06-13-2014, 04:46 AM | #1 |
13
Rep 113
Another fitment thread? Yeah sorry guys
Hi all
So I pick up my 09 135i in 14days it has the performance pack wheels & I won't lie I don't enjoy the look of the in the least.. I've been looking at vmr's which the et50 on the rear I know is best but alas these wheels have taken my eye Koya sf01 semi forged http://www.koya.com.au/?cars=sf01-18...ged-custom-fit My question is with the performance pack suspension kit can I get away with: 18x8 +43 fronts 18x9 +42 rears I know this is 8mm of of the oem area I'm coming from having owned a jz80 supra & my current 2 e30's so this higher offset stuff is a new language to me, many many thanks in advance Cheers Ant Last edited by Anthony B; 06-13-2014 at 06:38 AM.. |
06-13-2014, 05:24 AM | #2 |
Rep 166
fronts will be fine.
Rears may require a small fender roll. I run ET42 in the rear, with a 9" rim Last edited by N88888_dawg; 06-16-2014 at 04:09 PM.. |
06-13-2014, 06:34 AM | #3 |
13
Rep 113
Sweet, I have no drama with having the guards rolled to fit.
Not sure if it's sad to be ordering wheels before I pick my car up lol. Next to get some decent tread sorted out for them |
06-13-2014, 06:56 AM | #4 | |
326
Rep 914
I ran 12mm spacers on my Style 261 wheels and they rubbed over bumps (I was also lowered). So you will most likely just need to roll the fenders |
06-13-2014, 07:21 AM | #5 | |
Rep 166
I ended up buying a set of spacers to fit my rota GTR drifts to a 3 series I was meant to be buying. The sale fell through and I got a 1er instead |
06-13-2014, 08:50 AM | #6 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Tire size and brand will make a difference but I think the magic number for et42 is 8.5" if you're looking to go with a 255 rear. Anything wider and it'll probably rub slightly so a small fender roll is in order. Obviously a tire with more square shoulders will rub more.
06-13-2014, 11:47 PM | #7 | |
13
Rep 113
Oh its definitely mine, deposit is down & flights are booked picking it up from a BMW dealership in 11days. Ill be ordering the wheels once the concrete is set on Monday provided my property settles all ok. I'll suss out tires to fit was looking at F: 225/40/18 R: 255/35/18 |
06-14-2014, 01:25 AM | #8 |
1024
Rep 1,264
I run 18x8" ET35 with 215/40/18 and 18x9" ET40 with 245/35/18. Lowered on Eibach Pro-Kit and it rarely ever rubs. Even when it does, it's ever so slightly.
750whp 135i Build | Budget 335i Build | F80 M3 Build
🎬 YouTube channel (35K+ subs): youtube.com/jakespence135 📷 Follow me on Instagram: instagram.com/jakespence 🏁 Shop BMW merchandise: bimmerstreet.com |
06-14-2014, 07:48 AM | #9 |
126
Rep 3,099
hmm well ET45 9.5" + a bit of low on mine, with 245's scrubs pretty badly on bumps, especially with a passenger
the 135i has 10mm further out, so ET55 9.5" would have the same fitment 9" is like dropping 6.35mm off the offset, so a +42 9" on a 135i is like a hm +48 offset 9.5" if you plan on staying at stock height.. well it's not perfect, you'll have to fit narrower tires than optimal. if you plan on lowering.. not so good at all, even with a roll. you'll have tons of fender>tyre clearance - where these cars rub is the rear bumper>body mount. |
06-15-2014, 07:43 PM | #10 |
13
Rep 113
On willitfit.com, apparently the rear will sit 16.7mm further out. I think I'll wait till I have the car & measure the space on the oem setup between the tire & the rear guards,
06-16-2014, 02:50 PM | #11 |
General
2042
Rep 25,989
That sizing shouldn't be much of an issue at all. They only stick out 2mm further than our V710s, V701s, and V718s. We make our V810 in a higher rear offset for the 1-series though, so that you can run wider tires.
Best of luck, OP!
VMR|Wheels | 714.442.7916 |
06-17-2014, 03:37 AM | #12 | |
13
Rep 113
Finalized the purchase with the bmw dealership about an hour ago. Just waiting on the flight details they've booked for me. Will get a lovely 461km drive home to learn the car Thursday next week |
06-17-2014, 12:43 PM | #13 |
General
2042
Rep 25,989
07-09-2014, 04:37 PM | #14 |
13
Rep 113
So wheels are on, verdict:
+43 Front no scrub with 225/40r18, actually wish I'd gone a lover offset to bring the wheel slightly more. +42 Rear slight scrub on big bumps 255/35r18, car is on BMW performance suspension & no other modifications. Will be getting a slight roll & pull, some of the scrub will be sorted when I get m3 subframe & trailing arms fitted to remove some of the rear play of the oem bushes |
07-09-2014, 05:24 PM | #15 |
Rep 166
Looks good buddy!
