      03-25-2014, 08:35 PM   #1
jbertino
34
Drives: 2010 135i 6mt fbo protune e30
Stance guys need help!
I'm looking to buy ccw in 18x9 +32. And 18x9.5+ 38. Wrapped in 225/35 I will be lowering also what will have to be done to get them to fit with minimal rubbing
full bolt on 6mt
cobb
e30 protune
fortune auto coilovers
12.08 119
      03-25-2014, 08:38 PM   #2
135Pats
135Pats's Avatar
456
Drives: A few BMWs
I don't stance my car but can tell you the front is going to be no fun to fit. You can make it work, but it'll require a lot of work. Probably a pull, cutting the liners and tabs in the rear, tons of camber, and you'll be very very tight to the strut most likely. It will look sweet on the CCWs though.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      03-25-2014, 08:42 PM   #3
jbertino
34
Yea I was looking a wheel calculator and it actually says I will 7 mm more room to the strut than a 18x8.5 +45 . But it will poke out 19 mm more
full bolt on 6mt
cobb
e30 protune
12.08 119
      03-25-2014, 09:19 PM   #4
135Pats
135Pats's Avatar
456
Drives: A few BMWs
Ya it's going to suck to fit TBH. You'll need to get it poking a good deal to clear the strut, but obviously the fender area bites so you'll need a serious pull and camber. Even then it'll rub but it is what it is.
I wish CCWs looked good in higher offsets, i'd love some classics on my car but 8.5 ET38 and 9.5 ET44 is boring looking.
F30 N55 XDrive EBII
      03-25-2014, 09:24 PM   #5
jbertino
34
Not really I was looking at a set that were 18x10 + 50 and they still looked good had about a 2 inch lip
full bolt on 6mt
cobb
e30 protune
12.08 119
      03-26-2014, 07:18 AM   #6
Fifty3bags
326
Drives: 2010 135i
I would talk with @anttmann about his setup. It's very similar to what you are looking at running. You can find his build thread on here.
Also, I am currently waiting on my wheels to come back from refinishing and I'll be running similar offsets as you (with adapters). Less aggressive in the front and more aggressive in the rear. Your best bet is to find specs from other people and compare them using willtheyfit.com and fitmywheels.com to see how much different your setup will be.
1addicts
