Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      03-27-2014, 05:20 PM   #1
Smiley913
Drives: Something that Runs
S55 vs N54 dyno characteristic
I think the dyno graph shape for the S55 and N54 is very similar. I am not talking about numbers but the characteristic of the HP and torque lines.
Link to N54 stock dyno:
http://www.1addicts.com/forums/showthread.php?t=432677
Link to S55 manufacture "dyno":
http://f80.bimmerpost.com/forums/sho...d.php?t=893935
Both torque curves have the following characteristics: start with sharp rise, flat middle, and drops off at the end.
HP curve: start HP line slope is higher compared to middle, flat end.
Does this mean the S55 will feel similar to N54/N55?
      03-27-2014, 05:39 PM   #2
parky1215
parky1215's Avatar
564
Drives: F90 M5C | G06 X6 M60i
It will feel different @ top end.
N54's HP falls down after 5800 RPM while S55 will produce max HP from 5500 to 7300 RPM.
S55 will have best of both Turbo (low RPM torque) and NA engine (top end HP) according to spec sheet.
Hopefully that will be how the car actually drives.
      03-27-2014, 11:16 PM   #3
SneakyDeeky
driver mod in progress
SneakyDeeky's Avatar
225
Drives: with both feet
2015 VW Golf R  [5.50]
2014 Audi SQ5  [10.00]
Thumbs up
Regarding the characteristics, you're right when discussing the stock torque and power curves, but as soon as the coding is cracked and somebody optimizes a tune for E85, look out! My dyno from earlier this year with a blend of E85 and 91 octane, netting an E60 blend, is shown below.
Note that this is with my daily driven fuel blend and tune as better numbers are achievable when cranking up the boost and more timing advance.
I hope the S55 torque curve is like the N54 but even better, as I love mine. It's a tire shredder, but man is it fun to drive.
Link to Video of Dyno Run shown above
      03-28-2014, 12:47 AM   #4
paddy335
66
Drives: M140i;X5 40d
Originally Posted by SneakyDeeky View Post
I hope it's like the N54 but even better, as I love mine...
http://www.e90post.com/forums/showthread.php?t=937787
Every time I see your car in your sig.....man it looks good
      03-28-2014, 05:26 AM   #5
CanAutM3
General
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
You cannot really compare the two power curve images you provided. One is a marketing "cartoon" while the other is a chassis dyno chart. Both are imprecise in their own way. To do an apple to apples comparison, we should use both the marketing cartoons. I used the 1M power curve here. IMO, the S55 will feel much stronger on the top end due to the broader power plateau and higher overall output with much more useable power.
Since the S55 is a FI engine, it will also be closer to the N54 in terms of feel than to the S65. I am not yet convinced this is a good thing. I guess I will find out when I pick-up my M4 this coming July.
      03-28-2014, 10:37 AM   #6
tdizzle
107
Drives: 2017 F80 ZCP
Apparently the new N55s had a slight tweak to their turbo (or the exhaust part of it) and are seeing a more flat curve at the top rather than the insane drop off everyone hates.
BMS is testing out the electronic wastegate version of the newer ones and has a 2014 435 putting down over 400whp and says there is still room for growth. The curve looks nice and pretty near the top. Color me and my '12 335 jealous.
Let's hope BMW was on to something and the true power curve is exactly what they're painting in their cartoon. The newest development of the N55 makes me optimistic.
      03-28-2014, 10:44 AM   #7
Black Gold
592
Drives: M3
incredible that the electronic wastegate has made that much of a difference in tuning potential.....
the m3 is a different ball game as its twin turbos vs single, different internals, different cooling system, different turbo placement etc....
      03-28-2014, 10:48 AM   #8
tdizzle
107
Agreed, can't really compare the M3 to the n55, I just wanted to point out that they may have learned something in developing the //M car as that small tweak on the N55 has basically added 30whp to a similarly tuned car in the alpha version. It also probably explains why they revised the MPPK numbers to be a bit higher than previously.
//M cars should be loads of fun.
      03-28-2014, 10:52 AM   #9
Black Gold
592
Drives: M3
do you have any links on where this change is explained in more detail? id love to learn more about exactly how this has resulted in more power.
I am not worried at all about power in the m3. I think the car will absolutely rip, and there will be more power on the table once the tuners get the cars and get cracking.
One thing that would be nice is if the cooling system is as good as I hope it is. The n54/55 cars basically need IC upgrades in stock form, even the 1M which had a more robust system (mainly oil coolers and secondary radiator).
      03-28-2014, 11:56 AM   #10
swamp2
swamp2's Avatar
611
Drives: E92 M3
Given that what we feel (at least if we only consider the butt-o-meter), moment by moment, instantaneous acceleration, is governed by the shape of the torque curve, I suspect they will feel quite similar. They will certainly feel more similar than the new M3 will feel to the current one.
Sure the car will be substantially faster, will make better sounds (than the N54) and this will also mask some of the overall similarity. It is hard for us to be fully unbiased and separate each of our senses (visual, inner ear (acceleration), ear (acoustics), vibration, etc.). The overall shift to the right of the torque curve will also mask some of the similarity.
Some of the short shifting we've seen in the M3/M4 videos also speaks to engine character and feel and this bolsters my point of view.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      03-28-2014, 03:25 PM   #11
Inuyasha
“One finds limits by pushing them”
Inuyasha's Avatar
123
Drives: M2C
I'm hoping this new M feels like the N54 because the N54 rocks!
      03-28-2014, 06:39 PM   #12
SneakyDeeky
225
The info requested about the electronic waste gate tuning improvements is found on that other forum. Good stuff by Terry as usual.
http://www.n54tech.com/forums/showthread.php?t=23709
As for the S55's sound, the OEM exhaust tone is pretty bland if you ask me, but then again so is the N54's. By the time you remove the cats from the downpipes to reduce turbo lag and upgrade the mufflers it will sound really good; it won't be as good as the V8 S65, but few sounds are.
I'm counting on the S55 to come from the factory with much improved cooling and be ready to withstand track duty out of the box. If it didn't, I wouldn't even consider making the switch.
To maximize the N54's potential and fully enjoy it on a track, just take a look at the mods in my sig. I had a major focus on cooling (i.e. - dual oil coolers, larger intercooler, water wetter additive with only distilled water in the radiator, m3 bumper for better airflow, etc...). Even upgrades to the fuel system help as E85 burns cooler than traditional fuel and much cooler than race gas - the NGK 5992 plugs with tighter gaps are needed for such high blends of the corn fuel.
      03-28-2014, 07:44 PM   #13
///ADMAN
///ADMAN's Avatar
40
Drives: 2013 BMW 335is
2013 BMW 335is  [10.00]
Originally Posted by DarkAgent View Post
I'm hoping this new M feels like the N54 because the 335is N54 rocks even harder!
Fixed
      03-28-2014, 08:25 PM   #14
BlackLight
BlackLight's Avatar
17
Drives: E92 M3
Exclamation
... water wetter additive with only distilled water in the radiator,..l.
You know that is a scam right?
Anything that reduces the boiling point (surface tension) will reduce the cooling capacity...
      03-28-2014, 08:51 PM   #15
gmd2003
gmd2003's Avatar
352
Drives: 2014 CP M6 and 2006 VT 525 Z4M
It's not a scam , it actually increases the waters boiling point and prevents micro bubbles from forming in the radiator . Those bubbles cause reduced heat transfer from the motor to the radiator . I see an avg decrease in water temps on track of 15 degrees using it with water vs antifreeze /water mix . Not sure where you pulled its a scam from but you're dead wrong .
      03-28-2014, 09:09 PM   #16
///ADMAN
///ADMAN's Avatar
40
Agreed. I run about 20 degrees cooling in my track car with Water Wetter.
      03-29-2014, 07:16 AM   #17
MRV99
MRV99's Avatar
254
Drives: 2017 M3 ZCP / 2017 RRS SC
2017 BMW M3 ZCP  [0.00]
Haha reduce the boiling point.
17 M3 ZCP -- 2017 Range Rover Sport SC
--RIP--
12 X5 50i Sport -- 11 M3 DCT -- 2011 X5 50i(Lemon) -- 2008 550 Msport -- 2007 x5 4.8 sport -- 2004 545 sport -- 2002 x5 4.4 sport -- 2001 540i Msport 2000 SL500 -- 1997 SL500
      03-29-2014, 01:41 PM   #18
BlackLight
BlackLight's Avatar
17
Drives: E92 M3
Exclamation yes WW does reduce the boiling point
      03-29-2014, 02:18 PM   #19
///ADMAN
///ADMAN's Avatar
40
Once you let your car get to 305F, the additive is pretty much a moot point.
You have a bigger problem on your hand. I know first hand...
http://my350z.com/forum/maintenance-...eavy-pics.html
      03-29-2014, 10:00 PM   #20
BlackLight
BlackLight's Avatar
17
Drives: E92 M3
Exclamation The point is
You have a bigger problem on your hand...
that 100% water makes the most difference, and additives are not usually allowed on track anyway.
The interesting part of the graph is below 250F...
      04-04-2014, 09:14 AM   #21
G80indy
Save the Manuals
G80indy's Avatar
1714
Drives: Z3, E46, G80
OCD kicking in again
regarding wording here:
It doesn't reduce boiling point.
It decreases the residual heat in the block, by more efficient heat transfer.
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      04-04-2014, 09:51 AM   #22
CanAutM3
General
CanAutM3's Avatar
21117
^ This
It has not much to do with boiling point, but rather with specific heat capacity. Water is a very efficient medium to convey heat energy (ie, you need a good amount of energy to raise a given amount of water by 1 degree). Adding additivies (such as glycol) is great to prevent freezing and corrosion is the coolling system, but it reduces the specific heat capacity of the fluid in the cooling system. This is very well portrayed in the graph in the previous post where it shows cooling time depending on the fluid mix.
Tags
dyno, n54, s55
f80post
