04-25-2014, 08:58 PM | #1 |
21
Rep 70
Drives: Alpine/Coral 135i Sport 6spd
Garage List 2008 BMW 135i Sport [0.00]
2012 Mercedes-Benz ... [0.00] 2003 350Z TT (SOLD) [0.00] 2003 EVO 8 (SOLD) [0.00] 2000 S4 TT (SOLD) [0.00] 2000 S2000 (SOLD) [0.00] 1998 ITR #449 (SOLD) [0.00] 1996 Integra GSR (S ... [0.00] 1995 Supra TT (SOLD) [0.00] 1992 NSX (SOLD) [0.00] |
So you run 11's in 1/4, what mods did you do?
As the title says...include slips if you have them and tire compound please...thanks! I took her to the 1/8th mile last night and she needs mods and traction in a big way. About to drop some money on the 1 and curious to see all the great ideas out there. Have $4k to burn, what to do, what to do?
Brian:
(SOLD) 2008 AW/CR BMW 135i M-Sport | 312whp/357wtq on a MD | 6MT | BB Stage II+ BE Flash | BMS aFe DCI | TiAL BOV | VRSF CP | VRSF FMIC | VRSF IC Piping | VRSF Catless DP's | NGK Laser Iridium +1 Colder Plugs | BMP CF rear spoiler | BMW Style 230's | 235/35r19 & 275/30r19 Firestone Indy 500's |
04-26-2014, 08:13 PM | #2 |
Rep 35
It really depends on your transmission. 6MT is going to take a lot more skill and work to get in to the 11s, hell even low - mid 12s. LSD, sticky tires, and a LOT of seat time. For autos, you should probably be running good tires and FBO, but you might be able to get away with no LSD.
04-27-2014, 12:38 PM | #3 | |
Civil Rights Activist
115
Rep 949
An idiot could put fat DRs or 10.5W ET streets on a 400hp car, dump the clutch and go 11s if you're at a reasonable altitude with good air density regardless of transmission.
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame. BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets |
04-27-2014, 06:16 PM | #4 |
116
Rep 1,158
So drag racing isn't skill with a manual? Ooooook. That means a 16 year old can go to the drag strip and run 11s with a 6 spd ZL1 that has monster DRs out the back first time down the track.
A manual trans requires SKILL to get the most out of it in a straight line. There is more than dumping the clutch and shifting gears. If you cant launch correctly then you're not going to make a good pass. |
04-28-2014, 09:00 AM | #5 | |
115
Rep 949
I didn't say it wouldn't take any skill. If that's how it read, then I'm sorry. I meant it won't take "a lot more skill," which is what you said. Maybe a 16 year old kid can take the car down the strip and maybe he can't. On his first pass? I doubt it. But after 20 passes, probably. I've seen 12 year-olds in pushsters go 10s. I have over 1000 total passes down 1320's in 15 different states. Done these in manual cars, auto cars, NA, turbo, nitrous, blower, so I'm pretty familiar with what is required to go down a track and I'm pretty confident in my experience. I don't disagree that if you can't launch correctly then you won't have your best pass, but in this case we are talking about a car (a BMW 135 - not a ZL1) that like it or not is pretty easy to drive. Let's be honest, drag racing, especially in cars like ours, isn't the rocket science of racing. You might not have your best pass, but you can definitely have a *good* pass. So yes, there is more to it than dumping the clutch and shifting the gears, but not *much* more than that is required to get into the times the OP is talking about. If the OP is looking to one day have the fastest 6-speed 135 in the country, then I'll agree, he will probably need to figure some things out about feathering and pedaling and keeping it in a straight line.
04-28-2014, 12:11 PM | #6 |
116
Rep 1,158
Not every person can make the same times as the pros do. An auto is easy to launch but a manual takes time to learn and not just some idiot off putting big DRs on the back of his car then revving to 5k and dumping the clutch. A "driver mod" is what makes a manual vehicle run great.
Our cars aren't that great in the 1/4 mile simply because of the IRS. No one has yet to figure out the wheel hop in this car. But I bet if the axles were like the ZR1s....then the wheel hop wouldn't be much of an issue. |
04-28-2014, 06:43 PM | #7 |
21
Rep 70
I am really just curious of those that are running 11's at the track, what mods have you done, really...this is my first BMW, but I've raced just about all my cars from my Audi S4, EVO 8, GT2, GT3, Supra, NSX, S2K, 350Z, E63 AMG, C63 AMG, SLS AMG...etc....I'm just curious, that's all. All of my cars have been a 5pd or 6spd so feathering and launching isn't an issue.
Brian:
04-29-2014, 01:13 AM | #8 |
116
Rep 1,158
Well I'm sure you're going to need full bolt-ons with a mix of E85 and pump gas. Most people tune 1st gear down a bit so you can get a better launch in this car then up the boost in 2nd gear on out.
Full bolt-ons for this car is pretty much as follows: full exhaust, intake, bigger intercooler, charge pipe (for N54s like you) and thats it. Then tune it for all that plus the E85/pump gas mix (30/70 mix) then its up to your skill in getting the car into the 11s for sure. Then also getting a set of 255 or 265 rear tires that are street legal drag radials and you're all set. |
05-08-2014, 12:13 PM | #9 | |
21
Rep 70
Brian:
06-13-2014, 09:14 AM | #11 |
10188
Rep 8,634
My previous 6AT 335i...
Cobb E40 Protune VRSF DPs BMW DCI ETS 5' FMIC That car ran a 12.00 @ 119.6. The trap speed indicates it could have gone into the 11s easy as the power is there. If I was not running half worn Hankook V12s, it would have been an 11.8-11.9 easy. Manuals are notoriously harder but you should be concerned with the trap speed much more than the time, I feel many people miss this point.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
06-16-2014, 12:09 AM | #12 |
247
Rep 1,827
My previous 2008 135i had the following:
Cobb OTS E30 map Helix FMIC Raceland downpipes Apex ARC-8 rims with stock runflats With these mods, I ran a 12.0@118mph with a horrible 2.071 60ft. Those runflats were half worn and made it very difficult to grip, but I am very certain with better tires such as Michelin PSS it would have gone 11's easily as it made the power (trap speeds). This of course was with an auto transmission. |
07-17-2014, 10:46 AM | #13 |
19
Rep 222
If you can dish out the $2-3k for an LSD, I think it would help a lot with the launch. I have:
'08 N54 135i coupe VRSF Downpipes BMS intake 30/70 e85 with JB4 map 5 Apex EC-7'1 with 265 Conti Extreme Contact DW Ran 12.797 At the launch the car hops like a rabbit because of the E"LSD," I don't remember exact 60' times but it felt like I lost the most time there. I'm thinking a front mount would help it breath better at top too. |
07-17-2014, 02:05 PM | #14 |
N54 Tuner
Rep 160
Upgraded turbos
07-17-2014, 03:43 PM | #15 |
456
Rep 6,478
Grip, a settled back end, and a real diff.
Power is the easy part.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
08-05-2014, 08:11 PM | #16 |
171
Rep 2,682
Getting 11s is all about grip. Yes you'll need power, but without a good 60ft it's impossible no matter how much power you have on this platform.
I recently got my best time of 12.1@122mph with new tyres (AD08Rs). Only had a 2.0 60ft which is good for me. Check out this thread if you want to see what it takes to get 11s. BMW 1 Series Australian Drag Racing Standings http://www.1addicts.com/forums/showthread.php?t=534598
08-07-2014, 09:48 AM | #17 |
Rep 189
11.76 @ MIR
I posted a best time of 11.76 at MIR in Nov, 2012.
2009 135 Auto, Street tires (Toyo Rs) COBB with PTF tune by Jake (40% E85/93 mix) FBO with the exception of stock mids No weght reduction I completed 6 passes that day with times from 12.2, 12.1, 11,.9s and finally 11.76. This was only my 2nd time on the track so I improved my times pretty quickly. The previous year I ran a 12.9 with a Dinan tune and everything else stock (no bolt-ons). I just recently moved into a new home so my slips are somewhere in 1 of 80 or so boxes. This time was acomplished with a 1.94 60ft, so it was pretty impressive. However,DA that day was right around 0, so basically the conditions could not have been any better. Oct 2013 I bought Hoosier slicks, catless mids, coding for the transmission flash, and asked Jake to slightly increase boost down low since I would have a little more grip. I was also planning to do some weight reduction to try to get to the low 11s. Plan was spoiled as I had to beging looking for a home and uproot my family from Va to Md. Since then I haven't attended MIR. Plan to possibly attend this Nov. |
09-10-2014, 07:42 PM | #18 | |
21
Rep 70
Brian:
