BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW E-sys coding for the f48 x1
      02-04-2016, 09:58 AM   #1
bmtespar
bmtespar's Avatar
709
Drives: 19 X3 30i, 18 230iX Vert
Howdy all. I started coding the new X1. There isn't much information out there in regards to coding the f48 I guess since it is so new. What I did find is that the coding is based off the F56 (Mini). I'm posting this here because there is apparently not a separate section for coding yet. Here are a few things I coded.
1.Auto Mirror fold on lock using fob or comfort access- love this!
2.Auto mirror unfold on unlock with fob or comfort access- again, love this!
3.Ring tone for calls in car is from my phone instead of different car tone
4.Got rid of idrive disclaimer page on start up.
5.Got text messages to show full message rather than 3 lines.
6. Fog lights can now be turned on while park lights on.
Some of the things I am trying to get working:
Driving lights stay on with high beams. Coded this but didn't work.
Cornering lights fiction with high beams.
On more thing, I could find no module for active sound.
Appreciate 3
      02-04-2016, 10:20 AM   #2
Bluezed
Bluezed
81
Drives: X1 25d xLine MG
Did you see a code for the Auto Stop/Start remaining 'as was' when the engine is switched off?
I have to keep remembering to do it manually every time I switch on.
      02-04-2016, 10:24 AM   #3
bmtespar
bmtespar's Avatar
709
If you are in the U.S., it is set to remember by default but to answer your question, that is a code option.
      02-04-2016, 10:48 AM   #4
Remmm
Remmm's Avatar
Netherlands
Drives: F48 Alpinweiss
Nice
I thought 1&2 are allready standard? I have 6 as well. But a friend of mine did it because i don't dare to do it myself. I think he based the changing on a 1-serie.
He coded the following stuff:
1. Auto start/stop off (when you start, i can put it on when i want)
2. M-performance logo instead of standard (when getting in the car, also in HUD)
3. Radio off, when opening door (instead of keep playing)
4. taillights on with DRL
5. We tried to get the fog-lights on when opening, but it doesn't work yet.
Next time we will look at:
- Change Angel Eye Brightness when headlamps on to 50%
- Turns on Fog Lamp with Welcome Lights
- Door handle LEDs light up when engaged in Reverse
- Allows Fog Lights to remain on when high beams are active.
- Adds the vehicle’s current speed to the BC cycle list (Displays on KOMBI screen)
- Max speed the mirrors will fold. (is to low)
- Number of turn signal flashes when locking.
- Adds iDrive setting to turn on/off the audible confirmation when Alarm is armed.
Also wondering if ASD is possible.
I am very curious if you manage to change one of the above
      02-04-2016, 11:55 AM   #5
bmtespar
bmtespar's Avatar
709
I forgot to mention, I changed my signal flashes to 5 instead of 3 and now digital speed to show in gauge center. I thought that there is already a setting to turn in off and on confirmation chirp for alarm and I thought the handles already lit when in reverse or maybe I coded that cause mine work.
      02-04-2016, 07:50 PM   #6
Shubha29
10
Drives: 2016 BMW X1
Hi,
Can u let me know if equalizer can be enabled by coding in Tone Settings?
I really miss the Logic 7 Equalizer in this F48 system.
      02-04-2016, 11:49 PM   #7
BMW newbie 2016
BMW newbie 2016's Avatar
Drives: 2016 X1, Mineral Grey
I had never heard of coding until I joined this group. I think it's great that you can customize so many aspects of the system in your car.
I am wondering how difficult this is to do and what type of equipment it requires.
Sounds like some of you guys are doing this yourselves. What do you need in terms of software and would a novice be able to code any of these things himself.
I like the idea of folding the mirrors when locking the car and changing the blinking signal from 3 to 5 blinks as someone had mentioned in this thread.
Also does this have any effect on the warranty of the vehicle?
I'm very interested in this type of manipulation of the system.
Thanks
      02-05-2016, 12:09 AM   #8
PF1
92
Drives: F48 X1 xDrive25i M Sport
Same here, coding sounds fascinating to me but also risky, so would appreciate any help from experienced coders to guide us newbies through our first coding session!
I have purchased the ENET cable (from eBay) which came with a CD (not sure if I should use whatever is on that disc). Also downloaded the E-Sys software recommended on this forum. Running that software looks a bit intimidating.
      02-05-2016, 07:40 AM   #9
bmtespar
bmtespar's Avatar
709
I am new to coding myself but people have been coding their cars for a very long time now. The good thing is that you can go back in and change settings of it causes a problem. I was nervous at first about coding so I had a guy stand over my shoulder the first time to make sure I followed the right step. My experience thus far is that it is very repetitious once you do it a few times. There are tons of E-sys install instruction out there. The things you need are:
Cable
E-sys software
E-sys launcher
Data files
Appreciate 2
      02-05-2016, 12:07 PM   #10
Vogit
93
Drives: X1 xDrive 20D xLine
Cable
E-sys software
E-sys launcher
Data files
Thanks for sharing this: I'm working myself up to trying a couple of things once I get the cable (Already got the software from other links on the forum), but haven't quite got the nerve yet.. Good to see how other people get on.
The main things I'd want to do are:
1) Mirrors auto fold/unfold (The long key press ends up starting to shut the blind on the sunroof.
2) Display road speed in the instrument cluster (With seat and wheel set for comfort i can't easily see both the speedo and the information display).
      02-05-2016, 02:18 PM   #11
bmtespar
bmtespar's Avatar
709
I have both of these things coded, although I have the HUD so it is sort of pointless for me.
      02-05-2016, 04:24 PM   #12
PF1
92
Cable
E-sys software
E-sys launcher
Data files
I have the first 3 items but I'm not sure where to get the Data files from, and is there a data file specific to the F48 or should I find the F30 or F20 one? Thanks.
      02-05-2016, 05:38 PM   #13
bmtespar
bmtespar's Avatar
709
It' s a set of files for all the models. You just want to make sure you have the most up t date ones you can get. When you launch the E-sys software, you tell the system which set of files to use depending on the car you are coding. There isn't a F048 file set listed yet but you can use the f56 files to code. I am using version 57.2 PSdZData lite.
      02-07-2016, 12:35 PM   #14
rinks7890
Drives: X1
Can the trunk be closed using the keyfob after ecoding ?
      02-07-2016, 07:02 PM   #15
Shubha29
10
Drives: 2016 BMW X1
Trunk can be closed with keyfob by default for F48.
      02-07-2016, 07:22 PM   #16
bmtespar
bmtespar's Avatar
709
I don't think it can be closed via the fob by default in the U.S. However, I did see see it can be coded to the x3.
      02-09-2016, 07:54 PM   #17
Shubha29
10
Drives: 2016 BMW X1
I have the closure via keyfob as well. Will check again and let u know.
      02-16-2016, 10:21 AM   #18
Vogit
93
bmtspar: Cautiously working my way in to coding, but not sure which parameters to code to achieve the above, as what I'm reading from my ecu doesn't seem to tie up with the F56 crib sheet. I'd be very grateful if could let me know what you did.
      02-16-2016, 02:34 PM   #19
bmtespar
bmtespar's Avatar
709
Use the f30 code sheet and see if it makes more sense to you. In the f48 the NBT module is called HU Navi or something like that.
      02-16-2016, 02:41 PM   #20
Vogit
93
Thanks, will give that a try
      02-17-2016, 08:34 AM   #21
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
x3 forum has coding thread, it should be similar
      02-17-2016, 02:02 PM   #22
giddyup69
Drives: '13 F30 335xi
Good thread. My dad is taking delivery of his X1 soon and was specifically wondering how to code it like my F30. Thanks for all the info.
'13 F30 335xi • white/black • m-sport
