06-11-2014, 03:02 PM | #1 |
Rep 112
Drives: 2011 135I ManTransmission
How difficult to fit?
I found a set of Linea Corse BBS Reps locally and I was wondering if they would fit my 1er. Specs are as follows:
19x10 et37 19x8.5et30 Sorry for the NOOB question. Thanks for any insight. |
06-11-2014, 04:04 PM | #2 |
24
Rep 387
Offsets in general are a bit on the low side....
The front should be alright....especially when you dial in camber The rear....might be a little hard with the offset for a x10'' width... But if you stretch tires + camber + roll or pull....almost anything is possible lol |
06-12-2014, 10:47 AM | #3 |
206
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
If you want a straight bolt on setup then this is not it. Like the post above me said it will take some major work. If you want a straight bolt 19 inch staggered setup go with a 19x8.5 40-45 offsets and a 19x9.5 50-60 offset.
06-12-2014, 10:56 AM | #4 | |
326
Rep 914
@addict ran 18x10 +40 CCW LM-5s on his car with only a roll and he was on ST coilovers and then switched to bags. You will need to add some camber, but it would be within spec unless you want some poke. |
06-12-2014, 12:53 PM | #5 |
General
2040
Rep 25,989
Definitely not a bolt on, straight forward/no rub fitment.
VMR|Wheels | 714.442.7916 |
06-12-2014, 12:56 PM | #6 |
32
Rep 919
The rear is going to require around 2.5 degrees of camber. You're also going to need fender work.
The fronts are going to fit when the wheel is straight, however they are going to rub like hell when you're turning. You'd basically be guaranteed to have to pull the front fenders and do some trimwork in the wheel well. You'll also have to dial that camber out pretty hard and throw some 215's on there. It's doable, but understand that you're REALLY compromising on ride quality and you will 100% have to modify the fenders and camber to make these wheels fit. |
06-12-2014, 01:34 PM | #7 |
Rep 112
Thanks for all the input. I'm not going to sacrifice ride quality for looks. It appears the cost savings of buying this set will be out weighed by getting them to fit. Ill just keep looking for a better option. Thanks again
