04-17-2014, 12:57 AM | #1 |
180
Rep 1,310
tire brand difference in width?
i have michelin tires PSS 255 Rear and i was wonder if Bridgstone RE11 255 Rear run wider? or the same width .
some companies run bigger then other? |
04-17-2014, 01:00 AM | #2 |
64
Rep 760
Drives: E82 135i & F80 M3
PSS has fairly wide shoulders, I know that for sure.
With the RE11's you might have to do some googling. |
04-17-2014, 05:04 AM | #3 |
Proud AARP member in good standing
28
Rep 635
Just go to TireRack.com and plug in the tires. They'll list all the specs of the tires.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
04-17-2014, 08:03 AM | #4 | |
88
Rep 824
04-17-2014, 10:39 AM | #5 |
170
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
OP, I agree with the TIRERACK suggestion for research, however I can also tell you that from numerous sources on here... the RE11's in a 255/35 18 are narrower than the 255/35 18 PSS. That may actually be different than the TIRERACKS's data shows.
BTW the same applies to the Yokohama S-Drive... opposite to what TIRERACK states, it's actually wider than the Potenza S-04 (all tires being 255/35 18).
"Since light travels faster than sound, some people appear bright until you hear them speak". |
04-17-2014, 02:23 PM | #6 |
General
2042
Rep 25,989
From my experience, the Bridgestone RE-11 runs pretty wide, although I've never compared them directly to the Michelin Pilot Super Sport. I think the Bridgestones probably have a more square shoulder though.
VMR|Wheels | 714.442.7916 |
04-17-2014, 02:43 PM | #7 |
180
Rep 1,310
I just checked on tirerack the tire spec width of both tires are exactly the same 10.2
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
04-17-2014, 06:35 PM | #8 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
IMO TireRack specs will help however due to shoulder designs, etc. it's more complex than just looking at specs. Sorry, I've never used RE11's.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
04-18-2014, 11:54 AM | #9 |
General
2042
Rep 25,989
+1
The physical dimensions of the tire are only part of the story. It's like comparing height and weight of people. You may have two people that are the same height and weight, but their proportions could be completely different.
04-18-2014, 12:00 PM | #10 |
157
Rep 1,409
Let me spare you the doubt and anxiety. I use 255's RE-11 in the rear and track my 135i. No rubbing at all on stock style 261 rims.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
