      11-08-2013, 05:03 PM   #1
arthurtwp
arthurtwp's Avatar
Australia
36
Drives: '12 1 Series M '17 M3 Comp DCT
angel eye change
hey guys. so sorry but I am probably one of the worse diy guys around.
picked up replacement angel eyes for my 06 e87 130i m sport.
tried changing it myself last night and was completely stumped.
the left I could not gain access to due to air box in situ and limiting the room to work with.
the right I got the cover off. and could not figure out how to change the bulb (
wonder if anyone has any suggestions?
      11-09-2013, 02:06 PM   #2
kore
kore's Avatar
Spain
Drives: E81 118D N47
Hi. Have you tried removing the airbox cover? Maybe you'll have more space then
      11-10-2013, 02:50 AM   #3
arthurtwp
arthurtwp's Avatar
Australia
36
awesome idea. yeah friend and I tinkered for a bit. ended up moving the airbox away by temporarily disconnecting from the intake.
hmmm... intakes quite easily detached.. wonder if its.. easily replaced :P
      11-10-2013, 11:19 PM   #4
Cam 130i
Drives: BMW E87130i
Hi Arthurtwp,
Last week i replaced the halo lights on my 06 130i ,it appears more difficult than it is because you can't see what you are doing!
You don't need to remove the covers from the rear of the headlights, the halo globe is separate and is located below and to the outside of the headlight unit, just follow the wires.
It is then just a matter of turning the lamp holder in an anti clockwise direction and removing it. Replacement is the reverse.
I was able to do it without moving the air box etc. Do the drivers side first as it is easier.
What are you replacing them with? I went to 6 watt LED with is a nice white light BUT not bright enough in daylight so I have ordered 32 watt LED's on Ebay and i will upgrade once they are delivered.
It really is a job that most guys are suited to, You are searching around in the dark for a little hole and trying to stick something into it!!
Good Luck
Cameron
      11-11-2013, 09:39 AM   #5
arthurtwp
arthurtwp's Avatar
Australia
36
haha yeah. the passenger side particularly painful. especially the 'oh I did not have to struggle with the covers' bit.
I went with 6k LEDs. didnt want them too blue or bright being parking lights. unfortunately they are a slightly different shade as my xenon's. but.. mehs.
was thinking of getting the lux LEDs. ended up cheaping out and getting random 70oz dollar ones (including delivery). worked alright so far (I.e. 2 days) with no error codes. the install was a bit hairy cause one of the connector pins was a bit soft and bent. :S but alls well in the end. will post a picture when I can.
      11-11-2013, 09:39 AM   #6
arthurtwp
arthurtwp's Avatar
Australia
36
      11-12-2013, 07:04 PM   #7
iastute
Drives:
Would you be able to post pics of your upgrade? Contemplating on updating mine too.
      11-13-2013, 08:46 AM   #8
arthurtwp
arthurtwp's Avatar
Australia
36
will try to get them after work tomorrow. neighbors not gonna appreciate the lights into their house this time of the night haha. its a nice upgrade. having said that the 6k LEDs are not too bright..
      11-14-2013, 01:48 PM   #9
E92-Lighting
E92-Lighting's Avatar
859
Drives: Next Generation LED Lighting
we have DIY guides via our website for installation
      03-10-2014, 06:43 AM   #10
Corona Extra
Drives: E87 118d //M
Just bought 6k LEDS myself, very curious to see how yours turned out!
      03-13-2014, 02:05 AM   #11
arthurtwp
arthurtwp's Avatar
Australia
36
Mine the turned put alright. friend has a lux set. still way brighter and better.. mine are barely visible in daylight.. which doesn't matter since the DRL on the E87 includes the low beams.. you can see them at night on my Sig )
1addicts
