05-23-2014, 05:52 AM | #10 |
117
Rep 1,998
128 part out (preview)
We'll guys. It's your lucky day.
Compiling list of all the parts that I took off my car when I turned it back in. BMW performance exhaust BMW performance intake BMW performance brakes ( yellow ones) Camber plates BMS power box F30 backing plates Spare caliper bolts Spare BMW backing plates for front pads when using aftermarket pads that click E93 front sway bar I'm in ny (11701) so some of this stuff is heavy and big. If local I'll deliver myself. If far ?????? I guess we'll figure something out if you really want it. I'll post pics and prices. Or make me an offer I can't refuse Pm me your email and what you want and we'll talk that way. First come first serve I guess. All stuff is used. 2 + years , calipers boots are perfect but bodies are scratched from 500 wheel removals lol. I have touch up paint. Exh has a small scoff on the bottom of tail pipe but can't be seen intake is perfect and I even have a new BMW filter. Regards Alex
X1, R58 JCW, M2 in my future if planets align
05-23-2014, 05:59 AM | #11 |
117
Rep 1,998
I may be able to help all of you ? See post
05-23-2014, 07:32 PM | #13 |
117
Rep 1,998
got all the pm's thank you.. sorting thru them now.. putting together pics and prices.. will get back too all shortly with answeres to questions and pics..
05-23-2014, 09:35 PM | #14 |
117
Rep 1,998
pics and prices
All prices are local pick up / cash payment. im in 11701 (L.I. New York )
other than some small stuff and maybe the intake, everything is big and heavy !!! Its Bucki's thread so i offered him the exhaust first, awaiting response. made other offer to local NJ member, awaiting response. All items sold as-is. no guarantees. Everything in working order. All items were on my car ( as per my sig) I tracked this car for 3 seasons .what a freakin blast!! BMW perf exhaust 400.00 ( MSRP was 695 + ship ) you will need new clamp from BMW. slight scuff under tail pipe trim that cant be seen . normal surface stuff of a 3yr old exhaust. sounded great BMW perf intake 475.00 ( MSRP was 730 + ship ) Near New ( what really could happen to it ) i have a 1 year old filter and a Brand new one in box as a bonus( 100+ value) looks great, sounded great BMS Power box 175.00 Shipped ( MSRP 279.00 ) Great little add on.. have install instructions. wonderful on street or track. Ground Control camber plates 225.00 shipped ( MSRP 349.00 + ship ) set my car to -2.5 and never touched it after that.. tire wear was negligible at this setting and made all the difference in the world at the track. BMW performance brake kit. ( this is part # 34110444772 ) This was a pair of yellow front calipers and a pair of stock looking rear calipers BUT the piston is bigger Front rotors are the drilled and slotted, rear rotors are stock. It comes with new backing plates for the front As noted, I tracked this car but protected my brakes with F30 backing plates Hard brakes TI Shims. and RBF /ATE brake fluid. The pistons seals are not cooked. I Bled and inspected theses brakes more times then i care to remember I could swap pads in 20 minutes a side HOT. You may need to have your car coded for performance brake upgrade. I NEVER had a brake pad / system/ failure or even fade. fastest time at Lime rock was a 1:06 base package 850.00 ( MSRP 1895.00) 2 front yellow Perf calipers w/8k old drilled slotted BMW rotors ( calipers are scratched to some extent see pics ) 2 stock rear calipers w/ larger pistons w/ 8k old stock rotors 2 oem front backing plates ( needed to fit bigger rotors) 1 frt brake pad sensor ( needed) ( reuse rear sensor ) 1 bottle phoenix yellow touch up paint i have a set of OEM front and rear pads (used ) Options ++ add to cost of base package listed above 1 set Modified F30 backing plates to fit 128 + 30.00 1 set NEW spare Brembo caliper bolts + 35.00 I had a set of TI brake shields, but for the life of me i only have 3, I looked everywhere for the 4th.. + 25.00 and you call hard brakes to get the 4th Make me offer on theses spare: Feroddo front pads worn...Noisey BUT freakin amazing on the track worn spare set BMW perf rotors ( i kept them for track emergency, but as noted, never needed them , have spare set of oem rears also 4 used hankook rs3's 225-45-17 maybe a couple of track days left.. or a bunch of autox-s BMW e93 front sway bar with brackets and bushings 125.00 dont have a pic.... but its a sway bar ?? we all know what it looks like .. 1 set NEW in box X1 Black performance grills ( 80.00 shipped ) got 2 sets for xmas for wifeys car. 1 set take off ( near new ) X1 chrome oem grills makes great garage art !!! 40.00 (shipped ) [/I][/U][/B]
