03-04-2014, 07:35 AM | #1 |
Rep 7
Tire Pressure
I recently bought a 2008 135 convertible. Shortly before I bought it the run flats were replaced with high performance summer tires. When inflated to the 39psi that BMW specifies for the run flats the car rides like the tires are made of concrete. I have tried reducing the pressure two psi at a time, and at 30psi the ride is acceptable. Has anyone else come up with a better idea?
03-04-2014, 08:42 AM | #4 |
118
Rep 1,668
32 PSI in a normal style tire is acceptable. You can always goto the manufacturers website and determine the correct tire pressure for the style tire that you have. If the manu doesnt display it you can also ask a tire specialist.
Run Flats are meant to be harder and less flexible. The reason for this is so that the tire does not prematurely wear out around the rim lip or by flexing the plys of the tire to an extreme. A tire that has been over stress will likely have threads and beads of rbber inside the rim which s visible when dismounted (only) That is why when you do have a flat tire on a run flat you are supposed to replace them after you drive up to 50 mles (@<50 miles per hour). If you have ever had a flat run flat you will certainly notice. The vehcle gets very squirrly compared to the fully inflated tires. So with a regular style tire high performance or not 32 PSI will be fine. The V12's you have will wear just fine at 32 PSI. As a matter of fact at higher PSI the center of the tire will wear faster and give you what i call tire fade early on in the life of the tire. This gives you a very loose feeling in your butt under high cornering situations. Unless you are trackng the car which is of course at your own risk I would not drive it with less that 30 PSI.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
03-04-2014, 08:42 PM | #5 |
Rep 7
In lowering the pressure I have run afoul of the tire pressure monitor. Is it possible to reset the target pressure, or am I stuck with the factory 39psi?
03-04-2014, 10:23 PM | #6 | |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
You should fill/bleed your (cold) tires to the desired pressure, then reset the TPMS per the owner's guide instructions and you're good to go.
03-04-2014, 11:09 PM | #7 |
Admiral of the Fleet
265
Rep 3,552
The target will simply be wherever they are at when you last reset it. People have referred to it as a "stupid system." It only knows whatever spot you teach it and will merely alert you when it gets x amount below that or a certain percentage, which is escaping me. So, set 'em where you want, reset the TPMS system so it learns those numbers and know that apparently you have to do the reset while the car is on and you seemingly have to drive for a minute for it to learn, and then after a minute or two, the TPMS light will go off. So, know in advance that it doesn't go off immediately, which can be disconcerting, or at least was to me the first time I did it.
03-07-2014, 07:22 AM | #9 |
4338
Rep 6,196
03-07-2014, 12:36 PM | #10 |
General
2042
Rep 25,989
Kind of surprised that on a set of Hankook Ventus V12s you found them to be too stiff. Those tires are known for being pretty soft too.
I wouldn't go much lower than 30PSI. Personally, I would just stick to the OEM pressure recommendations, because not running the correct pressure could affect your tire wear/life and your mileage, but that's up to you.
VMR|Wheels | 714.442.7916 |
03-07-2014, 11:06 PM | #11 | |
167
Rep 403
Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
03-08-2014, 05:24 AM | #12 | |
1836
Rep 4,203
The 128 door jam actually quotes 2 pressures, one for speeds under 100mph which I do most of my driving and the other above 100 |
03-08-2014, 09:09 AM | #13 | |
167
Rep 403
The higher tire pressures kick in if you're at 4x passangers & luggage above 100 mph... Karl.
03-08-2014, 09:43 AM | #14 |
265
Rep 3,552
Weird, my 2013 says 36 front, 39 rear like others. I wonder at what point and why they changed the numbers. The convertibles are also higher at like 39 and 42 if I remember correctly.
03-10-2014, 01:10 PM | #15 |
General
2042
Rep 25,989
They are known for being significantly softer than RFTs. Pretty much any tire that's not an RFT will be softer than an RFT.
