      05-08-2014, 10:44 AM   #1
BGR
518
Drives: C7 GS 7MT; e90 M3 6MT
Kosei K6R?
Anyone have any experience with these wheels? TireRack recommended them in a square 17x8 setup and said I could run PSS in 235/45 on them without rubbing or clearance issues on a stock 135i M-Sport. They are light and fairly inexpensive. Might be just what I'm looking for.
      05-08-2014, 11:43 AM   #2
Gary@TireRack
Moderator
Gary@TireRack's Avatar
369
Drives: Formerly 1995 M3
We have had very good experience and feedback with the Kosei line of wheels. They are very popular for light weight track and performance street wheels. I would expect similar results with the new K6R design.
Wheels http://www.tirerack.com/a.jsp?a=AW7&...eels/index.jsp
Gary. Tire and Wheel Forum Moderator. Tire Rack Sales Rep Gary@Tirerack.com
http://www.tirerack.com/a.jsp?a=AH8&url=index.jsp
Please refer to 'Gary/E90 Post' as your previous contact when you order online to help support this forum.
      05-08-2014, 12:24 PM   #3
BGR
518
I'm sure the wheels are great based in what I've read, but my question more revolves around fitment specific to the 135i. I know the offsets can be a challenge and I am wondering if anyone has run this wheel/tire combo on a stock suspension without any camber plates/spacers and not had any fitment issues. Thanks.
      05-08-2014, 12:25 PM   #4
BGR
518
Sorry tried to quote above but phone didn't cooperate.
      05-10-2014, 09:25 PM   #5
BGR
518
Anyone?
      05-11-2014, 04:24 AM   #6
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
235/45/17 may be very close to the front fender depending on the tire brand. Its a larger diameter than the stock size too.
I suggest getting 225/45/17 front and 245/40/17 rear for those ET42 wheels. If the rear alignment is close to factory stock you will have enough space for the a very big selection of road tires. I have Michelin PSS in 225 / 245 staggered sizes and they have good clearance using wheels which are 17x8.0" with ET45 offset. What tires do you have in mind?
      05-11-2014, 11:30 AM   #7
BGR
518
I'm also looking at the Michelin PSS. I would prefer a square setup for track use so I can rotate wheels as well as have a more balanced feel.
      05-11-2014, 05:33 PM   #8
John_01
John_01's Avatar
Australia
232
You can fit 245/40/17 Michelin PSS on the front axle if you have some camber - They are not a big tire. However I wouldn't choose the Michelin PSS as a track tire. I tried it for one day on the track and found they become very slippery when they are hot. Also I lost a lot of tread depth in less than 30 mins track running.
      05-11-2014, 09:18 PM   #9
BGR
518
What would you recommend instead? I run in advanced and totally melted the stock run flats. I will also have M3 front control arms so slightly more negative camber.
      05-12-2014, 12:03 AM   #10
John_01
John_01's Avatar
Australia
232
I think you are going to need more front camber no matter which tires you use for the track, otherwise you are going to wear the outside shoulders.
I have a second set of wheels mounted with Toyo R888, which seem to be durable for track use and provide OK grip for my skill level which is still evolving. Hankook R-S3 seems to be one of the popular for track tires that can also be driven on the street. I see others using them on the track to good effect. I think they have about 0.5" wider tread than Michelin PSS in 245/40/17 size, so fitment on the Kosei rims will be very close to the fenders both front and rear. I think you will need about 3 degrees of front camber, 2 degrees rear camber, and I can't say for 100% sure if it will rub or not.
1addicts
