05-28-2014, 09:59 PM | #1 |
67
Rep 501
Probably dumb question about bleeding brakes
I was planning on using a turkey baster or pump to remove the old brake fluid in the reservoir, but there's a screen blocking the entrance... how do you guys get rid of as much old fluid as possible before flushing with new fluid? Do you remove the screen somehow?
Also, I'm probably going to buy a Motive pressure bleeder to do the task. I have no compressor to run a vacuum bleeder. Any other tips/suggestions? |
05-28-2014, 10:29 PM | #2 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
Pull the screen out.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
05-28-2014, 11:13 PM | #4 |
1821
Rep 5,337
The screen is on a "cup" with 3 bumps that holds it to the lip of the reservoir. Remove the screen and you can remove most of the fluid in the reservoir with a syringe or turkey-baster.
I have the pressure bleeder from BavAuto and find the pressure release valve and the quick connect invaluable. I used to have a Motive and gave that to a friend after I bought the BavAuto bleeder.
06-04-2014, 08:35 PM | #7 |
1135
Rep 2,866
Drives: Anything
The ///M uses DOT4...not sure about non-M, but assuming would be the same. I did a complete bleed on all 4 corners plus clutch using less than 1L with plenty to spare.
06-04-2014, 11:56 PM | #8 |
My other car is on Mars
636
Rep 3,124
I divided up a liter, assuming a flush, as Hack points out below:
Reservoir 300 ml RR 200 ml LR 150 ml RF 150 ml LF 100 ml Clutch 100 ml Just rough guesses. Used Motul 600 and Speed Bleeders.
Warning: May contain traces of nuts.
06-05-2014, 12:01 AM | #9 | |
1821
Rep 5,337
Flush take about 1 liter.
