| 03-31-2024, 05:26 PM | #1 |
582
Rep 1,557
[INFO] F48 Fuseguide / Power Supply Terminals
Terminals
Terminal 30 - Permanent power Terminal 30B - Power when driver is present Terminal 15 - Ignition Terminal 30F - Permanent unless fault detected (signal from BDC) Link with ability to comment if something is wrong and always most up to date version: https://docs.google.com/spreadsheets...it?usp=sharing For example if you want to retrofit a accessory that only is used when driving ( eg. dashcam without sentry mode) you can use a Terminal 30B fuse. If your accessory should always have power, then a use Terminal 30 (eg dashcam with sentry mode) Google these parts for pins/terminals that go back in the fusebox Mini Fuse: TE AMP MCP 2.8 connector - 61139232674 Regular fuse: TE AMP MCP 4.8 6.3 - I have no BMW number for this. Maxi: LSK8 - 12521436649 --- I did make this as part of my research how I should wire the "iconic grill" retrofit
Retrofits done: 2TB, 235, 313, 430, 456, 508, 5DP, 322, 674 , 6CP, 323,
552 Other mods: Central Locking button on both sides, Add extra trunk lights Other info: F48 Fuseguide, CarPlay 6CP - OEM way, 456 - X5 Comfort Seats in F48 X1 Last edited by mrpingu; 12-06-2024 at 03:21 PM.. |
| Bookmarks |
| Thread Tools | |
