BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) 323 - Softclose Retrofit on F48 :)
Thread Tools
      10-10-2024, 06:48 PM   #1
mrpingu
Norway
582
S323A - Soft Close Retrofit
Introduction
This was never released for the X1 but I found out that X5 and G12 use exactly the same doorlocks. Inspired by someone else in Norway who did this to i3 I thought to do this to my F48 aswell.
Result / in action:
https://www.youtube.com/shorts/N92flbMh9q8
As soft-close don't need any coding this is almost plug&play.
The parts we need
Cables & connectors
4x approx 1.5meter 0.35mm2 Cables (4 different colors)
2x approx 10meter 0.75mm2 Cables (2 different colors for ground & power)
8x 6-pin female Hirschmann sealstar connector
4x 2-pin 2way 1.2 SealStar FA Connector (Female)
4x 2-pin 2way 1.2 SealStar MA Connector (Male)
4x TE AMP MCP 2.8 connector - 61139232674 (fusebox)
8x Fillister head screw with collar 07147187828
4x 10A mini fuse
Soft-close motors
1x Lock, Bowden cable, front left 51207323781 / 51207419839
1x Lock, Bowden cable, front right 51207323782 / 51207419840
1x Lock, Bowden cable, rear left 51207323783 / 51207419841
1x Lock, Bowden cable, rear right 51207323784 / 51207419842
Soft close locks from X5*
* It depends if you have 8TG thiefproofing device on your X1 F48 you need to source correct locks
For vehicles with 8TG = YES (SCA / ZS)
1x Door lock, front left SCA / ZS 51217281949
1x Door lock, front right SCA / ZS 51217281952
1x Door lock, rear left SCA / ZS 51227281957
1x Door lock, rear right SCA / ZS 51227281958
For vehicles without 8TG = NO (SCA)
1x Door lock, front left SCA 51217281945
1x Door lock, front right SCA 51217281948
1x Door lock, rear left SCA 51227281953
1x Door lock, rear right SCA 51227281954
The wire-diagrams
Taken from G12, as the F15 wiring diagram is incomplete for this matter so I decided to create my own based on the evidence I found.
The original system on both the F15 & G12 both use terminal 30B. Using my fuse guide
I found that fuse 85, 86, 87, 88 is not used on my and probably most cars and that is on terminal 30B. So I will be adding the wires to these fuselocations. All motors use 10A minifuse. If one of these slots is taken try to find a free slot on the same block, so you stay on the correct terminal.
What needs to be done?
Step 1: Pulling a power wire from fusebox to each door
Step 2: Repin the locks
Step 3: Fix the motors
In this step we will be pulling a power wire from fusebox to each door and extra ground wire for passenger side rear door
Cable needs to be 0.75mm2 cross section. I stay with the standard and pick red wires for 12V+ & black wires for ground.
Fuse 85(Z7*6B pin 12) Driver side door (X28*1B pin 33)
Fuse 86(Z7*6B pin 11) Passenger side door (X5*1B pin 33)
Fuse 87(Z7*6B pin 10) Driver side, rear door (X8*1B pin 16)
Ground (Z10*7B) Driver side, rear door (X8*1B pin 15)
Fuse 88(Z7*6B pin 9) Passenger side, rear door (X9*1B pin 16)
Ground (Z10*6B) Passenger side, rear door (X9*1B pin 15)
As on the rear doors there is only 0.35mm2 ground wire I decided to pull an extra 0.75mm2 ground wire to the passenger footwell ground point (Z10*6B) as well from the passengerside rear door. (X9*1B pin 15).
For driver side I pulled the wire backwards to the ground point on the wheel arch (Z10*7B)
Need to remove the glovebox to get to fusebox
Then add the wires in the fusebox
Then run it to the doors, this shows passenger side rear door:
Close up of the B-pillar upper trim
Note added yellow wire in pin 16 and the black wire (ground) on pin 15 is added.
To keep it plug and play I use the 2-pin sealstar. Originally on non-soft close locks all pins are on the top connector but soft close locks also have a second connector. Pim 7 and pin 8 from the top connector need to go the pin 2 and pin 4 on the bottom connector.
Then just find add the 4 other wires between the motor and the lock according the diagram.
The motor needs also power and ground.
For power use wires that have been added in step 1.
Ground on the front doors can be just tapped into the ground wire inside the door. For the rear doors use the the ground pin that was added in step 1.
In the front doors you can reuse 1 small hole and a the big hole to fix the motor.
The rears door you have to drill a hole as there is no suitable hole and there is lot less space in the rear doors.
Front doors
No collision with the window.
Appreciate 5
      10-11-2024, 12:00 PM   #2
rice_rocket88
No_Country
342
Drives: E60 F48 F39
Looks pretty awesome!
      10-11-2024, 03:50 PM   #3
mrpingu
Norway
582
Yeah it actually is. Makes the car feel more premium. For time being did only passenger door and have still to source driver door lock but rears are sourced but still needs to be fitted.
In short it involves sourcing door locks & softclose motor from X5 F15 or 7 series G12 and install these. Soft-close was never released for F48 but F15 and G12 use same doorlocks.
      10-16-2024, 05:29 PM   #4
mrpingu
Norway
582
Decided to cut and paste all the wirediagrams and put together Soft-close Wire Diagram for the F48. If anyone wants to undertake themselves.
Is there any interest that I write a more comprehensive guide?
Appreciate 2
      10-16-2024, 06:35 PM   #5
rice_rocket88
No_Country
342
Drives: E60 F48 F39
For me I'm pretty much never going to undertake this task myself so no need. It is great info though! It's a pretty sweet feature I've seen on x5's of the past but my friend decided not to get it again after getting something caught in the older cars' door.
      11-27-2024, 02:18 PM   #6
wcruzeiro
wcruzeiro's Avatar
Brazil
72
Drives: BMW X1 F48
2018 BMW X1 F48  [0.00]
Simply incredible. This is a retrofit to be respected!
Maybe I'll try this one later on. For now, I'm motivated to reassembly my car and be able to drive it again, heheheh
Do you have the part numbers list to do this retrofit?
Thank you
      11-27-2024, 04:23 PM   #7
mrpingu
Norway
582
Added the guide, put lot more effort in the first part than the second but hope it’s useful enough. Includes part Numbers. Didn’t took pictures of everything but at added an good deal of them to show the extend of this retrofit.
      06-23-2025, 08:09 AM   #8
mrpingu
Norway
582
Finally found doorlock and softclose for reasonable price and got the time to install it on the driver door aswell. Snapped some more pictures.
For the driverdoor, because of the physical cylinderlock you also need to remove the doorhandle and loosen the support. Just something to keep in mind.
TIS / ISTA says you also need to remove the rear windowlift bar but that’s not needed. You can wiggle everything in place without removing this, there is enough room to get anything right.
Most challenging is get the doorhandle back in the support again but there is this trick you can use https://m.youtube.com/watch?v=4w17Qha_lIw
Thread Tools
Copyright ©2000 - 2025, vBulletin Solutions Inc.
