04-05-2014, 04:49 PM | #1 |
Rep 103
18" Apex EC-7 Anthracite on AW
Hey all,
Just had these mounted. 18x8.5 et38 225-40-18 18x9.5 et58 255-35-18 I think it may need a small spacer in the rear, but I love the way it looks |
04-05-2014, 06:33 PM | #3 |
Senior Chief Petty Officer USN
106
Rep 501
can you post more detailed pics....im getting ready to order these with the exact size tires and want to see how much of a gap you have so i can order spacers at the same time
04-05-2014, 07:08 PM | #4 |
707
Rep 2,448
Car looks awesome. Im thinking about the same wheels as well and would love to see more pics. Also, If you got 265s in the rear do you think you would still want a spacer? Just curious because I am planning to get 265s for the rear.
04-05-2014, 09:08 PM | #6 |
Rep 103
I will try to get a picture of the clearance of the wheel to fender tomorrow. It's not much but it would benefit from a spacer. A 265 would most likely make up the difference however.
I am lowered on kW v2 coilovers and camber is less than a degree I believe |
04-06-2014, 09:53 AM | #7 |
707
Rep 2,448
Thanks. Looking forward to the pics.
04-06-2014, 02:47 PM | #8 |
66
Rep 1,267
Drives: AW 135i
I don't know why you'd need a spacer for anything other than looks...
Build thread: http://www.1addicts.com/forums/showthread.php?t=748935
04-06-2014, 05:57 PM | #10 |
1418
Rep 2,560
Drives: Rapidly from A to B
18x8.5 et38 in front??? I'm running 8.5 et45 in front and a 38 doesn't even seem possible. Is it?
Updated: Just checked the Apexraceparts site and I don't see an EC7 available in a 38 offset. My guess is you are running a 45 in front. Last edited by Pyrat 2; 04-06-2014 at 06:04 PM.. |
04-11-2014, 11:41 AM | #11 |
170
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
OP, looks great... and nice job with the ride height on the KW's... not too low, not too high, just right
"Since light travels faster than sound, some people appear bright until you hear them speak". |
04-11-2014, 12:20 PM | #12 |
Rep 257
Love it! I went back and forth between EC7's and ARC-8's and depending on the day I think I should have picked the other.
I currently have the same sized rear wheels (ARC8) with 265/35 rear tires and 3mm spacers with no issues, I am going to try 5mm spacer when I do a wheel stud conversion and I think that will be about perfect to even the look up with the front. I am also lowered on KW's and close to the same ride height if not a little lower. |
