02-11-2014, 10:14 AM | #1 |
111
Rep 1,487
High Offsets - How High?
I'm beating myself up over rim choices right now and I have a question.
How high (offset) can you go with... - 8" Front - 8.5" Front - 9" Rear - 9.5" Rear ...before you rub the shock absorber. Pretty much what I am asking is at what point/offset will the rim contact the strut with these wheel widths? I notice that most 8.5" wheels at the front with a +45 offset are paper width close to the shock absorber so, is this the very limit? I imagine a +50 would never work. A +45 offset on a 8" rim would surely leave a little more room, maybe even allow a +40 without rubbing the arch too much. I'm not so sure about the rear. I never hear anyone complain about rubbing the shock absorber there and surely Apex's 9.5" ET58 ARC 8 proves that there is more room? |
02-13-2014, 05:56 PM | #2 |
Rep 57
It depends on the tire and tire brand, but I think Apex Arc-8 is about as high as you can go for maximum tire width.
My front are 18x8.5 ET45 with 235/40 PSS at stock sport suspension height with no rubbing but barely clears the strut. I have 18x9.5 ET62 rear with 5mm spacer and 275x35 PSS with no rubbing. |
02-13-2014, 07:42 PM | #4 | |
California-bound
385
Rep 1,480
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
02-14-2014, 08:25 AM | #5 |
66
Rep 1,267
Drives: AW 135i
The Arc8 is a +62 offset and the best bet to maximize rubber width without rubbing.
Build thread: http://www.1addicts.com/forums/showthread.php?t=748935
02-14-2014, 02:41 PM | #6 |
General
2042
Rep 25,989
From our experience, between ET40~45 front, and ET50~58 rear is ideal.
VMR|Wheels | 714.442.7916 |
02-17-2014, 02:28 PM | #8 | |
195
Rep 1,317
Wibbles on here, has a set of unused Apex ARC-8 for sale as he's now sold his 135i before he even fitted them. He did have them up for £1200 (there's an ad on here somewhere) but I suspect he might be open to a good offer. Worth a PM to him, and will be cheaper than importing them yourself.
2017 X5 4.0dSE ~ Atlas Cedar:Ind.Amaro Brown Merino&Piano Blk, Sport Auto, DHP, Comfort seats, Cold weather pack, HK audio, Electric towbar, Sun protection glass.
02-20-2014, 11:39 AM | #9 |
170
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
WOW that is alot or rear tire, and PSS at that... I am jealous.
"Since light travels faster than sound, some people appear bright until you hear them speak". |
02-20-2014, 02:54 PM | #10 |
32
Rep 919
You can run mid 30s front and rear on a 8.5/10'' wheel, respectively, before rubbing the strut. You will need to engage in a lot of fender and liner work if you're looking to run this kind of setup, not to mention work with the camber. Even after you get the wheels and tires on, you will scrape when the springs compress.
I'm not certain about the measurements on a 9.5'' rear. |
02-20-2014, 03:18 PM | #11 | |
326
Rep 914
I plan to have my car professionally measured to get the widest possible wheels front/rear. My setup will most likely vary from popular opinion (more camber and fender work), but I also plan to get it measured for optimum width/offset on stock fenders/stock camber settings as well. I will post the measurements when they are done. |
02-20-2014, 04:36 PM | #12 |
32
Rep 919
At that point, would you be looking to run a 9'' width wheel with an offset in the low 30s instead? (with one inch being about 25mm)
02-20-2014, 05:22 PM | #13 | |
326
Rep 914
02-20-2014, 05:35 PM | #14 |
California-bound
385
Rep 1,480
@larryn was using x9 up front with a 255. Required spacers to hit optimum offset, and camber plates.
02-20-2014, 09:32 PM | #15 |
2148
Rep 10,176
