09-27-2013, 08:22 AM | #1 |
29
Rep 182
Tire question
Hey Guys/gals,
So now i have a nail in my rear bridgestone RFT, I haven't lost air pressure yet. I am thinking of changing to the Michelin PSS(non RFT). I searched and read several folks on this forum who have done it. I am going to be puting them on my 296 wheels. I have two questions. 1. Can i put on 235/30/19 in the fronts and 265/35/19 in the rears on my 296 style rims, without any mods and rubbing or any issues whatsoever. 2. Which is the best and most reliable 'flat tire repair kits' for these tires just incase I do get a flat. Hate to be stranded in teh middle of nowhere. 3. Does anyone have a picture of these wheels and tires combo on thier car, that I could possibly have a look at. Thanks and sorry if it is a question that is beaten to death. I was just not able to find a straight forward answer for the 296 wheels.. Thanks, Jake... |
09-27-2013, 08:44 AM | #2 |
245
Rep 2,387
I can answer #2 for you. BMW or Conti make a emergency tire inflation kit. they're both the same, and Conti is cheaper (at Tire Rack).
If you have a pass-through to the trunk, the Conti kit will amazingly fit perfectly in between the inner and out doors, like it was custom made. Can't vouch for the BMW version.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
09-27-2013, 08:52 AM | #3 |
118
Rep 1,668
forgive me for sounding stupid but i thought that the 296 wheels came in 18" not 19".
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
09-27-2013, 08:57 AM | #4 |
Rep 32
Drives: 2007 328i AND 2003 325i
The 296 wheels definitely come in 19, I have them in that size.
As to question #1: - I have no done that yet but recently asked the same question on the boards and to tirerack.com The answers were all... "yup, the 235/265 will fit those wheels as long as they're at least 19x8 and 19x9". The 296 wheels are 19x8 and 19x9 so you should be good. Tirerack even shows 235/265 as an 'optional' size for the car. I decided to upgrade my wheels at the same time, to 19x8.5 and 19x9.5, and will be placing the order today. |
09-27-2013, 10:18 AM | #6 |
Rep 32
I just relooked at your post and see you asked about 235/30 and 265/35... which is NOT what I am getting or asked about. I am getting/asked about 235/35 and 265/30.. so I am not sure if what you're asking will work
I'm getting the Silver VMR V710 with Contininental DWS (all season tires) Wheels are 19x8.5 and 19x9.5, tires are 235/35/19 and 265/30/19 |
09-27-2013, 10:28 AM | #7 |
29
Rep 182
Sorry I might be loosing my mind and confusing myself here with all these threads I have been reading.
Basically I just want to go one size up in the front and rear with my 296 19" wheels and Michelin PSS. My current OEM bridgestones are 225/35-19 fronts and 255/30-19 on the rears. Thanks, Jake... |
09-27-2013, 11:23 AM | #8 | |
Rep 32
the tire will have a wider cross-section and slightly taller that what you currently have |
09-30-2013, 11:32 AM | #9 |
29
Rep 182
Thanks folks, guess I will go with the one size up option. Hopefully it works out and I don't get any flats. I will alaso be getting the conti repair kit just in case...
09-30-2013, 01:38 PM | #10 |
25
Rep 151
I had the 296 rims with 235/35 and 265/30 combination last winter:
For the winter it was ok for me. It fits good. Had 12mm spacers at the rear with slight rubbing on inner plastic wheels housings. For the summer I'd recommend the oem-size 225/35 and 255/30, because the bigger wheels are much more angular on the slim rims. 235/265 is the perfect choise for 8,5J and 9,5J. |
10-04-2013, 10:11 PM | #11 |
14
Rep 85
Drives: 2014 Z4 28i
ok I have a question...
19x8.5 front and 19x 9.5 rear. Getting 235/35/19 front Question is: Can I get 255/35/19 on the rear? Everyone says to get the 265/30/19 on the rear... but I saw them today and the profile is very low. I think the 255/35/19 will be a smoother ride. So can anyone explain if 235/35/19 and 255/35/19 work? Any drawbacks? |
10-05-2013, 11:24 AM | #12 | |
3188
Rep 10,509
http://www.amazon.com/Slime-1034-A-T.../dp/B000ET525K |
10-05-2013, 01:21 PM | #13 | |
245
Rep 2,387
10-05-2013, 10:55 PM | #14 | |
42
Rep 640
The ride and handling are greatly improved with the PSS. I also like the look of the taller profile and less wheel well gap.
HerrK - 2021 X5 40i M Sport l PCD l Atlantis Blue/Ext'd Tartufo Merino l M Sport w/blue Calipers l Matt Popular l HK Sound l 740's l Exec & Drive Pro Pack Sold w/Great Memories - E89 Z4 l ED 2010 l 2011 35i l Crimson/Ext'd Coral Red w/Alum l 6 sp MT l Prem Sound l Sport Pack l 296's |
10-06-2013, 01:48 AM | #15 | |
3188
Rep 10,509
The 2 times I've used that kit I have asked my wife to slowly move the car forward while I inspect the tread. I chalk the sidewall to orient myself. The last time I used the kit, it was to repair an OEM RFT that got a nail but had not been driven without air. Fix was fine for 23 months (then I turned the car in) Actually, the reason I went with that kit in the first place was a nail in the tread that the fix a flat can was just ineffective at sealing, which is why I recommend keeping it around as back up. |
