01-12-2024, 11:32 AM | #111 |
578
Rep 2,047
There parameters i posted arent exact same match. They are not the full parameters, they are part of the difference i found necessary to change. NCD1 is for LED NCD2 is for halogens. Car is 2019 F48 LCI
01-12-2024, 12:05 PM | #112 | |
Rep 15
I'm the guy that posted previously in the same topic with exactly the same issue. Thanks for bringing the topic back to life and trying to help. I just went into an expert mode - suprised that there are so many values. Before I start digging for values in LceLampMapping3 &4 , is there a better way to export them all before posting here vs. making screenshots on the mobile phone - perhaps by exporting backup file? Also, do you think that writing directly to bimmercode regarding this issue would make any sense? Last edited by inlinesix85; 01-12-2024 at 12:32 PM.. |
01-12-2024, 12:16 PM | #113 | |
Rep 15
I'm also afraid of messing something in expert mode and potentialy bricking parts of the car (that would really ramp up the bill and I have no support), but at this point it is just about knowing precisely which values are to be inserted/replaced... Your experience at least confirmed for me that issue lies not with wiring (proper placing of 4th wire) and turing on certain bimmercode options in simple mode...it is a small step forward at least. |
01-12-2024, 12:30 PM | #114 | |
Rep 15
01-12-2024, 01:16 PM | #115 | |
181
Rep 595
The thing is the lampmapping data seems like a lot of code but is actually very logical build up. So for a start you can only take the STANDL_H_ entries which corresponds to dipped beam rear lights. Then take only _R in the name and we have only the right side. First I need to have a bit of overview what is set. I suspect something is wrong with the PWM values but unless I see the big picture it’s hard to help / the right values. The thing is on my car I have already working as it should, that means if your values are different then it must be in these differences.0 Last edited by mrpingu; 01-12-2024 at 01:24 PM.. |
01-13-2024, 03:53 AM | #117 | |
Rep 15
There are 216 values pertaining to STANDL, PARKL or TAGFARL for rear lights in expertmode. I managed to transcribe them all to Excel. Since I ccanot attach .xls document here, I printed it as .pdf. Hope you'll be able to navigate trough and compare these to your values. |
01-13-2024, 06:50 AM | #118 | |
181
Rep 595
Output, function, priority & PWM parameters are all off compared to LED version of the lamp. Please take the values from the sheet I posted earlier. That should work. I filled & checked them all for those 3 (STANDL, PARKL & TAGFAHRL) only “hinten” (H) not the fronts “voran” (v). There are several tabs in this sheet but you need the BDC_Body Lampmapping Tab. https://docs.google.com/spreadsheets...456x__ZQ0/edit What I noticed from your values is that the halogen version of the rearlight share the same bulb for rear fog lamp and normal light. Only run at a different (lower) Voltage level so the normal light is not as bright as the fog light. In the LED version theres a separate bulb for rear fog light and thus and should the mapping / routing of the lights be different. I am pretty sure these values should fix the problem. But I have become unsure if the Rear fog light still works as expected, so you might want to test that aswell. — PS: I started this sheet to better understand all the lighting options in the coding and in different modules. After I gained understanding I managed to turn on corner & fog lights together with high beam. So when I use high beam I see both wide & long Last edited by mrpingu; 01-13-2024 at 06:57 AM.. |
01-13-2024, 01:50 PM | #119 | |
Rep 15
Hello MrPingu, I have cross referenced all the values in my table with your table and attached is the final result. Can you please check once more and confirm that this is it? I spend a lot of time today staring at this table and it is perfectly possible that I made some mistake(s) along the way. Before I start coding, in your opinion, can I damage anything in Body control module in case of something goes wrong despite checks (missing / wrong value)? Someone earlier mentioned that light dial should be in two 0'clock position - is this of any importance in this case? I have pre-LCI led lights (LED stripes and bulbs combo). I understand the comment regarding fog lights, but this i, frankly least of my concerns at the moment. Just want to make darn stripes work properly :-) Thank you for great support. Last edited by inlinesix85; 01-13-2024 at 02:03 PM.. |
mrpingu180.50 |
01-13-2024, 01:54 PM | #120 | |
Rep 15
It seems that we (mostly MrPingu to be truthfull) made some progress while you were away and you may jump back in and help us to test solution.... |
mrpingu180.50 |
01-13-2024, 02:35 PM | #121 | ||||
181
Rep 595
Also let make BimmerCode make a backup and write timestamp down so if anything goes wrong you can revert and are sure which date & time the backup is from. You cannot damage the BDC itself. We are only changing things regarding LampMappings, so the risk is really low. Worst case, none of the lamps work due to incorrect mapping. And really worst case is that we blow a fuse because of wrong voltages but it’s highly unlikely as halogen draws more than LED. And not to forget, the coding is already wrong So to be honest I really think this is a low risk operation. General coding risk still apply, like power outage due to low battery but otherwise I don’t see any big risks. If in any case BimmerCode cannot revert the backup, we can always change the values back by hand as you have noted them your excel sheet. So we have some lines of defense. Quote:
Good you mention it one more time, that’s what the values are for and also I have. The lucky part is that I have a PreLCI with Led Headlights and thus striped rears. So I am pretty sure about the values. IMO the pre LCI looks better than the LCI. PreLCI has 2 stripes, LCI only 1. Quote:
EDIT: I see now that also applies for brake light, double check the brake lights Last edited by mrpingu; 01-13-2024 at 02:51 PM.. |
inlinesix854.50 |
01-17-2024, 04:48 PM | #122 | |
Rep 15
As per above posted tables, I carefully replaced 44 values in total. And it worked. Like a charm. Fog lights working. Brake lights working. LED stripes have increased in brightness slightly. No errors whatsoever, car is not complaining (and BDC module is still in one piece, I guess, no smoke coming from passenger footwell) MrPingu, you have my deepest gratitude |
mrpingu180.50 |
01-17-2024, 04:57 PM | #123 |
Rep 15
I completely agree. Having observed many pre-LCI and post LCI vehichles during last year, I find pre-LCI more to my liking. Beauty is always in the eye of beholder, but I think they fit the car better. Car has definitely more presence compared to halogen-only versions. I also replaced all the halogen bulbs with their LED counterparts, small but worthy investment. |
01-18-2024, 06:11 AM | #124 | |
181
Rep 595
01-19-2024, 01:04 AM | #125 | |
Rep 16
To be clear on this, you changed the 44 values in the expert mode section "Landmapping 3 and 4" of Bimmercode. Correct? This seems doable to me. The only difference is that my outer rear Leds did not work after connecting the extra wires to the BCD and putting daylight on in Bimmercode. I drove the car outside the garage and checked all positions of the light switch in the dashboard. I'm sure the led units are ok since I tested both with a battery. Can it be that this will be solved with the coding stated above? Of is there something else going wrong? |
01-19-2024, 03:53 AM | #126 | |
181
Rep 595
I would suggest to do like inlinesix, note down the current values systemmatically so you have a backup and then change those to the ones he changed. See the attached pdf of post #119 |
01-19-2024, 05:54 AM | #127 | |
Rep 16
01-19-2024, 07:44 AM | #128 | |
Rep 15
Hello MichielX1, Yes, I changed those 44 values in Expert mode of Bimmercode. It took me just 10 minutes, since new values are already available for selection from a menu, there is no need to write everything manually. Earlier in this topic you can see screenshots from "simple mode" of Bimmercode that I checked when installing the lights a few months ago. It is possible that you have not selected all of them and therefore your outer LED stripes do not work when DRL's are active (presuming that your wiring is OK), but this is not really important right now. As MrPingu said, leave some time for proper preparation. Take a laptop in the car, go into Expert mode and write your existing values in a spreadsheet, so you have reference values if something goes wrong. You can use .pdf's that I provided above to create your spreadsheet. Make sure your car battery and phone battery are full, so not to interrupt coding process. Be careful to enter proper values, no need to hurry. Remember a timestamp for Bimmercode created backup. And that should be it. You can report back here when you're done, I'd be eager to know if it worked for you too. Fingers crossed, you'll definitely enjoy them when you finally manage to make everything work as it should. Looking back with knowledge that I have now, complete process should take not more than couple of hours. But it took me 6 months. And without help from this forum, I would be unable to do it. |
01-19-2024, 03:38 PM | #129 | |
Rep 16
01-27-2024, 09:18 AM | #130 |
Rep 16
Bingo! The Leds work now. Thanks to your instructions and support! Especially mrpingu, inlinesix85 and thenine90. The coding was quite straightforward, thanks to the schedule. Still strange that the outer leds did not work after coding the daylights on, like in the other converted cars did.
It's been a great help. Looks much better. And all other lights at the back work as well. Happy camper over here. I love Bimmerpost! Last edited by MichielX1; 01-28-2024 at 04:15 AM.. |
01-28-2024, 04:13 AM | #131 |
Rep 16
Little afterburner: the back Led lights work now constantly so also during daytime with the lightswitch on 12 o'clock. This is probably the consequence of the conversion. Or is it possible to only have the front lights working during daytime (like it used to be)?
If not, no problem. But can be better for the lifespan of the back lights. These can stop working I read after some years. |
01-28-2024, 06:54 AM | #132 | |
181
Rep 595
Good to hear you solved everything That’s another coding. Check your settings in Bimmercode easy mode under ‘Daytime Running Light’. It might be that these settings are on active now. Well, funny that you mention it. Mine has started flickering and took the taillight quickly out today and had a look. After a quick look and some test I came to the conclusion it is not the LED strips that fail but the PCB inside them. The only thing is that to get completely to the PCB you have to separate the lens / cover from the assembly. I didn’t want to do that today so I will try to buy second hand inner taillight and when I have to time I will fix up the PCB as probably it’s the same problem as on the X3’s: https://www.ledsupply.com/blog/commo...ail-light-fix/ |
