11-09-2013, 06:53 PM | #1 |
289
Rep 3,201
2011 E90 M3 Level X Audio Upgrade by Musicar Northwest
One of our local clients had a Level Three 3-way system installed a few months ago, and decided that he wanted to go beyond - he wanted a 4-way system, and he asked how he could exceed the level of performance he had.
He selected: - Dynaudio MD102 30mm tweeters and Esotar 430 midranges (fully active) - His existing Maestro underseats (but bandpassed as midbasses) - Morel Ultimo SC104 carbon-fiber subwoofer - Three Mosconi AS series power amplifiers - 100x4 on the mids and tweeters, 200x2 on the midbasses, 600W on the sub. - His current Helix DSP managing the new fully-active system - His current Morel Hybrid 402 as rear speakers (powered by a dedicated Arc amp) The requirements were: - Load floor unencumbered - No false floor - Stock appearing interior - Rears present for Rear PDC and for music if faded aft - Subwoofer level control - Reversible installation All work performed by my partner Tom Miller. Original DSP location: New DSP location: The Dynes in the doors: The woofers underseat (even though these were already there, we had pics) Rear speakers: The amps had to fit in the corner, in the same footprint that the CD changer trim would have taken. However, the CDC trim isn't tall enough for the amps used. The pedestal has a fan in it. The finished trunk: Sounded scary good. It was a really fun car to listen to. |
11-12-2013, 12:09 PM | #4 |
289
Rep 3,201
Tom does great work
I wish the car had been EPS - we could have used a DA and run digital straight into the DSP. But even so, it sounded really impressive. |
11-13-2013, 09:00 AM | #5 | |
2297
Rep 13,005
If you split the Combox/MULF MOST ring connection (shown in the first photo) into a DA2 then it would have done the trick, by coding the OEM HU/iDrive to SA752 first. Next time, next time... |
11-13-2013, 09:16 AM | #6 |
530
Rep 6,149
Install looks bad a$$, great job!!!
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
11-13-2013, 11:03 AM | #7 |
289
Rep 3,201
We offered this option to the client, but he did not want to recode anything.
11-13-2013, 01:41 PM | #8 |
Rep 57
Firstly, Amazing work, as always.
Secondly, it's been awhile since I've looked into the BMW audio realm, but this has me thinking about my current setup. Is there now a way to split into the most ring and get rid of my LC2i and utilize digital processing? Or did I just completely misunderstand the above posts? |
11-13-2013, 03:13 PM | #9 |
289
Rep 3,201
There is a way to use the MOST as the audio delivery system into a Mobridge "digital preamp". If your E92 is early 2011 and has the USB interface which requires the split cable (6FL?) then you are analog out of an iPod into the head unit, and MOST back to the Digital Preamp. If you have 6FN, or upgrade to it, then you have USB decoding of the iPod files in the back of the car, and your iDrive or Pro CD becomes a transport.
Then you can get a Toslink input DSP and that becomes your analog preamp. Volume controls all work as before because the Mobridge piece actually recalculates amplitude based on the volume commands on the MOST bus. If your car is HK or EPS, it's PNP. If it's HiFi or base Stereo, there is a recode to the HU to 677 needed. I did this in my car with the recode from HiFi (I was a beta tester for the DA2, which retains the 7-band EQ in the HK and EPS systems, but doesn't have as much output (there is more headroom needed in the recalculating for the potential EQ boosting) If you use the DA with certain DSP processors with low outputs, there is a low output issue, but we have good experience with which ones are fine with the DA2 (I prefer to have the DA2 rather than the DA1). I didn't think it was going to be a big upgrade. I was surprised by the improvement in my car's system. |
11-13-2013, 03:17 PM | #10 |
BimmerPost Supporting Vendor
8238
Rep 18,833
Drives: BMW
Love the final result, looks very clean/OEM.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-13-2013, 03:27 PM | #11 |
289
Rep 3,201
I re-read what I wrote above. If you have the split cable, going this route will still work, and will still have advantages. The thing is the biggest benefit will be when you play CDs.
If you are using the split cable, the iPod still sounds better this way. My car didn't have the 6FN upgrade, and the difference was apparent either way. But USB sticks with high quality files sounded better than Apple Lossless on my iPod, due to the analog path into the BMW head unit on the split cable and the resistors in that line that are to protect against static discharge damage to the gear. Some folks have shorted across those resistors to get more signal into the head unit, but I don't want static to blow my iDrive |
11-13-2013, 04:15 PM | #13 | |
2297
Rep 13,005
11-13-2013, 04:46 PM | #14 | |||
Rep 57
I'm just trying to see if there is any advantage to switching out my current LC2i to a different type of setup to yield better performance. Currently, I have the stock amp, your harness, LC2i, two Zapco amps, 2 under seat woofers and a 12" Morel Ultimo. My setup is similar to this package: http://www.m3post.com/forums/showthread.php?t=497008 On a side note... Any updates on that E46 coupe enclosure? |
11-13-2013, 04:56 PM | #16 |
Rep 57
Well I was assuming I would be replacing the stock amp, but then Technic made me think a little more then I started second guessing myself...
11-18-2013, 11:37 PM | #18 |
Retired Curmudgeon
2985
Rep 4,047
Agreed. The attention to detail is very nice indeed, and I'm sure it sounds sublime.
I still can't decide if this car is a keeper, so my system is staying pedestrian (on a good day).
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
11-25-2013, 11:49 PM | #21 |
You got my money?
3168
Rep 4,652
Drives: Ice Cream Truck
I like how that enclosure sits on top of the tool tray rather than how mine replaces it. Is that a new design or something VP? Oh wait... is that a 10" woofer and the reason why it looks that way?
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
