06-03-2014, 12:14 AM | #1 |
106
Rep 1,428
Is an impact too much torque?
I bought a cordless impact, that says 200ftlbs max. If I were to install my wheels would that be to much torque or will it be fine.
06-03-2014, 12:40 AM | #2 |
137
Rep 902
Over torquing could result in threading the studs and/or your lug nuts becoming loose.
I hate using the machine because it damages my lugs so I always hand torque mine |
06-03-2014, 06:41 AM | #4 |
Resident Tamed Racing Driver
298
Rep 4,697
Proper torque always matters.
If you become accustomed to your impact gun, you can run them up 95% of the way. I have a cordless one that I used that I can always nail 60ft/lbs with. It is just a simple case of doing that last 28 ft/lbs with the torque wrench after. |
06-03-2014, 06:56 AM | #5 |
4338
Rep 6,196
200 lb.ft is way too much! That will over stretch the bolts, putting them is plastic deformation. Over torquing the wheel nuts will damage the wheel bolts and the hubs and will cause warping of the brake rotors.
Spec is 88 lb.ft. Just get them snug and then hand torque. |
06-03-2014, 01:07 PM | #6 | |
General
2042
Rep 25,989
Honestly I wouldn't even bother using an impact gun on wheels at all, even if it's just to thread most of the bolt. It doesn't save you that much time, and you risk damaging some of your bolts or possibly the hub. I always recommend hand tightening them first, then using a torque wrench to properly torque the wheels down.
VMR|Wheels | 714.442.7916 |
06-03-2014, 01:11 PM | #7 | |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Plus aside from over-torquing you can easily scratch your wheels if you're not careful. |
06-03-2014, 02:01 PM | #8 |
4338
Rep 6,196
Personally I use an impact to snug up the wheels. But I use a torque limiting stick of 80 lb.ft. Put the car on the ground and final torque to 88 lb.ft.
They look like this: |
06-11-2014, 02:59 AM | #9 | |
38
Rep 701
06-11-2014, 08:34 AM | #11 |
Moderator
369
Rep 4,745
80-88lb ft for sure.
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum. |
06-11-2014, 11:56 AM | #12 |
827
Rep 3,856
That's way too much. I do 88lbs with a torque wrench. I use the impact drill to loosen them, and to speed up the process of hand tightening, but I Never torque it with the impact drill. Always with a prope torque wrench.
