04-09-2014, 03:24 PM | #1 |
153
Rep 964
Drives: BMW 135is | #341/586
Rims and Tires for the Track
I am looking for a new set of Rims and Tires for the Track. I am running the stock suspension for my 135.
I would like to stick with 18 inch rims. Any suggestions for the brand/size/offset of rim and the size of tire?
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
2021 BMW X7 M50i | Alpine White | Children Hauler Last edited by Chunner; 04-09-2014 at 03:26 PM.. Reason: Question clarification |
04-09-2014, 05:16 PM | #2 |
General
2042
Rep 25,989
Our V810s plus some nice sticky rubber.
https://www.flickr.com/photos/vmrwhe...7636563494005/ 18x8.5 ET45/18x9.5 ET58 + A tire like the Bridgestone RE-11 would be a great combo!
VMR|Wheels | 714.442.7916 |
04-09-2014, 06:31 PM | #3 | |
153
Rep 964
2021 BMW X7 M50i | Alpine White | Children Hauler |
04-09-2014, 08:21 PM | #4 |
89
Rep 912
Prices and weight on those VMRs?
E82 '13 135is - Space Gray/Coral Red, 6 MT, Heated Seats, 50% tint, clear bra, BMW Perf. Grilles, BMW Perf. CF Diffuser - #180/586 |
04-09-2014, 09:00 PM | #5 | |
460
Rep 4,531
Are these purely going to be running on the track? If so, why do you want to stick with 18s? IMO, there is nothing beneficial with 18s for track. You're spending more on wheels, tires, and a smaller sidewall. If you can fit 17s, go for it. You're reducing weight, which thus translates to rotational mass and quicker acceleration. As well, tires are cheaper. As for tires, IMO look into the Dunlop Z2s or BFG Rivals. Both tires can handle non-camber cars fairly well (because of their harder sidewall). I do like the Hankook RS3s, but there is a new version coming out within a week or 2 and really no known data on them yet. |
04-09-2014, 09:07 PM | #6 |
/M Enthusiast
1599
Rep 1,619
I bought Bridgestone RE-11s for my Vette, I love them on the track and street, I've done wet and dry HPDE days with them. Really excellent traction even when lightly drifting them. I wish they had the size I wanted for my One when I was putting track tires on it. I went with Dunlop Z2s on the One., they are good but a bit noisy, but wet and dry traction is really good with them also.
Anyway those are both good tire choices for street and track driving. Last edited by Suds; 04-09-2014 at 09:17 PM.. |
04-09-2014, 09:22 PM | #7 | |
157
Rep 1,409
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
04-09-2014, 09:25 PM | #8 | |
460
Rep 4,531
IIRC, the biggest width you can go is around 255s. This is limited by tire manufactures. Now that I think about this, you're going to need more rear tire....which is a good point for 18s. I have ran on Hankooks for 2 years on my Z4M and loved them, take a bit more slip angle to get ultimate grip. Just started running on Dunlop Z2s. Much more responsive, but when you get to the limit they break away pretty quick. With the RS3s you can progressively feel the tire start loosing grip and can recover. |
04-09-2014, 09:31 PM | #9 | |
157
Rep 1,409
What is the maximum front+rear RIM width for a 17" is what I was interested in (17x8.5, 17x9, 17x9.5). If you recall, I have front camber plates. I would not mind a square setup or "minimal" stagger setup...
04-09-2014, 09:40 PM | #10 | |
153
Rep 964
04-09-2014, 10:13 PM | #11 | ||
460
Rep 4,531
Let me start off by saying, that the 1 series has stupid offsets (in the rear). If you want a square set-up, you're going to be limited to 8.5" or 9". Let me go into explain what I've had to go through for fitting 8.5" As you can see, there is not much room to give. The car is lowered a big amount...as I want to set it up for track/autox as much as possible (going on recommendations from people who have raced 135i before) Anyways, I run ARC8s wrapped with Dunlop 245/40/17. The wheels are 17x8.5 ET40. The fronts needed a 5mm spacer to clear the strut and a light fender roll to avoid rubbing under high compressure. For the rears, I needed to do a hard roll to avoid rubbing. I still get rubbing under compression against the fender liner...but no contact with the paint (I'm perfectly okay with that). If you tried to go 9" square, I feel that you will need to roll and pull fenders to clear the fronts. The rears aren't as big as an issue (if you're specifically looking at APEX because their 17x9 is an ET42). With an ET42 in the rear, you won't stick out as much as you would with an ET40 and 8.5" (specifically it would be 4mm). However, there is no room to go. You'll need a bigger spacer to maintain clearance from the strut...which means you're going to need around 12mm of extra room on the outside fender...which IMO is not happening. So, I think if you want to play it safe, either 8.5" squared with roll in the rear at least, and maybe fronts depending on how you are lowered. Or, you staggered with a 9.5" in the rear with a high offset (APEX is ET62 which will fit perfect). And incase you wanted to know, from a visualization standpoint. This is with stock suspension and camber: Quote:
Sizing the tire will depend on the brand/model tire you decide and what wheel width. For example, I would not recommend the same size RS3s and Z2s, because their tire design is completely different. Z2s can be stuffed on a wheel (similar to a R-compound) and still be effective. If you try to do this with RS3s, you'll decrease steering response and make the car slower and tougher to control....because the tire will actually shimmy back and forth on the wheel before it starts to "slip" and make grip. Do you want to go staggered or square? Basically the recommendations are the same for 18" as they are for 17". I'm a pretty big fan with APEX. They helped me numerous times trying to size and fit my wheels. Huge asset. |
04-10-2014, 06:53 AM | #12 |
157
Rep 1,409
04-10-2014, 01:02 PM | #13 |
General
2042
Rep 25,989
Typically on most of our wheels, 225/40/18 and 255/35/18 is what we recommend. You can run a 265/35/18 or possibly even a 275/35/18 with the V810, depending on your alignment, tire you choose, and whether or not you have the rears rolled or modified. 265/35/18 should fit without modification, but the 275s may require a a bit of work.
For a set of 18s you're looking at about 22 pound per wheel front and rear. PM coming your way though!
