05-24-2014, 06:31 PM | #1 |
59
Rep 913
Would new rears help with traction?
05-24-2014, 08:21 PM | #3 |
340
Rep 1,293
My experience with PSSs is that the grip starts to fall off before the tread is completely spent. And once the grip goes, the tread wears out much faster, but that could be the result of the tire spinning more frequently.
05-24-2014, 08:59 PM | #4 |
59
Rep 913
Ya. I dunno. I can break traction pretty much at will 1st to 3rd. Even in 3rd I can do it without even 'trying'. Honestly it is frustrating. I just want to be able to put the power down and go.
05-24-2014, 09:19 PM | #5 |
66
Rep 1,267
Drives: AW 135i
PSS tires are not really the greatest imo. Not sure why everyone swears by them when there are better performing tires out there. To improve rear grip, you need a wider/taller tire with a lower air pressure. If you're running A 255/19, that could explain some of your troubles. A 265/35/18 would be much better size (note: I have no idea what tire you're actually running aside from 255s.)
Build thread: http://www.1addicts.com/forums/showthread.php?t=748935
05-25-2014, 09:45 AM | #6 | |
59
Rep 913
Will 265 fit without issue? What tire do you recommend? I know there are stickier tires out there, but thought the PSS offered the best performance/longevity combination. |
05-25-2014, 09:52 AM | #7 |
Rep 80
I too am interested in this. I know its terrible I am still on stock RFT (I don't have a big money tree in the yard so I am waiting till they need replacing (had 6mm front and new rears at CPO delivery).
Afaik(and I may be wrong), widest on stock wheels is 225 and 255....if wider will safely fit I imagine more people would do it and seems the most commonly praised setup is the 225/255 PSS. |
05-25-2014, 10:39 AM | #8 | |
340
Rep 1,293
Another point... I've noticed that PSSs don't really benefit from lower tire pressure. Yes this is counter intuitive, but I know my tires need a few PSI when I start to feel them slip. I'm not a tire engineer but think this has something to do with the shape of the side wall which tends to balloon a little more than most compatibly sized tires (especially if you go to an oversized tire). I suspect that keeping the tire pressure firm stretches the tire and maximizes the contact patch. In addition, the PSSs can get pretty greasy when they get overheated, and low tire pressure adds heat. Okay final thought... Running excessive negative camber on the rear will limit your straight line grip. Last edited by Pig Farmer; 05-25-2014 at 10:45 AM.. |
