BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Any Tool32 Experts?????
      03-14-2024, 05:47 AM   #1
davetcollection
Drives: BMW X2 18d S Drive
Hi,
I'm trying to do the DIY Carplay activation.
I have found and changed the VIN in the HU, using E-sys to one from a 2020 F39 with S6CP
But as I go in to Tool32 to do the provisioning Tool32 is not talking to the car.
Can anyone offer any advice on Tool32 connection settings with E-net?
TIA
I have also posted this in F39 Forum
      03-14-2024, 06:10 AM   #2
mrpingu
181
Originally Posted by davetcollection View Post
Hi,
TIA
Did you run Tool32 with compatility settings on? Without running it in WinXP or Win7 (don't remember) it is unstable.
Retrofits done: 2TB, 235, 313, 430, 459, 508, 5DP 322
      03-14-2024, 06:24 AM   #3
davetcollection
Thanks, yes I have ran in compatibility mode
      03-14-2024, 06:55 AM   #4
mrpingu
181
Ok, thats's good. All other things are correct aswell? internet adapters, firewall ETc? You get a VIN in e-sys and/or ISTA?
Disable any non-used network adapters in device manager, these can ruin things for tool32.
Edit: You can also get EasyConnect from here;
, see link to software pack in description, using easy connect you can setup tool32/EDIABAS easier.
      03-14-2024, 07:17 AM   #5
davetcollection
Firewall off, all other networks disabled. I get the message IFH-0018 initialization error message when I try to select enaevo.prg in Tool32.
I don't have connection manager so thanks for link, will try that
      03-14-2024, 07:54 AM   #6
mrpingu
181
Try EasyConnect, if that doesn't work post your EDIABAS.ini here.
Pretty sure it is wrongly configured connection settings.
      03-14-2024, 08:05 AM   #7
davetcollection
Will do thanks
      03-14-2024, 08:10 AM   #8
davetcollection
And, yes, sorry, connects and codes with E-Sys with no problems
I have coded new VIN to HU and coded mirrors to fold on lock instead of 3 second delay
      03-14-2024, 10:16 AM   #9
mrpingu
181
Definitly some issue / misconfiguration witht he connection. E-sys probably picks up the right ethernet adapter / IP-adress while tool32 doesn't.
You could read out IP-adress from E-sys, then use it to configure EDIABAS to force it to connect to 1 specific IP.
