04-01-2014, 07:13 PM | #1 |
88
Rep 824
Spacers for 225/255 setup
I have 225 front and 255 rear michelin pilot sport as/3 mounted on stock 264 wheels. I'm at stock height. I measured with a ruler and have about 1.5cm front and rear from edge of tire to fender. I'm going to do 10mm up front and was thinking about going 5mm in rear. Anyone run this setup at all? I was told I shouldn't put any spacer on rear but just want opinions
04-01-2014, 07:37 PM | #3 |
88
Rep 824
Just want the wheels to sit flush with fenders. I had 15mm rear and 12mm spacers with my stock 215/245 size and it was perfectly flush. I like the look not fan of tucked wheel
04-01-2014, 08:03 PM | #4 |
456
Rep 6,478
my wheels are not stock width, but 5mm all around on my car, up front solely to clear the strut. Rear is aesthetic.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
04-01-2014, 08:07 PM | #5 | |
88
Rep 824
04-02-2014, 10:23 AM | #6 | |
456
Rep 6,478
I’d get hub extenders but the rear hub on E8x does not accept one.
04-02-2014, 10:33 AM | #7 | ||
88
Rep 824
04-02-2014, 11:05 AM | #8 |
456
Rep 6,478
I honestly don’t recall what spacers I have on the car right now, either Macht Schnel or H&R. If the latter are hubcentric at 5mm, that would be great. Either way it hasn’t been an issue for me at all. 10mm spacers at my current ride height would cause pretty intense rubbing. More camber up front would rectify that, but in the rear there just isn’t much room. I hate doing anything wheel or tire related to this car, the space inside the wheel wells is such a joke.
04-02-2014, 02:48 PM | #9 |
General
2040
Rep 25,989
5mm spacers can most definitely be hubcentric. All that implies is that the bore in the middle of the spacer is the size of the car's hub. They would not be wheelcentric though, as there would be no machined lip on them.
VMR|Wheels | 714.442.7916 |
04-02-2014, 03:32 PM | #10 |
53
Rep 199
Drives: F22 M240i
I've got 264's with 225/255 Goodyear Eagle Asymmetric 2's fitted. I have a set of 10mm and 12mm spacers I'm planning to fit (12 rear/10 front). Would this work and could I perhaps also squeeze a set of Eibach springs in for a slight drop or am I playing with fire in terms of potential rubbing issues?
04-02-2014, 04:11 PM | #11 | |
456
Rep 6,478
04-03-2014, 07:22 AM | #12 |
53
Rep 199
Drives: F22 M240i
Thanks. I'll fit the spacers and see what the effect is. No point in picking up the springs until I've seen how the car gets on post-spacer install and having a look how much space I've got left to play with
04-05-2014, 07:39 PM | #13 |
53
Rep 199
Drives: F22 M240i
I fitted the spacers (12mm rear and 10mm front) and unfortunately with the 255/35/18 at the rear it touches quite badly when traveling over uneven surfaces. I'm going to swap the spacers around to see if 10mm is more suitable for the rear in this config.
04-13-2014, 07:32 AM | #14 |
53
Rep 199
Drives: F22 M240i
Some more feedback: Swapping the spacers around I continued to have no rub up front, but the rear continued to rub, albeit is less situations. Removed both sets of spacers and all is well.
05-28-2018, 05:15 PM | #15 |
Rep 10
Hey guys.
Bringing this thread back from the dead. I currently run 225/255 tires with stock m sport suspension and stock 264 wheels . After researching I installed 12mm spacers front 15mm spacers rear. The rears rubbed over rough road conditions and dips. I then swapped out the rear 15mm spacers for 12mm. Now the rubbing has minimized but it now only occurs on rear passenger side only. Would an alignment fix the problem or should I remove rear spacers entirely? |
05-31-2018, 09:55 AM | #16 | |
Rep 13
Drives: E82 VTT 2+ E30 FBO
