12-06-2021, 12:21 PM | #68 |
266
Rep 649
Minimum vs. Recommended. If you want to put a 225 tire, you certainly don't need an 8.5" wheel, so he could have saved a couple of bucks.
In my head, Tire Rack should have said something like this: Minimum: 225 Recommended: 235 or 245 Maximum: 255 But anyway, I'm just sharing my thoughts.
2023 X3 m40i Brooklyn Grey
Reefy38.00 |
12-16-2021, 06:04 PM | #69 |
266
Rep 649
12-17-2021, 02:33 PM | #71 | |
266
Rep 649
One final comment, keep in mind that wider tires and bigger wheels will negatively impact the acceleration. That was one of the downsides with mine, even considering I have an ECU tune (270hp+). Don't get me wrong, the good things overpass the bad things. But it's something to consider.
Reefy38.00 |
11-24-2023, 03:11 PM | #73 |
66
Rep 121
Drives: 2017 X1 xDrive28i
12-18-2023, 11:10 AM | #76 |
266
Rep 649
Looking good!
But it definitely needs lowering springs =). Did you buy the Bilstein B12 combo?
12-18-2023, 12:02 PM | #77 |
66
Rep 121
04-11-2024, 04:11 AM | #81 |
182
Rep 596
How did you put these on? AFAIK 611m is only released as 5x120 bolt pattern and our F48 have 5x112
04-16-2024, 03:11 PM | #82 | |
Rep 55
I had a question, I wanted to paint the ferric grey part of my 566 style wheels (black in color) to make them stand out more easily but Im not sure what kind of paint can I use. Something that is not a spray-can as I only want to highlight/cover the ferric grey parts not the entire wheel (check attachment - photoshopped for end state look) Can the likes of Rustoleum outdoor paint help? do I need to sand, primer, paint and apply clear coat again? I wanted something like a quick fix not an elaborate process |
04-16-2024, 08:06 PM | #83 | |
266
Rep 649
04-17-2024, 08:09 AM | #84 | |
182
Rep 596
04-18-2024, 10:50 AM | #85 |
Rep 55
I will avoid pressure washing. How long would it last? Also since I want the plastidip to cover only the ferric grey portions whats the best way to do that? Assuming plastic dip comes in spray mode only. It's going to be very difficult to mask all the diamond cut / shining silver piece only
04-18-2024, 12:22 PM | #86 | |
182
Rep 596
04-18-2024, 12:43 PM | #87 | |
266
Rep 649
PlastiDip comes in a spray. Masking tape plus some paper will be good enough. You can find instructions on how to apply it on YouTube. You will need to make several passes until it covers completely. If you want it to be glossy, you then have to apply a PlastiDip clear coat.
