04-18-2024, 06:39 AM | #1 |
40
Rep 37
Drives: BMW 1 series 125i
Anyone painted M35i OEM wheels black?
Has anyone painted the OEM 20 inch wheels black on a x2 M35i? I saw one post with Plastidip but was hard to see.
Keen to see some photos, the attached photo is my car with factory wheels |
04-18-2024, 04:50 PM | #2 |
191
Rep 635
04-19-2024, 01:19 AM | #3 |
40
Rep 37
04-19-2024, 12:41 PM | #4 |
303
Rep 1,087
I'm pretty sure some models had them OEM black which was pretty cool I have the 19's and was thinking of doing a change of color as they'll eventually be rotated to winter tire duty by next season.
04-21-2024, 09:10 AM | #5 |
191
Rep 635
Maybe just try to plastidip them? I mean if you don’t like it you can remove it again.
I did with my winter wheels 1 season and know I am convinced I will let them powder coat after next winter. |
04-28-2024, 03:37 AM | #6 |
29
Rep 52
Drives: BMW X2 M35i F39
Search for senja.f39 on Instagram. He had his resprayed black last year.
(He’s on here as havenzhiv but hasn’t posted updated pics as far as I know) |
05-01-2024, 01:52 PM | #7 |
29
Rep 52
And one in Mineral Grey from Autotrader for comparison.
05-02-2024, 06:29 AM | #9 |
40
Rep 37
Thanks guys, exactly what I asked for. Now I just need to decide to change the colour or change the wheels
05-03-2024, 10:55 AM | #11 |
191
Rep 635
05-03-2024, 11:49 AM | #12 |
2036
Rep 2,815
Drives: F33 430 and F39 M35i
Looks nice. Wonder if I should get mine done before my next tire purchase. It'd be nice to clean up all the curb rash from my daughter who's no longer allowed to drive my car. lol
05-03-2024, 12:55 PM | #13 |
303
Rep 1,087
Haha.. you know what? The beauty of the plastidip is that it slowly fills up those blemishes.. so you could just hit it with some sandpaper to get the initial texture down and plastidip it over it. Honestly it is easier to do the plastidip after the tires are on so that the poor tire guy doesn't have to worry about scuffing the plastidip off.
This is the third time I have done plastidip on wheels and the first time I ordered the "kit" and followed all the rules. I don't like that method, as I'm sure I screwed that up... Here's my tips: 1) it's way easier to deal with overspray by simply using some fat painters tape and taping off the rubber to the wheels vs rubbing the "anti stick" stuff on the tires which I did.. it helped, but it wasn't that great. 2)when they tell you to start with dusting coats.. this is really important, I basically kept on dusting the wheels as my thick coats I tended to get a little bit of running. Easily remedied by the next round to go lighter on the running areas. 3) It really is better/easier to prop the wheels up against the wall (and I used a tarp with some large cardboard). I had done a set of wheels on the ground and although it also came out pretty good.. not as well as the 45 degree angle for sure. I also only used barely 2 out of the 5 cans that I was supplied. I know that if I layed the outer edge way more thick on the overspray it would have been easier to take off.. but that's a whack ton of paint and purposely overspraying it! If you're going flat black you can go to home depot and the paint is really cheap. This brass monkey stuff is like 3X more expensive. You can also apply the "glossifier" and other things to the classic plastidip, but you CANNOT use those with these specialty hyperdip paints for the wheels. Oh .. and a $10 paint gun attachment is definitely great. I've had these little plastic things kicking around forever and it helps when you're doing so much spray can painting. |
chowser512035.50 |
05-04-2024, 02:50 PM | #14 |
2036
Rep 2,815
i will buy the paint attachment. i have dipped before. for my daughter's car I stuffed old playing cards around the rim to be my tape. lol.
rice_rocket88303.00 |
