01-07-2024, 10:33 AM | #749 |
Rep 4
hi all, i'm new to coding. i'm getting the psdz error 433, when tried to read the SVT. any work around please?
i have the 2019 F48 Last edited by Ronnyt27; 01-08-2024 at 02:11 AM.. |
01-08-2024, 06:04 AM | #750 |
189
Rep 631
Use "read ECU" on BMW x1 F48 using F056 profile
01-08-2024, 09:15 AM | #752 | |
189
Rep 631
Do you have any errors or symptoms and what are you trying to do? |
04-26-2024, 03:30 AM | #753 |
Rep 62
Hi, back to some coding learning after some time. Still trying to figure out coding 2VB for RDC. Wanna ask your existing value for BDC body is same as mine ?
04-26-2024, 04:11 AM | #755 |
Rep 62
Yes already compared and coded all the values but just trying out if I missed something. Just went to workshop they checked all my sensors were active. But it still stopped at 49%
04-26-2024, 05:29 AM | #756 |
189
Rep 631
Which ECUs did you code? Need to code HU, DSC, BDC and KOMBI. Did you write VO to the car?
04-26-2024, 07:51 AM | #757 |
Rep 62
Saved the 2VB option and carried out the fdl coding.
I’ve actually tried 2 methods. The smart code on BU itself. And then tried the NCD code from e-sys Of course the “old” and “new” are just vice versa |
04-27-2024, 10:04 AM | #758 |
Rep 62
I’m wondering if bmw only accepts certain ID on the tpms sensors? It would be easy if only I can register the 4 IDs into receiver module lol.
04-27-2024, 11:54 AM | #759 | |
57
Rep 154
Drives: 2018, F48 28i
I just added 2VB option using Esys by using the VO coding method. Right after adding 2VB I drove around for about 20 minutes and everything showed up. I just bought 4 TPMS from AliExpress for total 51C$ and have them installed. Nothing had to be done. They lasted about 3 years. |
limsheng3.00 |
04-27-2024, 07:42 PM | #760 | |
Rep 62
Came back from re setting the 2VB. Still stucked at 49% Thinking of getting smartphone NFC coded TPMS sensors I saw on AliExpress. https://www.aliexpress.com/item/1005...k=in_edm_other Last edited by limsheng; 04-27-2024 at 10:38 PM.. |
04-28-2024, 09:02 AM | #761 |
Rep 62
From E-sys to ISTA. Found a way to check on the RDC by deflating tyres and inflating back. Well at least I know my rear left sensor is defective. Now to call up seller if they would replace one for me lol.
