05-31-2014, 07:00 PM | #1 |
28
Rep 129
Will these RGR's fit?
edit: see update in post #7
Would anyone be able to tell me if these BBS RGRs would fit my stock 135i? If they won't fit, would spacers be enough to correct (what size)? 18 x 8 front, 35mm offset - 235/40 tire 18 x 9 rear, 45mm offset - 255/35 tire Thanks for any info! Last edited by Cheeze1; 06-04-2014 at 06:26 PM.. |
05-31-2014, 07:13 PM | #2 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Should fit on the stock suspension as long as you don't rub the front strut. If it does a 5mm spacer should fix it, although then you might rub the fender on big bumps depending on tire brand. A spacer in the rear will just make things worse. It should fit but might rub with passengers over bumps depending on tire brand.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
05-31-2014, 07:58 PM | #4 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
35 offset with 235 in front seems pushing it
05-31-2014, 11:14 PM | #5 |
California-bound
385
Rep 1,480
With a 225 tire, it might just fit. However, without some additional negative camber up front, it's right on the edge of poking out.
Rears should be fine.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
06-01-2014, 10:16 AM | #6 |
BMW Enthusiast
106
Rep 1,034
Really depends on your tire. I run apex arc8 8.5x18 et38 up front with Bridgestone RE11 225/40/18 and it was rubbing the fender before I installed Dinan camber plates. You might not rub on street tire 225/40 since your wheel is 8x18 not 8.5x18 like mine
2011 JB E82 135i - Premium pack | Value pack | Premium sound | Sport pack | M-Sport steering wheel and suspension | Blackline LCI tail | BMWP carbon spoiler | BMWP CF license frame | BMWP gloss black grilles | Meisterschaft GT w/gloss black tips | CF diffuser | CF splitters | Hyper Black Apex Arc-8 w/Potenza RE-11 | Dinan camber plates
06-04-2014, 06:33 PM | #7 |
28
Rep 129
So this issue is going to be forced quicker than I would have hoped. One of my rears has picked up a nail and is not repairable. I can still drive it for now but it has a slow leak that isn't going to last. Consequently I am now in the market for an appropriate set of wheels/tires whether I like it or not.
I would really like to make the RGR's work instead of buying a whole new set of rims/tires. I could probably sort out a decent suspension for that price. Would a new suspension setup ensure the RGRs would work well? Wheel offsets and sizing is one area of knowledge I am sorely lacking in. I'd really like to be able to use a 235 up front and 255 rear. |
06-05-2014, 01:11 PM | #8 |
General
2040
Rep 25,989
I wouldn't run the 235/40/18 up front. 225/40/18 could probably work for you though.
VMR|Wheels | 714.442.7916 |
