03-13-2014, 03:27 PM | #1 |
Rep 28
Michelin Pilot Super Sport or Continental ExtremeContact DW?
I'm looking to change out the RFT to normal tires. Everyone raves about the Michelin PSS but Tirerack.com's got a good deal going on Continental ExtremeContact DW.
I've had Continental ExtremeContact DWS on my previous car and I loved them. Are Pilot Super Sports really worth the extra money? It's about $300 difference. I honestly don't really drive my cars that hard so I feel like Super Sports will be over kill. |
03-13-2014, 03:35 PM | #2 |
Rep 257
I debated those two, called Tire Rack and talked to Gill for awhile and he ended up convincing me to go with the S04's.
He said the PSS and S04 are extremely close and the S04's are real cheap now too so I went with them. I also have a convertible so when he said the S04 is a bit softer over bumps than the PSS he had me hooked. I like bridgestone. re01 and re-11's have treated me well previously. |
03-13-2014, 03:43 PM | #3 | |
Admiral of the Fleet
265
Rep 3,552
The other thing to consider though are all the extra benefits Michelin gives you under the Michelin Plan, which might be especially useful depending on your plan about a spare. They will tow you for free up to I think 150 miles and a friend of mine who recently hit a pothole and had his PSS bubble up in the rear after 2k miles, michelin just gave him a new tire for free under their warranty. In the end, you can't go wrong with the PSS, just a matter of $. And as a fellow IS-er on the mean (awful) streets of LA, if I had to do it again, I'd be right on the fence and 50-50 since I don't know if I'm taking advantage of or would even notice any of the improvements between the two tires. Hope that helps...though it may make it worse. |
03-13-2014, 06:20 PM | #5 |
138
Rep 353
the S04 seems very appealing, but if you believe tirerack it has a 4lb+ weight penalty per corner. I just got in on the group buy for Apex wheels which are 4lbs+ lighter than stock. If I go PSS, that is another 4lb+ lighter than the run flats, but the S04 are about the same weight as run flats.
So similar to the OP question, would saving another 4lb+ per corner be noticeable? I think it might be worth it to go PSS or Conti which have the same weight, but S04 seems to have a big weight disadvantage. The other thing of course is that $300 buys other mods like blacklines or a front sway bar or a used JB4. Decisions Decisions.... Last edited by potxoli; 03-13-2014 at 06:25 PM.. |
03-13-2014, 08:24 PM | #7 |
1Addict
3233
Rep 7,894
Not that it will make it easier but you could look at the Vred Vorti. Same category as the PSS. I just got them and couldn't be happier, hooks well in 1st/2nd around corners, but the sidewall is stiff on these badboys too. So..
I'm just getting them worn in now, Think I'm around 400-450 miles on the set. It should just keep getting better, and it's already damn damn good.
03-13-2014, 08:29 PM | #8 |
1418
Rep 2,560
Drives: Rapidly from A to B
I have owned both. If you're not driving hard the EC are fine although I still prefer the MPSS. If you plan on going to the track then there is no comparison. I had my ECs literally start shredding apart. Suffice it to say it was not a good day for me when this happened. I know its not a track tire but either is the MPSS and they have held up fine.
03-13-2014, 08:51 PM | #9 |
Rep 257
http://www.m3post.com/forums/showthread.php?t=678512
Here's a good thread on the pros and cons of the S04. They look like a great bang for the buck tire IMO. |
03-14-2014, 12:47 AM | #10 | |
Rep 28
03-14-2014, 02:15 PM | #12 | |
Rep 257
To me it came down to the cost difference, it didnt quite seem justified to me. My 265/35/18's are being delivered today, and the 245/35/18's arent supposed to make it till Monday. (Tire Rack shipped from different locations) I will post up my bathroom scale weight per tire to go against the Tire Rack advertised weight for fun. I can also do my new 18x8.5 and 18x9.5 APEX ARC-8 vs APEX advertised weight to make sure my scale is good. (I'm not saying the tires are lighter than advertised because I am sure they are not, but I'll check it) |
03-14-2014, 05:34 PM | #13 |
151
Rep 929
I immediately removed the OEM runflats and replaced with PSSs. It feels like the tire was made for this car. I hear the S04 is a good tire, so I'm interested in hearing your opinion on the S04s (as well as the bathroom scale weigh-in!).
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension |
03-14-2014, 05:43 PM | #14 |
265
Rep 3,552
I'd rather hear about the Continentals since I'd rather get those for my purposes than the pole positions (s-04s) since I would prefer the smoother, quieter ride, which may be the OP's goal, especially on these awful streets. The other problem is the weight readings on the 245s and 265s may not be all that helpful to those of us running stock 215/245s or upsized 225/255s.
From a performance standpoint though, I think the S-04s are better than the contis and ALMOST as good as the PSS, consistently rated by tirerack as a close second. But if someone wants a more comfortable DD tire with a softer ride and doesn't want to shell out PSS money, I think the extreme contact DW tires are a good alternative. Perhaps we can convince OrangeTea to get the continentals so we have 2 identical 135is's, one with PSS, one with the continentals (or s04s) and drive them on the same LA roads for a good test comparison. |
03-14-2014, 05:45 PM | #15 |
Rep 257
So Tire Rack says 29 lbs for the 265/35/18 S04 and my bathroom scale says 29.2 lbs.
Both tires banded together were shipped for 58lbs from UPS so they are right at the Tire Rack advertised weight. (Not that I was expecting anything different) |
03-15-2014, 02:23 AM | #16 | |
23
Rep 647
03-15-2014, 09:29 PM | #17 | |
Rep 257
If I lived in a dry area, I would get the re-11's. They were surprisingly quite for the first 2/3 wear. |
03-15-2014, 10:28 PM | #18 | |
23
Rep 647
03-15-2014, 10:38 PM | #19 |
European Editor
10589
Rep 22,992
Hands down the best tire out there is the PSS. You won't see anything but glowing reviews. And the biggest selling point with the Michelins is that they are AWESOME tires not just when brand new,but also a few years down the road. Often times once tires get some miles on them, they will make lots of tire noise and start to pull on "cambered" roads. The Michelins are a very good tire.
G.L. on your tire choice - and please report back to us.
03-16-2014, 08:29 AM | #20 | |
Resident Tamed Racing Driver
298
Rep 4,697
Everytime I get a tire that isn't a Michelin, I'm massively disappointed. At this point its not even a thought. From PSS to Primacys to X-Ice, they are really best in class.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
03-16-2014, 09:43 AM | #21 |
89
Rep 912
I'm debating this right now. The $ savings is really pushing me in the direction of the DW, and I'm one of the biggest PSS supporters there is having run them on my previous car.
E82 '13 135is - Space Gray/Coral Red, 6 MT, Heated Seats, 50% tint, clear bra, BMW Perf. Grilles, BMW Perf. CF Diffuser - #180/586 |
03-16-2014, 12:12 PM | #22 |
968
Rep 3,323
I'm due this spring for a new set and these 3 tires are what I was considering. I have owned the Conti DW's and liked them. The price is good for the Conti's for the quality of tire. The S-04's seem to be a good choice also because of price and reviews I have read.
The deal breaker for me is do the Michelins last longer than the others? If they do, it might be a wash and I'd be going for the Michelin PSS. Anyone have advice on how the Michelin PSS hold up in mileage?
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
