ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
  TireRack
      11-05-2007, 06:49 PM   #1
imolazhp_ci
29
Drives: Z4 M Coupe
Brake Pad Size for M Coupe...
hey... does anyone know what the sizing for the stock pads are? are they just the same as the Normal M3? because i can't seem to find any variation between regular M3 Brakes and CSL Brakes...
      11-06-2007, 03:55 AM   #2
RussRamz
M Slut
RussRamz's Avatar
18
Drives: 2011 M3 Coupe Mineral White
Location: Adenau, GE via 3 years in dreadful El Paso, TX
The front brake pads are BMW Part #: 34112282995
This part number is the same as the brakes for the M3 CSL and M3 with the competition package, however the straight M3 has different brakes. You can do a search on www.realoem.com and research the same information if you care to do so.
      11-06-2007, 04:23 AM   #3
imolazhp_ci
29
Drives: Z4 M Coupe
no. im not concerned with the part number, i need the SIZE code... like for aftermarket pads.
      02-26-2008, 03:29 PM   #4
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
That's because the brake pad backing plate sizes are the same between the two. M3, E46 330i/Ci, MZ4 Roadster and Coupe, and M3 CSL/competition package all use the same size front brake pad backing plate. The differences between the pad numbers are pad material (Jurid vs Textar) and the actual prong that holds the pads into the pistons since the M3 CSL/Competition Package/MZ4 Roadster and Coupe has much larger piston than the M3 which has larger piston than the 330i/Ci.
zpost
