BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Wiring OEM Reverse Camera Help - F48
      10-10-2023, 03:25 PM   #23
NemoNeil
Drives: BMW X1
Originally Posted by mrpingu View Post
No that is normal on x1, only read ECU works.
I managed to add 3AG to VO and coded HU_ENTRYNAV and PMA2
still no cam display.
I checked FDL for CAM_ECU and still not present
Should i be doing something else?
Also should i see ICAM module when i read ECU?
Thanks
      10-10-2023, 05:04 PM   #24
mrpingu
Norway
194
Thanks
Hmm but you did press code on headunit ECU and PMA?
No only written modified FA to the car?
There is a difference between coding the affected ECUs and writing FA to the car. Just to be sure
Yes, you should see ICAM but this can take at your car needs to sleep before it is powered on. Had that once, VO coded every affected module but wouldn’t power up the new ECU. Only after car had been in sleep.
      10-11-2023, 06:50 AM   #25
NemoNeil
Drives: BMW X1
^^ Yes on both pressed code
^^ Believe i did... now when i press read VO, i get 3AG as per screenshot
^^ Under VCM this is where i "write FA FP"
tested again and still no joy...
i dont get why i dont see "CAM_ECU" in HU Module and no ICAM module??
fuses i checked all good.
traced wiring pins all good.
If camera wasnt working.... i should still see the display trying to view the camera, but instead i get usual PDC image of my car in the middle...
      10-11-2023, 08:40 AM   #26
mrpingu
Norway
194
Did you try to press the video-icon with r on the left, what happens then?
If that doesn't work
Can you post a screenshot of TAL calculation?
Go to Comfort Mode => TAL-Calculating
- Read and Save FA
- Activate FA
- Read and Save SVT Actual as SVT_ist
- Create an SVT Target
Under KIS/SVT Target Calculation Strategy, select Complete Flash
Select I-Step (shipm.) to match your original I-Level as read and shown in VCM I-Step (Shipment)
I-Step (target.) will be unselectable as it is fixed based on current PSdZData I-Level
Do a KIS/SVT Target Calculation and Save as SVT_soll
- Do a TAL Calculation and Save as SVT_tal
Edit:
1) And try to install ISTA and see if you get any errors on the ECU tree.
2) Did you also check with multimeter if you are getting 12V between Ground & camera ECU?
3) You are sure that you are plugged into CAN3 / R3?
      10-11-2023, 09:08 AM   #27
NemoNeil
Drives: BMW X1
- Read and Save FA
- Activate FA
Edit:
Screen Shot of SVT calculation and Tal Calculation i can pvt the file
I checked power pin 4 from fuse to camera and getting power.
Ista shows the attached. i never had TRSVC before coding 3ag. also the PMA started showing orange after i done this project... although all parking sensors wrking and no errors on dash
thanks bud
      10-11-2023, 09:37 AM   #28
mrpingu
Norway
194
thanks bud
You sure you are not missing any wire at any place?
TRSVC is camera.
Seems ICAM is not found that means it cannot be reached on the canbus3. So either the camera is not compatible or the canbus is not wired up corrrectly or the ecu is getting no power /turning on. Probably wire is not in place or wring pin somewhere. You should get ICAM up in esys to code after coding PMA & HU.
You can doulbe check partnumber of camera seems like over at the mini forum someone had similiar problem
https://www.minif56.com/threads/help...reply_top_post
      10-11-2023, 10:01 AM   #29
NemoNeil
Drives: BMW X1
TRSVC is camera.
Thanks... only wiring i can think off is that from BDC and R3 dont really match up
BDC pin 43 & 44 (note the order)
R3 PIN 16 & 3 (note the order)
as per pic earlier in thread... you can see blue and green wires are on different pins...
otherthen this, let me check HU wiring again...
Also no break in wiring to and from R3 and camera
appreciate help
      10-11-2023, 10:51 AM   #30
NemoNeil
Drives: BMW X1
appreciate help
Checked wiring to and from R3 and camera, no breaks..
Camera part number is 9475687 - seems to be compatible..
wiring on canbus r3 is
R3 pin 22 & 9
C* pin 7 - yellow
C* pin 8 Yellow\white
need to find long wire to test BDC to R3.. this is only one putting me off..
also found on one of the forum for HU wiring:
Nbt uses 21, 23 24.
Cic high uses 18, 27, 28
Tried the above and still failed to see anything.
stumpppeeddd....
      10-11-2023, 11:40 AM   #31
mrpingu
Norway
194
I don’t know to do either.
Start with canbus debugging, if it’s not connected to headunit then it should only miss video but if canbus is missing / wrong then you don’t get any communication at all.
Just check all the wires from BDC to R3 and from R3 to camera. According the diagram ignore colors, focus on the pins.
But also check if you have not mixed up R3 with R2.
      10-11-2023, 12:00 PM   #32
NemoNeil
Drives: BMW X1
And just like that, hey Presto......
What a bloody nightmare. Was the R3 to cam wiring. Swapped them around and working straight away. Dont understand the pins were match as per diagram.
Spent days and days troubleshooting. But got there.
I can't thank you enough and for your patient. I owe you a drink
Thanks a million.
Appreciate 2
mrpingu193.50
678hug11.50
      10-12-2023, 01:51 AM   #33
mrpingu
Norway
194
Thanks a million.
You are welcome, glad you sorted it out
      04-25-2024, 06:42 AM   #34
C_B_L
Drives: BMW X1, 1 Series
Hello guy,
I am trying to retrofit my X1 F48 with rear camera same way as you did.
Was that big pain in the ass?
How was coding like?
I code only with bimmercode until now.
Thanks for answering me
      04-26-2024, 02:47 AM   #35
mrpingu
Norway
194
Originally Posted by C_B_L View Post
Hello guy,
Coding is recommend to VO-code and thus use E-sys. I say so because VO-coding ensures that if you reset all values the camera will keep functioning.
I am not sure if BimmerCode has access to the PMA / PDC module, but if it does then you can use Bimmercode expert mode to code the values from post 18.
If I have to guess one PITA for this retrofit, its is routing the cable through the lid. Otherwise I would say it's pretty straight forward.
Retrofits done: 2TB, 235, 313, 430, 459, 508, 5DP 322
      04-26-2024, 01:25 PM   #36
C_B_L
Unfortunately,I don’t have an R3 connector but there are blue and green wires on pin 43 and 44. Is there a way to connect a4 and a5 wires directly to this green and blue wires without putting R3*1B connector(wire A4 to F3 and A5 to F4)? I mean what does this ground wire F2 from F cable from manual used for?
