05-08-2024, 02:12 AM | #1 |
Rep 13
X1 Battery power for Amp - Options and help
Hoping someone can point me in the right direction. I've watched endless YouTube videos and scoured the internets.
So I have already swapped all the speakers in my base audio X1 to audison and that makes a huge difference. The next step is to add an Amp because the head unit really can't drive the speakers that well. So I am working out what the best way of getting power to the amp is. So I've seen people go from the battery through the bulkhead to the boot and use a ground there in the boot. On top of the battery is what looks like something that could take a power connection but I don't know if this is the case for UK X1 I am aware there is an actual fusebox in the car and for a pre built hifi there would be a fuse here. I don't know whether I should be pulling power from that (but it also looks very very difficult to access) I also note that the boot of the car has power with the 12v lighter and it's my understanding that is a 20amp connection from the fusebox. This would be the path of least resistance but I've not read anyone using this - so there's probably something very wrong with it The rest of the wiring would be the looms from Audison from the head and the seats so that should be okay. It's the power I'm most concerned with, not something I've messed with before. In fact is there such a thing as a mobile installer who could do this for me? There's no one locally that can do it that I've found and I just want the install - I'll do the calibration and set up... cheers Paul |
05-08-2024, 03:04 AM | #2 |
194
Rep 651
I answered you in the X2 forum. But in addition to that and to answer your question about access:
You have to remove the glove box to gain access. Last edited by mrpingu; 05-08-2024 at 03:42 AM.. |
05-09-2024, 06:06 AM | #3 | |
Rep 13
Couple of points, the amp itself (Audison F8.9) has 2 x 30amp fuses on it. There is a HiFi fuse on the diagram that says 30 amp. I don't know if the base audio still has that fuse. I'm struggling to find the actual amperage of the amp. The quoted is based on a signal into 2 Ohm (55amp), but I am 4 Ohm. In theory 30 amp would give around 360w of power at 12v. The amp would be capable of driving 4 x 85w and 2 x 130w however I cannot ever see me being anywhere near that. The base head is loud enough at 15w(?) per channel. But the head unit cannot drive the underseats very well at all. Hence needing an amp to drive everything 'properly' So in this case, 30amp is probably fine but I don't know whether because the amp could do more is it going just trip the fuse or is it a case of if you don't turn it up to 11 then the power draw would never trip? I could get a lesser amp I guess. When it comes to getting a cable to the fuse box what kind of connection can be used? Once I've got to the fuse box, what's the best way of connecting? I note that the rear 12v point is rated at 20 amp. Make me wonder whether a small amp off that would be enough... thanks again! Paul |
05-09-2024, 08:14 AM | #4 | |
194
Rep 651
Using my fuse guide you can use 2 fuses just find a free spot on the same terminal Base audio probably has not the fuse inserte for HiFi amp. Easiest is to check yourself. But if the amp has two fuses on it already then you don’t need to fuse it again but… it’s easier to take power from the fusebox then going through the firewall. However on the driverside there is an unused grommet you can push out from the inside. If you are going to the fuse box route You need the double leaf spring contacts back in the fusebox, see the other topic. No 1 and 2 in the diagram. Also a thing to keep in mind is the wire thickness, 30A need thicker wire than 20A Where do you plan to locate the AMP and where are you going to run/ reuse the speaker wires? |
05-09-2024, 10:50 AM | #5 | |
Rep 13
I'll check the double leaf spring contacts. I'm sure you're right. The base probably doesn't have a 30a fuse there. Would there be another place I could take it from? If it was to come through the bulkhead then back on the battery itself there is a plate with connections but I'm lead to believe any free ones also probably don't have connections in. It seems that most people put the amp in the boot. I have the audio wiring harnesses from Audison. So that would be a connector from the head unit channeled down the side to the rear. Then there is another speaker connector from the two front seats so that the underseats can be driven separately, and that then channelled to the back - all of this on the passenger side. I believe there are many cables doing this already. If I could install the amp up front them I guess I would but realistically there's got to be a reason why everyone pops it in the back and perhaps heat/space. Looking at the specs there is a version of the amp which has half the power, and is rated for 30a. So perhaps that may be a better choice. So that 20a boot cigarette power is a no no? cheers Paul |
05-09-2024, 11:55 AM | #6 | ||||||
194
Rep 651
This is why, using the fusebox is the cleanest way. There is a wire directly from battery going into the fusebox, this wire is also fused and is really thick. Quote:
I found this video helpful: https://m.youtube.com/watch?v=e7vaPIqexP0 Quote:
But again I don’t see the problem for you as you need to run wires through the car anyway to just buy 2 spring leaf contacts and run the wires from the fuse box and use 2x 30A fuses in the fuse box. |
05-10-2024, 04:55 AM | #7 | ||||
Rep 13
Firstly again, thanks so much for replying, it's really useful.
The guidances shows a LHD but on a RHD I assume the fuse box is still passenger side behind the passenger compartment unit. How difficult was it to get to it? And to work with it? Quote:
I hadn't considered 2x30a. I presume they just get joined together? But if one fuse blew then is there an issue with a joined power connection? Are there potential dangers here? I could swap the amp for the model under, which draws less power and is rated for 30amp. I hadn't really considered that to be an issue with the bigger amp but it does make sense. thanks Paul |
05-10-2024, 06:31 AM | #8 | |||
194
Rep 651
No not for the LED in grill yet, but have to do that but for the Trailer Hitch I did. On X1 the board hangs on kind of hinges, if you get the glovebox off you have to push down the airducts for feet heater a little down and then you get it out see the attached images Quote:
I Don’t see How that should be more difficult, in my head I mean you need to take output from the Headunit to the amp (If you want to get to the sides it’s easiest to remove the glovebox and then then run it passenger side to the back) then from the back you need either connect the speakers. Either with new cable and or add them at the headunit. At this point you already have dismantled a good part of the car to run those wires. So taking it directly from the battery to the amp or from the fusebox I don’t see that as much more difficult. Quote:
Yeah th wil be joined, probably 2 power lines, how it’s split up I don’t know but probably 30A for the woofers and 30A for the rest. The only danger is using too thin wires. Look up AWG 12V chart. |
05-10-2024, 09:46 AM | #9 | |
Rep 13
Routing the cables are fine, just fiddly. No issues doing the speakers or cross overs and getting the seats out - that was easy. I think part of the challenge is finding an appropriate location to pull the power from. The car is based audio - no amp and I will need to get to the fusebox to see what is in there and whether there are 'spare' 30a fuses and connections I can get to. thanks! Paul |
05-10-2024, 09:58 AM | #10 |
Rep 13
Sorry, this is an actual question. Look at guides I see people using fuse taps to wire in some accessories but I am guessing fuse taps won't be good enough for 30a worth of power.
So how would I actually go about getting a cable in? I would have to remove one of the plugs from the back (like the you tube video) and you mentioned above double spring connectors. Could you explain a bit more? thanks Paul |
05-10-2024, 10:29 AM | #11 | |
194
Rep 651
Depinning is a pain but adding is not that hard if you have a wire with the double leaf spring contact. If you look at the attached photo you see how it works. 5 of the slots are pinned. This means the outside edges now have metal. The middle row is always hot (has always 12V) it has metal springs as well but hard to see on the photo. when plugging in a double leaf spring contact you add basically a a slot for the fuse to go and when omsetting the fuse you let the power flow from the middle to the outside. The outside is connected to the outgoing wire. In other words the the fuse acts as a bridge. Hope I explained in a good way. It’s not hard either, just time consuming /fiddly like you say. Although glovebox out is max 10 min job. But again this is certainly the most clean and professional way to do it. Add-a-fuse is basically the same thing but you can plug in the wrong way, if you do that everything goes through the first fuse before it goes through the second. Explained here as problem 1 and 2: https://www.evilution.co.uk/mod/fuse-taps.htm Problem 4 is almost non-existent practically in our cars as the fusebox is almost directly connected to the battery and there is a lot of headroom if I had to guess. While it might be, do I think it’s not really a practical limit you will be hitting here. |
05-10-2024, 12:34 PM | #12 | ||
Rep 13
Aside from it not really being a pro method and getting it the right way around, are there additional downsides I'm missing? thanks! Paul |
05-10-2024, 12:53 PM | #13 | |
194
Rep 651
I think you are overthinking this Just start and you will see you will be fine in the end. Reuploaded the images |
05-10-2024, 02:45 PM | #14 |
Rep 13
05-10-2024, 03:47 PM | #15 |
194
Rep 651
05-11-2024, 08:19 AM | #16 |
Rep 13
So interestingly my fuse box that I just took a photo of doesn't seem to have that whole section that you're showing. This is a 2017 X1.
What I assume I could do is that I see metal on the sides of some of the fuses, like where there is 20, 40 and 20. I assume that side is battery positive but on the other side would currently be empty. Strikes me the simplest thing is a Fuse Tap in there with an empty slot for the tapped fuse and a 30amp with 30amp cable off. That way I don't have to try and get the main fuse part off and then try to add metal tabs in there. That would be 10awg cable. Sounds plausible? cheers Paul |
05-13-2024, 03:07 AM | #17 | |
194
Rep 651
Yes that can be possible, I retrofitted it when doing the trailer hitch. Assuming you don't have a trailer hitch so you don't have the upper section. Those fuses are only used for the trailer hitch, but you can buy this part for easy acces and then use the fuses there. Requires some coding to activate that part though. Metalside = Connected to the battery, yes On the empty side you plug in the double leaf spring contact from behind. Then you got metal on both sides and can put in a fuse if want to go that route. 10AWG sounds plausible. |
05-20-2024, 04:18 AM | #18 | |
Rep 13
I did look at a fuse tap, but the only ones I found were 16AWG and thought that was too thin for 30amp (even though the taps are sold as rated for 30amp). You can get 12 AWG versions though. But going through the back 'properly' like you said seems on balance the better choice. I was wondering - can you take these connectors out of an existing fuse board? I have the one I bought off eBay to experiment with but not been able to remove a connector - maybe there's a trick, maybe it's not possible? I was planning on tapping into the same fuse that the official BMW Amp would it in, it's the medium sized fuse. One thing I note is that 8AWG isn't going to fit, maybe 10 would and I'd argue that BMWs own wiring for 30amp or even 40amp is considerable less than even 10 AWG. What sort of size cables have you been using? Many thanks Paul |
