03-29-2014, 11:13 AM | #1 |
Rep 198
Coding out TPMS
My search on this is not returning anything useful... Does anyone know if its possible to "code out" the TPMS. I don't need it, it hasn't worked properly in 20k, and I'm sick of the always-on warning light I have now, despite my tires being at the correct pressure. I'm so desperate, I've been considering cracking open the instrument cluster and removing the TPMS LED, lol.
03-29-2014, 11:24 AM | #2 |
50
Rep 739
Yes, it's possible. I had it done on my 1M. It requires unplugging the TPMS module (location depends on model and year) and then doing some coding work. I had a friend of mine do the coding so I don't recall exactly which parameters were changed.
The other option is to buy a TPMS emulator like the one Macht Schnell makes.
03-30-2014, 09:54 PM | #4 |
153
Rep 964
Drives: BMW 135is | #341/586
I think the TPMS sensors have a batteries. Check it out.
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPS AS/3 - VMR 710's 18x8.5 ET45 / 18x9.5 ET50 | MPSS - BMW 313's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | Beast #341/586 |
2021 BMW X7 M50i | Alpine White | Children Hauler |
03-31-2014, 02:13 PM | #5 |
18
Rep 116
Yes, they run lithium ion batteries. Unfortunately they are not generally serviceable. If Huecifer is having issues, he most likely has a bad TMPS unit. As to which one is anyone's guess.
From what I have read, the expected lifetime of a TMPS unit is 5 to 12 years. As this was legislated in the United States as required in 2007, it should be interesting to see what the failure rate is.
JTB
Spec Miata - 2nd SCCA RMDiv 2014 Spec Miata - 2nd SCCA RMDiv 2013 2009 135i - let the modding begin! |
