06-08-2014, 06:49 PM | #1 |
28
Rep 129
Fronts don't quite fit, options?
Today I mounted RGRs from my e36 and the fronts don't quite fit. What options might I have? The fronts are 18 x 8, 35mm offset - currently on 235/40 tire.
When I put them on, the tire was pretty close to the shock but definitely clear. It would rotate freely while off the ground. When I took it out for a slow drive there was a tiny, but definitive vibration which sure felt like something very minor rubbing, but upon taking the wheel off again I could find no signs of rubbing anywhere. That aside, it most certainly is rubbing badly on the outside edge of the tire over bigger bumps. Below are some pictures of the fitment, and you can see the white marks on the outside edge from the rubbing. What options might I have here? Would dropping to a 225 size tire definitely solve the issue? What about camber plates (and while still under factory warranty)? I'd really love to make these work because they look fantastic, and if I can't get it to work then I'll be forced to buy a new set of wheels ($$) because of current circumstances. Any help would be tremendously appreciated!! Fitment (and tire scuffs after first pic): Overall look, |
06-08-2014, 07:31 PM | #2 |
456
Rep 6,478
That's rough if you are rubbing like that at stock ride height. Space to the fender up front is a bad joke.
Not many options here...Drop down width in the tire but even then...that's a lot of poke to begin with.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
06-08-2014, 07:58 PM | #3 |
10
Rep 133
225 would not be a problem. OEM is a 215 on a 7.5 so a 225 on an 8 inch wide wheel will work fine. You may even want to try 215 on the 18x8. Your rims aren't going to be rubbing the strut at 35et. Add 1-1.5 degree of negative camber and you won't have to worry about any fender rolling.
06-08-2014, 10:33 PM | #4 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Many run wheels of that dimension on our cars. They add a little camber if they want to run slightly stretched tires. They add more camber if they want to run wider tires.
Pull the pins and maybe try some of the twist in spring separators they sell at Autozone for now until you get a chance to do more.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
06-08-2014, 11:58 PM | #5 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Run 225's and add some camber up front.
06-09-2014, 10:31 AM | #6 |
827
Rep 3,856
Perhaps with a little more camber they will fit? A set of Ground Control or other quality brand camber plates will run you ~$400. It's not like that money is "wasted" if that doesn't do the trick.
06-09-2014, 10:35 AM | #7 |
460
Rep 4,531
I run a 17x8.5 ET40 w/a 5mm Spacer (so ET35) with a 245/40 Dunlop ZII Tire.
I have -3.6* Camber and lowered around 1.5". I have no problems with front fitment. I do rub on sudden bumps during autocrossing under high compression |
06-09-2014, 02:46 PM | #8 |
General
2042
Rep 25,989
VMR|Wheels | 714.442.7916 |
06-09-2014, 06:56 PM | #9 |
California-bound
385
Rep 1,480
You need camber. The Dinan plates by themselves should be enough to get that particular setup to fit. If you want to go wider in the future, pick up some Vorshlag plates, and get ready to roll fenders.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
06-11-2014, 01:33 AM | #11 |
175
Rep 1,491
Just do the camber plates and roll the fender a little bit. No need to spend more money on two new tires lol
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
06-11-2014, 01:36 AM | #12 |
175
Rep 1,491
This my front 225 tire. Et38. I rub too on harsh compression on the track but that's about it and it's not that bad, that's with no camber plate or pin pulled and no fender rolling. The car is lowered too. So you getting the camber plates and rolling a little bit you should be fine man.
06-11-2014, 01:38 AM | #13 |
175
Rep 1,491
06-11-2014, 02:10 PM | #14 | |
28
Rep 129
What is a reasonable time (hours) to have a shop install the camber plates? 4 hours? |
06-11-2014, 03:57 PM | #16 | |
175
Rep 1,491
