BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      01-08-2024, 06:04 AM   #749
mrpingu
Norway
194
Originally Posted by Ronnyt27 View Post
hi all, i'm new to coding. i'm getting the psdz error 433, when tried to read the SVT. any work around please?
i have the 2019 F48
Use "read ECU" on BMW x1 F48 using F056 profile
Retrofits done: 2TB, 235, 313, 430, 459, 508, 5DP 322
      01-08-2024, 07:56 AM   #750
Ronnyt27
Drives: BMW X1
read ECU, the HU_ENTRYNAV is red, couldn't code nor do anything though. can you walk me through this please?
      01-08-2024, 09:15 AM   #751
mrpingu
Norway
194
Red means, couldn't find that ECU / ECU Not Connected.
Do you have any errors or symptoms and what are you trying to do?
      04-26-2024, 03:30 AM   #752
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Hi, back to some coding learning after some time. Still trying to figure out coding 2VB for RDC. Wanna ask your existing value for BDC body is same as mine ?
      04-26-2024, 04:07 AM   #753
mrpingu
Norway
194
Wert_07 [07]
Why don’t you calculate correct value using SVT compare with your SVT and your FA?
      04-26-2024, 04:11 AM   #754
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Originally Posted by mrpingu View Post
Wert_07 [07]
Yes already compared and coded all the values but just trying out if I missed something. Just went to workshop they checked all my sensors were active. But it still stopped at 49%
      04-26-2024, 05:29 AM   #755
mrpingu
Norway
194
Which ECUs did you code? Need to code HU, DSC, BDC and KOMBI. Did you write VO to the car?
      04-26-2024, 07:51 AM   #756
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Saved the 2VB option and carried out the fdl coding.
I’ve actually tried 2 methods. The smart code on BU itself.
And then tried the NCD code from e-sys
Of course the “old” and “new” are just vice versa
      04-27-2024, 10:04 AM   #757
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
I’m wondering if bmw only accepts certain ID on the tpms sensors? It would be easy if only I can register the 4 IDs into receiver module lol.
      04-27-2024, 11:54 AM   #758
X1604M
X1604M's Avatar
57
Drives: 2018, F48 28i
2018 BMW X1 F48  [0.00]
I believe you are trying to add 2VB option. My F48 is Canadian version which does not required to have TPMS Sensors by law in Canada so BMW never installed them at that time. But I found out after some research it has all the required hardware onboard.
I just added 2VB option using Esys by using the VO coding method. Right after adding 2VB I drove around for about 20 minutes and everything showed up.
I just bought 4 TPMS from AliExpress for total 51C$ and have them installed. Nothing had to be done. They lasted about 3 years.
      04-27-2024, 07:42 PM   #759
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Yes that’s right I bought the same thing and wished it worked. I’ll just keep revert back and code the 2VB again until it works.
Came back from re setting the 2VB. Still stucked at 49%
Thinking of getting smartphone NFC coded TPMS sensors I saw on AliExpress.
https://www.aliexpress.com/item/1005...k=in_edm_other
      04-28-2024, 09:02 AM   #760
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
From E-sys to ISTA. Found a way to check on the RDC by deflating tyres and inflating back. Well at least I know my rear left sensor is defective. Now to call up seller if they would replace one for me lol.
      05-17-2024, 11:52 PM   #761
limsheng
Drives: BMW X1
2016 BMW X1  [9.00]
Finally replaced the 1 dysfunctional sensor and the reset made up to 51% , tyres turned green and eventually succeeded with the RDC. I.am.so.glad.
mrpingu193.50
