01-15-2014, 05:02 PM | #1 |
Rep 15
Quality issues with McGard wheel locks
Anyone else seen quality issues with McGard wheel locks, or more specifically their keys? I had one key bend on me under quite a bit of torque -- so basically when you try to loosen the bolt it pops out. I got a brand new key today from the dealer (had to special order it) and after putting about 100 ft-lbs on the key, it bent the same way. The first one I could understand since I was putting probably 350-400 lbs of torque on it (thanks, BMW of Alexandria for over tightening...) but since then I had my local dealer break the bolts free and retorque to 100 ft-lbs so that wouldn't happen again. I've had 2 keys do this now, which is pretty pathetic since its pretty much a purpose-built item, or so you'd think. Now I've got 3 snow tires on and one runflat...which is NOT good, I know. Hopefully it'll be one day and only a trip to the dealer, since I can walk to work.
Just sharing my experience, these are the locks that BMW seems to use as OEM. Once I go back to the dealer and have them replace it with a regular ol' wheel bolt these pieces of junk are going straight in the trash. Anyone have recommendations for locking wheel bolts that don't suck? Also FWIW my winter set has narrower lug sockets so the McGards won't fit anyways. |
01-15-2014, 10:30 PM | #2 |
California-bound
385
Rep 1,480
I used McGard spline-drive lug nuts on my old Mazda's summer/race setup for many years, with nary a paint chip, let alone any real issues. And they were bolted/unbolted probably hundreds of times, and saw a lot of track/AutoX use...
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
01-15-2014, 10:38 PM | #3 |
Admiral of the Fleet
265
Rep 3,552
Known Issue
I believe this is what you're talking about as I had my wheel lock key stripped and mangled pretty badly so it won't grip or take them off at all. I was told by the dealer that it's a known issue and you have to be careful with them and hand tighten/loosen them, at least at first, if not more. Supposedly BMW has since redesigned the wheel locks because of this.
This picture look familiar? |
01-16-2014, 12:25 AM | #4 |
16
Rep 421
Had that issue before on my previous 135i. My local tire guy used impact wrench and ruined them while swapping tires. Both the lock and the key were stripped ended up had to chisel the lock out. The previous version of wheel lock from BMW (not McGard) was much better.
2011 1M VO stripper
2009 AW 135i M-sp (sold) 2002 SG MINI Cooper (sold) |
01-16-2014, 06:48 AM | #5 | |
Rep 15
01-16-2014, 07:06 AM | #6 |
4338
Rep 6,196
Well, 100 lb.ft is too much. Spec is 88.
It is also best to use an impact to remove them. With an impact gun, you get pure rotational movement, and no force down, which can cause it to pop out of the nut and break. I have a master set for Acuras (we also use McGuard) that I use 5 to six times a day, and have been using it for several years. Impact off, and an impact with a torque stick to put them on. Still good. |
01-16-2014, 07:21 AM | #7 | |
Rep 15
01-16-2014, 08:51 AM | #9 |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
I always thought those wheels locks were rather mediocre... I removed them all and replaced them with standard bolts.
01-16-2014, 08:58 AM | #10 | ||
265
Rep 3,552
I'm debating just removing them so I don't have this issue again as I'm not sure how many people are having their rims stolen these days. |
01-16-2014, 02:36 PM | #11 |
998
Rep 3,784
My thought is that the car would be stolen as well, so if the car is being stripped, those locks would hardly impede the thieves.
03-12-2014, 04:06 PM | #13 |
Rep 56
hey folks not to hijack the thread. I got a 2013 135 and the previous owner did not give the dealership(infinity dealer) their wheel lock key. Are those standardized? Can I get the dealer to get the key off a list of keys or is there a master key?
Regards Nick |
03-12-2014, 05:59 PM | #14 | |
33
Rep 691
I might be wrong, but I think BMW has a few different lock sets. If it's not aftermarket, I'm sure a dealer could at least help you figure out which key you might need. |
