10-13-2024, 11:22 AM | #1 |
Rep 3
X1 (F48) iDrive 6 (2017) reset
Does someone know how to reset iDrive 6 on X1 F48 (2017). Holding only volume button longer than 30sec. doesn't do any iDrive reset . I'm trying to do reset because I can't get connection between My BMW application and the car (I'm in Europe).
I have Bimmer Link and Code applications and I don't see any errors. All system works normal. Is it there maybe any need for iDrive 6 update? Thanks in advance. |
10-14-2024, 03:02 AM | #3 |
Rep 3
Probably is upgraded 2022 via USB, now is inside according to the https://www.youtube.com/watch?v=_ozSVKtNUyo (at 1:34) "iDrive Professional NBT EVO (iDrive6.0)" and the car VIN info: I-Level F056-22-11-520.
10-14-2024, 06:31 AM | #4 | |
322
Rep 971
If no, VIN mismatch between ATM / HU disables ConnectedDrive If yes, does your car have 3G or 4G modem? Around 2017 BMW moved from 3G to 4G modem. Starting from production date 07/2017 AFAIK. Where I live 3G and most of europe 3G is shut down.
Retrofits done: 2TB, 235, 313, 430 459, 508, 5DP, 322, 674 , 6CP, 323
Other mods: Central Locking button on both sides, Add extra trunk lights Other info: F48 Fuseguide, CarPlay 6CP - OEM way |
10-14-2024, 02:00 PM | #5 |
Rep 3
Headunit is original, it is not replaced. l don't know which type of modem is installed, l pressume that 4G is inside, how to check this? GPS map work fine and telephone current version is TT-02.170.002.
