BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) F48 cruise retrofit
      01-16-2024, 09:29 AM   #1
x1sando
Drives: x1 118d xdrive
F48 cruise retrofit
Hi all I’m trying to add cruise control with brake function to my f48. I’ve purchased and fitted the parts required but need some help with coding ect.
Thanks
      01-16-2024, 01:07 PM   #2
mrpingu
181
Thanks
Do you have ENET Cable?
      01-16-2024, 01:11 PM   #3
x1sando
No not yet I’m looking for what is needed ect. Or if it can be done via BimmerCode in expert mode
      01-16-2024, 03:05 PM   #4
mrpingu
181
Don’t think so as you cannot code the DSC2 with bimmercode if remember correctly.
If you can access the DSC2 ECU from bimmercode; Scroll to the end of the article and change to values mentioned at the bottom using BimmerCode Expert Mode. It’s only 4 values
http://*********f46.blogspot.com/201...ntrol.html?m=0
Edit Fill in ‘bmw coding’ without space on the stars. Forum censors…
Problem is that I think you cannot access the DSC2 with BimmerCode. If that’s true then you need e-sys and for e-sys you need ENET cable.
Retrofits done: 2TB, 235, 313, 430, 459, 508, 5DP 322
