01-24-2023, 06:25 PM | #89 | |
3084
Rep 3,029
Drives: 2019 M2 Competition
Incredibly helpful, thank you for the links and for the bulbs as well!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
07-14-2023, 02:23 PM | #90 | |
Rep 15
I have installed them with relative ease. Professional has installed fourth wire (EU halogen version has only three by default). Coded everything in latest version of Bimmercode as per incredibily helpful instuctions in this thread. Almost happy with result, but there is one thing I'm not able to resolve just yet. Light position on dial is set on automatic "0". When car is driven outside on a sunny day, everything is fine. Front daytime lights are working and LED "stripes" on tail lights are working too. When car enters in garage (or is driven at night) low beam turns on automatically and outer LED strips immediately shuts off. Any thoughts? Help is much appreciated because I've exhausted immediate ideas and obviously I have to code something in addition to what has been done. |
07-27-2023, 10:17 AM | #91 |
578
Rep 2,047
This feature of low beam turning on is country specific. Did you have it before replacing the tail light?
You can try vo coding using different countries and region and check if anything changes. |
09-17-2023, 09:10 AM | #92 | |
Rep 15
Our car was manufactured in Germany (German model). We're second owners. When I was purchasing (second hand set) of pre-LCI tail lights I was careful to purchase the tail lights from the same market (Germany) and same model year (to eliminate "country specific issues") I have not been able to resolve the problem. Since I found no apparent error with the coding, my attention turned again to the wiring. Maybe someone with EU-spec car can take a photo of wires going in outer tail lights? Maybe wiring combo differs from US model, expained in this topic? |
01-03-2024, 10:29 AM | #93 |
Rep 17
Hi there. I'm new to this forum. I have a '16 25i X-drive and live in The Netherlands.
My car came with halogen lights. I want to convert the full bulb tail lights to pre LCI Leds. The outer rear lights only have 3 wires so the conversion kit instructions (4 wires) do not meet my car. I read that a few of you are struggeling with the same issue. Like the members inlinesix85, zeidroc, jkont. Maybe one of you have cracked it and can share it with me. Many thanks! |
01-03-2024, 11:16 AM | #94 | |
188
Rep 609
Pay attention to the connectors at the taillight E57*1b / E58*1b / E60*1b / E62*1b Succes ermee |
01-03-2024, 01:10 PM | #95 |
Rep 17
Takk mrpingu! This makes sense. I already placed two extra cables from the tail lights to the Body Domain Controller. So this should now be a piece of cake.
01-04-2024, 01:35 PM | #96 |
Rep 15
Hello MichielX1. Did you succeed with the installation? Everythng working fine now? Can you ellaborate a bit and share some photos? Thank you.
01-08-2024, 10:00 AM | #97 |
Rep 17
01-11-2024, 10:35 AM | #98 |
Rep 17
So today I did the final wiring and coding. The outer leds do not work. The outer bulbs are still on. I connected the new wires to slot 42 in the body domain, and the other ends in slot 2 of the rear lights. Maybe I did something wrong. mrpingu of others any ideas?
01-11-2024, 10:48 AM | #99 |
578
Rep 2,047
How did you code the tail lights? For F48 the coding is different for LED and halogens, LED conversion using bimmercode is not enough. There is necessary coding for mapping the extra lights that the halogens dont have.
01-11-2024, 11:02 AM | #100 |
Rep 17
I turned the day running lights on and the rears outer lights to led, like advised earlier in this thread.
01-11-2024, 11:41 AM | #101 |
188
Rep 609
Best way is to code VO-code H-wort HELC «Conversions to new LCI Taillights». This is What the dealer would have done when they would installed the official retrofit kit for LCI taillights listed here:
https://www.realoem.com/bmw/enUS/sho...diagId=03_5090 You can ofcourse set all FDL values by hand if you want but there are 50+ of FDL values that change when I calculate from my FA which has already has 5A4 Led Headlights (So preLCI taillights with only LED strip for taillights, rest is halogen bulbs) |
01-11-2024, 11:55 AM | #102 | |
188
Rep 609
When I VO-coded / calculate using 8TL «active front and rear daytime running lights» I found out the error was gone and the lamps (both inner & outer) work as expected. Personally I coded, 8TN, 8TL to the car so that when car is at the dealer those codings are not erased. 8TN is for the option in iDrive to turn off DRL lights, nothing more. In your case I would also suggest to VO-code the correct H-wort to the VCM of the car so no dealer can accidently mess up the codings. (E.g. If the car gets in for the EGR recall) Edit: Unsure now, do you have retrofitted preLCI or LCI taillights? If you have fitted preLCI taillights, please post all your mapping & PWM values related to taillights. You can use this document as template: https://docs.google.com/spreadsheets...456x__ZQ0/edit TAB: BDC_BODY lampmapping Last edited by mrpingu; 01-11-2024 at 01:32 PM.. |
01-11-2024, 01:48 PM | #103 | |
Rep 17
Since I installed and tested the lights indoors, it is possible that the outer rear lights will work in daylight. But shut off when dark, just like the LED conversion that inlinesix85 descipes earlier in this threat. I will check this tomorrow. |
01-11-2024, 02:24 PM | #104 | |
188
Rep 609
Yes all these values can read/changed in BimmerCode Expert Mode. But test all functions of the lights first, like off, Parking light mode and on. Blinkers etc. If the outer part still not work look up all parameters of and post them here. MAPPING_PARKL_H… (H stands for hinten, meaning rear in German) MAPPING_STANDL_H… MAPPING_TAGFAHR_H… Thing is that these settings of LampMapping er very sensitive with right settings. |
01-11-2024, 02:43 PM | #105 | |
Rep 17
01-12-2024, 10:22 AM | #106 |
Rep 17
I tried again but no luck. Outside lights do not work, outdoors or indoors. I'm fed up with it. The coding becomes too complicated for me. With the risk of changing significant data. Also because other members here didn't crack it too. So I put the original lights back. And sell the Leds. Thanks for your support.
01-12-2024, 10:54 AM | #107 |
578
Rep 2,047
If you have enet cable i can help you with the coding.
Here is the difference i used on a F48 that has same issue. You can try ncd1 parameters. Not sure if its the same match but it varies according to the vehicles configuration. Difference BLINKERSTATUS_PLAUSIPRUEFUNG_AKTIV NCD1: vorne_aktiv [01] NCD2: nicht_aktiv [00] BL_L_CCM NCD1: ccm_bl_l [00 88] NCD2: ccm_bl_rl_l [01 5A] BL_L_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] BL_L_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] BL_R_CCM NCD1: ccm_bl_r [00 86] NCD2: ccm_bl_rl_r [01 59] BL_R_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] BL_R_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] FRA_H_L_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] FRA_H_L_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] FRA_H_R_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] FRA_H_R_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] MAPPING_BLINKER_H_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_BLINKER_H_L_IGR_RELEVANT NCD1: not_active [00] NCD2: active [01] MAPPING_BLINKER_H_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 13.7V [89] MAPPING_BLINKER_H_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_BLINKER_H_R_IGR_RELEVANT NCD1: not_active [00] NCD2: active [01] MAPPING_BLINKER_H_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 13.7V [89] MAPPING_BRAKEFORCED_1_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_BRAKEFORCED_1_L_PWM_2_ESS_1 NCD1: 100%, 100% [64] NCD2: 12.9V [81] MAPPING_BRAKEFORCED_1_L_PWM_3_ESS_2 NCD1: 100%, 100% [64] NCD2: 12.9V [81] MAPPING_BRAKEFORCED_1_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_BRAKEFORCED_1_R_PWM_2_ESS_1 NCD1: 100%, 100% [64] NCD2: 12.9V [81] MAPPING_BRAKEFORCED_1_R_PWM_3_ESS_2 NCD1: 100%, 100% [64] NCD2: 12.9V [81] MAPPING_BREMSL_1_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_BREMSL_1_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 12.9V [81] MAPPING_BREMSL_1_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_BREMSL_1_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 12.9V [81] MAPPING_PARKL_H_2_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_PARKL_H_2_L_OUTPUT NCD1: sl_2_l [16] NCD2: bl_l [18] MAPPING_PARKL_H_2_L_PRIORITY NCD1: priority_2 [02] NCD2: priority_4 [04] MAPPING_PARKL_H_2_L_PWM_1_LEFT NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_PARKL_H_2_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_PARKL_H_2_R_OUTPUT NCD1: sl_2_r [17] NCD2: bl_r [19] MAPPING_PARKL_H_2_R_PRIORITY NCD1: priority_2 [02] NCD2: priority_4 [04] MAPPING_PARKL_H_2_R_PWM_2_RIGHT NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_PARKL_H_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_PARKL_H_L_OUTPUT NCD1: sl_l [14] NCD2: nsl_l [1C] MAPPING_PARKL_H_L_PRIORITY NCD1: priority_2 [02] NCD2: priority_3 [03] MAPPING_PARKL_H_L_PWM_1_LEFT NCD1: 100% [64] NCD2: 0V [00] MAPPING_PARKL_H_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_PARKL_H_R_OUTPUT NCD1: sl_r [15] NCD2: nsl_r [1D] MAPPING_PARKL_H_R_PRIORITY NCD1: priority_2 [02] NCD2: priority_3 [03] MAPPING_PARKL_H_R_PWM_2_RIGHT NCD1: 100% [64] NCD2: 0V [00] MAPPING_RUECKFAHRL_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_RUECKFAHRL_L_IGR_RELEVANT NCD1: not_active [00] NCD2: active [01] MAPPING_RUECKFAHRL_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 13.7V [89] MAPPING_RUECKFAHRL_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_RUECKFAHRL_R_IGR_RELEVANT NCD1: not_active [00] NCD2: active [01] MAPPING_RUECKFAHRL_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 13.7V [89] MAPPING_STANDL_H1_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H1_L_OUTPUT NCD1: sl_l [14] NCD2: nsl_l [1C] MAPPING_STANDL_H1_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H1_L_PWM_2_REDUCED NCD1: 100% [64] NCD2: 0V [00] MAPPING_STANDL_H1_L_PWM_3_REAR NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H1_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H1_R_OUTPUT NCD1: sl_r [15] NCD2: nsl_r [1D] MAPPING_STANDL_H1_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H1_R_PWM_2_REDUCED NCD1: 100% [64] NCD2: 0V [00] MAPPING_STANDL_H1_R_PWM_3_REAR NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H2_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H2_L_OUTPUT NCD1: sl_2_l [16] NCD2: bl_l [18] MAPPING_STANDL_H2_L_PRIORITY NCD1: priority_3 [03] NCD2: priority_5 [05] MAPPING_STANDL_H2_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_L_PWM_2_REDUCED NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_L_PWM_3_REAR NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H2_R_OUTPUT NCD1: sl_2_r [17] NCD2: bl_r [19] MAPPING_STANDL_H2_R_PRIORITY NCD1: priority_3 [03] NCD2: priority_5 [05] MAPPING_STANDL_H2_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_R_PWM_2_REDUCED NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_R_PWM_3_REAR NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_UNIVERSAL_3_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_UNIVERSAL_3_FUNCTION NCD1: off [00] NCD2: standlicht [01] MAPPING_UNIVERSAL_3_IGR_RELEVANT NCD1: not_active [00] NCD2: active [01] MAPPING_UNIVERSAL_3_OUTPUT NCD1: off [00] NCD2: sl_2_l [16] MAPPING_UNIVERSAL_3_PRIORITY NCD1: priority_1 [01] NCD2: priority_2 [02] MAPPING_UNIVERSAL_3_PWM_1 NCD1: 0V [00] NCD2: 13.7V [89] MAPPING_UNIVERSAL_3_PWM_3 NCD1: off [00] NCD2: 13.7V [89] MAPPING_UNIVERSAL_4_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_UNIVERSAL_4_FUNCTION NCD1: off [00] NCD2: standlicht [01] MAPPING_UNIVERSAL_4_IGR_RELEVANT NCD1: not_active [00] NCD2: active [01] MAPPING_UNIVERSAL_4_OUTPUT NCD1: off [00] NCD2: sl_2_r [17] MAPPING_UNIVERSAL_4_PRIORITY NCD1: priority_1 [01] NCD2: priority_2 [02] MAPPING_UNIVERSAL_4_PWM_1 NCD1: 0V [00] NCD2: 13.7V [89] MAPPING_UNIVERSAL_4_PWM_3 NCD1: off [00] NCD2: 13.7V [89] NSL_L_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] NSL_L_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] NSL_L_UE_SPG_SCHUTZ NCD1: aktiv [01] NCD2: dimmed [02] NSL_L_WARMUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] NSL_R_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] NSL_R_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] NSL_R_UE_SPG_SCHUTZ NCD1: aktiv [01] NCD2: dimmed [02] NSL_R_WARMUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] RFS_L_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] RFS_L_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] RFS_L_WARMUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] RFS_R_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] RFS_R_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] RFS_R_WARMUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] SIGNATURE NCD1: UNKNOWN [00 00 00 20 A8 CE F0 58 51 72 84 2F BA C4 D6 72 42 99 7B 20 03 A4 19 6D 4B 6A FE B8 52 D8 20 89 ED 25 F3 B1 20 03 A5 D6 FE 09 23 1C FA CA 98 3A 4B 66 3C 90 99 28 99 56 0E C2 CB 56 2F 42 6E 2B 42 2F 34 A5 E9 18 67 B0 DF 65 36 E1 36 39 05 96 05 27 04 64 FF 00 09 FB E6 24 B4 31 18 8F 71 61 CE 02 84 D2 A1 DC CE 9C 25 81 C7 45 F1 11 E4 C5 74 A0 84 F9 FD 53 C4 BD 66 9B 07 98 AC 00 BA 8E 05 D1 C8 03] NCD2: value [00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00] SL_2_L_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] SL_2_L_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] SL_2_L_WARMUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] SL_2_R_IS_LED NCD1: aktiv [01] NCD2: nicht_aktiv [00] SL_2_R_KALTUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] SL_2_R_WARMUEBERWACHUNG NCD1: nicht_aktiv [00] NCD2: aktiv [01] SL_L_CCM NCD1: ccm_sl_l [00 85] NCD2: off [00 00] SL_L_UE_SPG_SCHUTZ NCD1: dimmed [02] NCD2: aktiv [01] SL_R_CCM NCD1: ccm_sl_r [00 76] NCD2: off [00 00] SL_R_UE_SPG_SCHUTZ NCD1: dimmed [02] NCD2: aktiv [01] SMALL_SL NCD1: nicht_aktiv [00] NCD2: aktiv [01] |
01-12-2024, 11:18 AM | #108 | |
188
Rep 609
BimmerCode -> Body Domain Controller -> Export Mode -> LampMapping3 & LampMapping4 |
01-12-2024, 11:20 AM | #109 | |
188
Rep 609
It is however for LCI |
01-12-2024, 11:29 AM | #110 |
188
Rep 609
USE the values from NCD1 for these and set the light switch in 2 o’clock position.
MAPPING_STANDL_H1_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H1_L_OUTPUT NCD1: sl_l [14] NCD2: nsl_l [1C] MAPPING_STANDL_H1_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H1_L_PWM_2_REDUCED NCD1: 100% [64] NCD2: 0V [00] MAPPING_STANDL_H1_L_PWM_3_REAR NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H1_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H1_R_OUTPUT NCD1: sl_r [15] NCD2: nsl_r [1D] MAPPING_STANDL_H1_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H1_R_PWM_2_REDUCED NCD1: 100% [64] NCD2: 0V [00] MAPPING_STANDL_H1_R_PWM_3_REAR NCD1: 100% [64] NCD2: 4.8V [30] MAPPING_STANDL_H2_L_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H2_L_OUTPUT NCD1: sl_2_l [16] NCD2: bl_l [18] MAPPING_STANDL_H2_L_PRIORITY NCD1: priority_3 [03] NCD2: priority_5 [05] MAPPING_STANDL_H2_L_PWM_1_STANDARD NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_L_PWM_2_REDUCED NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_L_PWM_3_REAR NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_R_FIXED_PWM NCD1: fixed [01] NCD2: pwm [00] MAPPING_STANDL_H2_R_OUTPUT NCD1: sl_2_r [17] NCD2: bl_r [19] MAPPING_STANDL_H2_R_PRIORITY NCD1: priority_3 [03] NCD2: priority_5 [05] MAPPING_STANDL_H2_R_PWM_1_STANDARD NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_R_PWM_2_REDUCED NCD1: 100% [64] NCD2: 6.2V [3E] MAPPING_STANDL_H2_R_PWM_3_REAR Stuur een PM met je nummer je hulp nodig via WhatsApp in het Nederlands Daarnaast kan je backup met BimmerCode maken dus je kan altijd terug en er zijn ook mensen met e-sys dan kan je altijd terug naar fabrieksinstellingen dus relatief weinig risiko. Belangrijk is alleen om zorgvuldig de waarden goed te zetten. |
