01-20-2014, 05:42 PM | #1 |
16
Rep 107
Wheel weight
I belive OEM wheels are about 26lb front and 28lb rear. I just pulled my winters off and put my summer setup on since we're having a warm spell. Man, do these 264's seem heavy! I can save 8 to 9 lbs per corner by going with light wheels like Apex. Is it worth the $1200 plus to you guys who've done it. Not just for the look or ability to run wider tires, but the handling.
Thanks.
2008 135i- Sparkling Graphite-Steptronic
ESS Stage 3 Flash-BMS Dual Cones-Helix Intercooler-AR Design Catless Downpipe-Berk DP Back Full Street Exhaust-AR Design Oil Cooler-AR Design Catch Can-OS Giken LSD-Bilstein B12 Kit-Whiteline rear sub-frame bushing inserts. 225-255 Direzza Z2. Last edited by Mountain135; 01-22-2014 at 10:23 AM.. |
01-21-2014, 10:49 AM | #3 |
Resident Tamed Racing Driver
298
Rep 4,697
It impacts every aspect of performance and is hugely noticeable. Unsprung weight savings are always a big deal. The key is making sure you get a well made wheel like APEX.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
01-21-2014, 10:55 AM | #4 | |
206
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
If you have anymore questions or would like a quote on wheels shoot me a PM Last edited by Nitrous Garage; 01-21-2014 at 03:04 PM.. |
01-21-2014, 02:56 PM | #5 |
16
Rep 107
Good stuff. Thanks guys
ESS Stage 3 Flash-BMS Dual Cones-Helix Intercooler-AR Design Catless Downpipe-Berk DP Back Full Street Exhaust-AR Design Oil Cooler-AR Design Catch Can-OS Giken LSD-Bilstein B12 Kit-Whiteline rear sub-frame bushing inserts. 225-255 Direzza Z2. |
01-21-2014, 08:00 PM | #6 |
1418
Rep 2,560
Drives: Rapidly from A to B
If you're really serious about going on a diet you can swap the wheels and the brake rotors. You should be able to get 6 to 8 lbs from the wheel swap and an additional 4 to 5 from brake rotor swap. ECS tuning and rbbrakes both have 2 piece rotors that are 4.7# lighter than stock.
http://www.ecstuning.com/BMW-E82-135...ing/ES2550968/ http://www.racingbrake.com/135i-E82-...-11-p/2166.htm There are separate threads that have reviewed these that you should look at before making the call. Nevertheless there are options are out there for sure. A total loss of 9 to 10# or more of rotating unsprung weight is huge and you will likely feel a difference. Right now I'm half way there with the lightweight wheels. I'm partial to the rbbrake rotors as I don't want cross drill but $s are making me think twice. |
01-22-2014, 07:43 AM | #8 |
16
Rep 107
Are the 128 calipers and rotors lighter duty and less efficient?
01-22-2014, 05:48 PM | #9 |
1418
Rep 2,560
They have a smaller diameter. Not sure what you mean by less efficient.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
01-22-2014, 06:07 PM | #10 |
460
Rep 4,531
01-23-2014, 03:37 PM | #11 |
16
Rep 107
Interesting! So our big 6-piston calipers work no better than smaller units on 128. Why do you suppose BMW puts them on?
01-23-2014, 10:59 PM | #12 |
1418
Rep 2,560
That's the right question. Don't expect the same results from repeated stops at high speeds. Also not clear what the results would be with very grippy tires vs the non grippy oem rflts.
I wouldn't recommend reducing the rotor size to save unsprung weight. However, you can change the rotor to a 2 piece and get a benefit while retaining the overall braking effectiveness.
01-23-2014, 11:23 PM | #13 |
119
Rep 377
01-24-2014, 11:47 AM | #14 | |
298
Rep 4,697
On the track, both fall seriously short. The 135 has critical component failure when the brakes overheat and the 128i chucks itself into limp mode when the brakes get hot.
