TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Vendors Classifieds
      08-07-2013, 05:30 PM   #1
kenny@velosdesignwerks
kenny@velosdesignwerks's Avatar
68
Drives: silver
Velos Designwerks | KW Suspension | End of Summer Sale
Hello Members,
We are proud to announce we will be offering the best pricing on KW V3 Suspension solutions for the X6M to the Xbimmer community as part of our end of summer sale. KW V3s kits are in-stock and most kits will ship with in 24 HRS. Limited availability first come first served. PM me for pricing information.
http://velosdesignwerks.com/products.../kw-suspension
Feel free to PM me for more info or any additional questions.
KW V3
State-of-the-art technology from motor sports for more performance on the road. The separate and independently adjustable rebound- and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Compression- and rebound adjustment
As far it is vehicle-specifically possible, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and also influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be adapted to the requirements of the driver. Moreover the driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics.
The compression phase adjustment is carried out at the lower end of the shock absorber via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
Damping technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board (TÜV)
High-quality components for long durability
Infinitely variable rebound damping adjustment
14-way adjustable compression damping
Unique, individually working damping force adjustment
Comprehensive documentation for easy use
      08-15-2013, 08:19 AM   #2
Omar@VelosDesignwerks
Omar@VelosDesignwerks's Avatar
445
Drives: Different Ones
all pm's replied to
