05-19-2014, 10:08 PM | #1 |
617DRFT
Rep 39
Drives: 2008 135
Apex ARC *Fitment Questions
Hello i am sure this question has been asked a million times but has anyone ran flat style arc 8s in the front and concave or profile 1 in the rear?
also i am considering running 245/35/18 pilot supersports in the front with Bilstein PSS10 coilovers will this size fit without rubbing or do i need camber plates or wheel spacers? and then 265/35/18 in the rear Thanks |
05-21-2014, 09:36 AM | #2 |
58
Rep 321
I have that exact setup on the front of my car. I do have 1m suspension (non 1m car) and camber plates but it fits no problem (2.8* of camber. Doubtful a 245 will fit without). The rear works but you will need to do the 9.5 et 62 (non concave) wheel. I run a 10mm spacer in the rear just for the aesthetic.
05-21-2014, 09:42 AM | #3 |
460
Rep 4,531
I run 17x8.5 ET40 ARC8 squared.
Currently running -3.6* Camber, and have 245/40/17 Dunlop ZII Tires up front. Lowered on TCKline DA Suspension. Needed to run 5mm spacers to clear the shock and spring assembly. Cannot answer rear, because I'm running ET40 in the rear, not an actual "proper" offset |
05-28-2014, 09:50 AM | #4 |
39
Rep 257
I have swift springs, konis, dinan fixed plates and M3 bits. I run -2.5 camber with hancook RS3s on Apex ARC 8s. 235/255. Initially I ran a 3 mm spacer for extra strut clearance up front. However I would rub on inclined turns. Removing the 3mm spacer fixed the rubbing issue. In the rear there is plenty of room for 265s if I so choose
06-06-2014, 01:25 PM | #6 |
33
Rep 332
On a 235 front do you go with 35 or 40? 235/35/18 or 235/40/18?
2011 BMW 135i DCT M Sport, black sapphire metallic,Coral red tint, black line tail lights, back grils, BMW Performance spoiler, Apex ARC8, 235/265 Dunlop ZIIs, Ohlins coilovers w/ Swift springs, M3 front bits, Whiteline rear sub frame bushings, Vorshlag camber plates, Stoptech pads, stud conversion, spacers, bms intake
06-06-2014, 01:29 PM | #7 |
207
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
