06-05-2014, 10:19 PM | #1 |
518
Rep 788
Dunlop Direzza ZII Cold Tire Pressure
I'll be doing my first track day on a brand new set of ZIIs this Saturday. Weather looks to have a high in the mid 60s and overcast skies. On a stock M-Sport suspension, is there a good starting cold tire pressure? I was thinking starting at 36 all around (225 front/255 rear) unless there are other suggestions.
06-05-2014, 11:28 PM | #2 |
157
Rep 1,409
I just installed a 255/35R18 square set of brand new ZII's on my 135i this week, and did one lapping session with them so far.
The stiffer sidewall tires felt really nice and precise on the track (better than my previous set of RE-11's), but were a bit slippery because of the cold weather, slight drizzle, and new tires needing mold release lubricant to wear off... I started with 32 PSI warm pressure, and hot pressure reached 38PSI. I took some measurement with a laser pyrometer, and noticed the middle of the tire getting hotter, which means pressure was too high. Will keep monitoring and adjusting tire pressure on next lapping events, until I find a sweet spot. Also getting a new alignment done tomorrow.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
06-06-2014, 10:32 AM | #3 | |
518
Rep 788
06-06-2014, 11:45 AM | #4 |
47
Rep 327
Drives: 2012 BMW 135i
I run ZIIs on stock M-Sport suspension in the same sizes. I typically start the day dropping the pressures a couple pounds from the factory specs, so 34 front, 37 rear. As the day warms up, I'll usually drop them another pound or two. If it starts to cool again, like in the winter, I start adding pressure back in for the last session or two.
The main thing to pay attention to for your pressures is your sidewall rollover. The ZIIs have a nice little arrow on the sidewall. You don't want your wear to move past the tip of that arrow. If you do, add pressure. If you aren't to the arrow, lower pressure. Also remember that changing 1 psi cold is more than 1 psi hot, so your adjustments will vary based on when you do them (first thing in the morning, or right after a session). Since us stock suspension guys can only get about .5 degrees of camber, we can't drop the pressures as much as might be ideal without rolling over too much. dcaron, your camber settings are a long way away from stock m-sport, and laser pyrometers are unreliable at best. I wouldn't use the data from that personally, because even if you come right off a flying lap into the hot pits to measure, the surface temp of the tires will already have cooled and cooled unevenly (the outer tread gets more air and cools faster). You're readings will also be highly impacted by whatever kind of corners lead up to the hot pits. A needle-pyrometer is a much better way to go, although still hard to get true tire temps from due to cooling. My two cents...
2012 BMW 135i DCT - M3 Front Control Arms, Whiteline RSFB, Dinan camber plates.
06-06-2014, 11:57 AM | #5 | |
518
Rep 788
I've been racing sportbikes in middleweight/lightweight for the last 5 years and am now just starting to get into cars. I am actually somewhat surprised that the price per tire is relatively constant bike vs car. You just need four for a car... |
06-06-2014, 11:58 AM | #6 |
4338
Rep 6,196
Surface temps are pretty much meaningless, unless they are real time. You need a probe that gets close to the core rubber like rsxpilot said.
I use a Longacre similar to this: I have found the ZII's like to run about 40 PSI when hot. So, set them to about 32-34 cold, go out and do about 4-5 laps at speed, come in and bleed them down to 40. Later on you can let your tires fully cool down and you will know your starting cold pressure. Usually it is a different pressure for every tire, and will be different for every track. You can adjust that for conditions like the tire rolling over the edge and uneven temperatures, but that is a bandaid solution to poor suspension set up. Last edited by MightyMouseTech; 06-06-2014 at 12:05 PM.. |
06-06-2014, 12:03 PM | #7 |
47
Rep 327
Exactly what I use as well. Was like $100 on Amazon.
06-06-2014, 02:04 PM | #8 | |
157
Rep 1,409
Did not want to pay that much for a needle pyrometer (paid $30 for my laser pyro). I want an approximate temperature delta across the tread as sson as I come into the pits, for a general idea of my under/over inflation, and camber and toe adjustment impacts. I realize that this is far from the optimal method but still a valid indication ...
06-06-2014, 02:08 PM | #9 | |
157
Rep 1,409
06-06-2014, 02:50 PM | #10 | |
4338
Rep 6,196
06-06-2014, 04:01 PM | #11 |
157
Rep 1,409
Even if the temps do change, tires will still hold some heat, which should provide a pattern (area of the tire doing most work or under most strain), correct?
06-06-2014, 07:09 PM | #12 | |
18
Rep 442
Once you are comfortable with a standardised measuring technique and evaluation, you can correlate temperatures with treadware. At best, this will provide you with an early indication of alignment or tyre inflation. At worst, you have lost nothing. Your escalation in efforts will ultimately be rewarded - probably after several events - in technical expertise, in operating costs, in confidence yourself, and in respect from competitors (In fact, my initial concern three months ago was how you had worn the outside shoulders of RE-11 with approximately -3o camber. Unless you had an aggressive set up and extremely aggressive driving style, I would have thought this to be impossible.) |
06-07-2014, 06:44 AM | #13 | |||
157
Rep 1,409
After a short while, I noticed the accelerated wear on the outer edges of the front tires, and went for the first mod (breaking the strut tower alignment pins to gain minor negative camber). Did a bit of lapping, realized this modification was not enough, as my car still understeered and chewed up the exterior of my front tires. I ordered camber plates and front M3 control arms, and dialed up as much max negative camber as possible (about -3.2*). I finally equalized the wear pattern and reduced the understeer considerably. All of this time, I did my weekly lapping on a cement pavement (airport track) 10 minutes from where I live. Fast forward to this season (April 2014). Just got a Quaife LSD installed. I booked a 2.5 days intensive driver education event, (on an asphalt track), with my now worn RE-11 tires (at wear bars in the rear, and no tread left in the front). We did about 8 20-minutes session/day. I monitored and adjusted hot tire pressure to 34PSI, and was amazed at the good grip I was getting (asphalt and cement pavement are so different). My 135i felt neutral, with mild oversteer at turn out. The worn RE-11 were now acting like slicks. This was the best handling I had experienced with my 135i. I was now due for new tires, and decided to go wider in the front with a used rear set of stock RIMS ( style 261 18x8.5 ET52) + 10mm spacer thazt I got for very little money. I bought a 255/35R18 Dunlop Direzza ZII tire square setup and did one session at the local ICAR track (cement track). I loved the accuracy and communication of the ZII tires, probably due to the stiffer sidewall over the RE11's. Having said that, I found the brand new ZII tires to be a bit slippery and they squealed at the limit. Got to give them a chance to break in I suppose. Im not done yet with selecting ideal hot pressure, camber and toe settings, for optimal dual-duty wear and grip - this is "work in progress" as I adapt to the stiffer ZII's and 255/35R18 square setup.
06-07-2014, 11:15 AM | #15 |
460
Rep 4,531
The triangle is just is a starting point. You can wear past the triangle and it is perfectly fine.
My wear is about half way down the triangle on the front, and at the top of the tip in the rear. It is all dependent on how you like the feel of the car at a certain pressure |
06-07-2014, 11:51 AM | #16 | |
518
Rep 788
06-07-2014, 11:59 AM | #17 |
47
Rep 327
That looks spot on to me BGR. Kgolf is right, you can go a bit further, and a couple of mine have ended up about half way down the triangle, but if you are right there at the tip it gives you some margin for error.
06-07-2014, 12:07 PM | #18 |
Слава Украине!
2317
Rep 2,441
06-07-2014, 01:07 PM | #19 |
460
Rep 4,531
06-07-2014, 01:08 PM | #20 |
460
Rep 4,531
No, it is an indicator of where you should be rolling over your tires.
06-07-2014, 01:21 PM | #21 | |
Слава Украине!
2317
Rep 2,441
http://www.michelinman.com/tires-101...nd-damage.page |
06-07-2014, 02:17 PM | #22 | ||
460
Rep 4,531
