08-20-2013, 05:18 PM | #1 |
Rep 129
Motor mount heat shield
There is a heat shield on the passenger side motor mount. Does anyone know what is being shielded from the heat and what risk might there if that heat shield was not there? I ask because the people that I hired to install the vibra tech motor mounts did not re-install the heat shield as they did not feel that it was any longer necessary. Any thoughts?
08-20-2013, 05:51 PM | #2 |
2432
Rep 11,667
This was touched on in the other motor mount thread.
IMO it should still be used. There is a lot of heat from the exhaust in that area. Just because the rubber is encased in an aluminum pot, does not mean that it is protected from the heat It's probably better than the OE mount, but I figure ever bit helps.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
08-21-2013, 01:54 AM | #3 |
423
Rep 5,329
euro cars dont even come with that heat shield...... but the catted headers you guys will create more heat hence the shielding.........
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
08-21-2013, 07:38 AM | #4 |
43
Rep 400
If I paid somebody to install, I would want the heat shield along with it. It can only help prolong the life of the mount. Keep in mind that there is a tab that has to be flattened for it to fit now.
08-21-2013, 11:17 AM | #5 |
Certified Adrenaline Junkie
43
Rep 1,325
I didn't reinstall mine but I have catless headers that are jet hotted. So, in theory, they shouldn't radiate as much heat as stock catted headers.
08-21-2013, 12:43 PM | #6 |
Rep 129
Interesting thoughts. You see I'm wondering if I should put them through the bother of reinstalling a part that may not be necessary. I will do it if I really feel that it is a relevant component with the vibra tech mounts.
08-21-2013, 02:36 PM | #7 |
My other car is on Mars
636
Rep 3,124
My left side stock mount was fine when I replaced it.
I thought my right side was fine too, until I removed it and found a big crack that was hidden by the heat shield. I'm going to wager that it didn't just crack from age alone, it degraded from heat, and it would have degraded faster without the shield. My recommendation would be to get the shield put back on, or do it your self. Given what I found, I'm considering adding more shielding.
Warning: May contain traces of nuts.
08-21-2013, 02:41 PM | #8 | |
Rep 129
08-21-2013, 03:25 PM | #9 |
636
Rep 3,124
The crack was in the stock mount.
2006 with 88k miles. Gently driven. YMMV. Replaced with the vibra tech. As was said, not sure if they have the same sensitivity to heat, but heat + rubber = no.
08-21-2013, 05:43 PM | #10 |
2432
Rep 11,667
One of the reasons why I'm having my headers coated.
08-22-2013, 09:32 AM | #12 | |
43
Rep 1,325
