ZPOST
  TireRack
      08-06-2013, 04:22 PM   #1
Urluz3n
Lackey
Drives: 07 BMW M Coupe
EGR/SAI Delete
Has anyone deleted or removed the secondary air pump that pumps air into the cats when starting? I wonder what kind of CEL I will get? Does the forward or rear O2 sensors send the error? Or is there an error? I am told deleting it will save you about 7 lbs. an clean up the engine compartment.
Thank You
Paul
      08-06-2013, 04:48 PM   #2
Z4inAZ
Drives: Z4 2.5 03
I also wonder what kind of CEL you would get if any. On older cars you could just remove it. All it does is blow extra air into the engine for the first couple minutes to help emissions.
EGR is something different though... thats exhaust gas recirculation and is a different way to help emissions. The M54 has both and though both can be deleted, generally only the secondary air pump is.
Car modifying is about improving things, not just changing them
      08-06-2013, 07:32 PM   #3
seank
enthusiast
seank's Avatar
48
Drives: e30 m3,e90 wagon,sprinter,z4m
Secondary Air Pump Post. To be tested soon.
http://www.zpost.com/forums/showthre...ghlight=andrew
      08-07-2013, 06:58 PM   #4
Urluz3n
Lackey
Well I did the delete today. And after the first running around town, no check engine light. Somewhere I read that the SAI doesn't doesn't activate or the pump does not turn on until the ambient temperature Is below 50°. Since I keep the car in the garage even during the winter my ambient temperature may never drop below 50°.
      08-07-2013, 08:55 PM   #5
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
What did you do with the electrical plug going to the pump? My kit arrives tomorrow
      08-07-2013, 09:29 PM   #6
seank
enthusiast
seank's Avatar
48
Mine is garaged and at 60 at night. My afr gauge says it kicks on.
      08-08-2013, 08:09 AM   #7
Beedub
423
Drives: 2007 Z4 M roadster vt2-500
my SAP unit comes on every start no-matter the temps...
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com
      08-08-2013, 04:43 PM   #8
Urluz3n
Lackey
Well I took the car to work and still no CEL. I am hoping this is a sign that it won't come on. That part of the engine looks better with out the pump and its hose. I am tempted to remove the heat shield so the header is more visible.
      08-08-2013, 04:57 PM   #9
ZStig
279
and increase your underhood temps? thats a ricer mod
      08-08-2013, 05:53 PM   #10
Urluz3n
Lackey
To be honest. I can't see that the little heat shield can't do much. What's wrong showing off the headers? I take a lot of pride in my car!
Besides we all have a little ricer in us. Hell most of my carbon fiber accessories is from CHINA!!
      08-08-2013, 06:20 PM   #11
Urluz3n
Lackey
Does it look naked without the SAI/EGR?
      08-08-2013, 10:35 PM   #12
ZStig
279
throw a turbo in there. hahaah
no it looks fine. I think you can remove the bracket that you left in there
      08-08-2013, 11:46 PM   #13
seank
enthusiast
seank's Avatar
48
You definitely have a place to warm your lunch.
      08-09-2013, 09:32 AM   #14
Incompatible
55
Drives: 07 AW Z4C 3.0Si
A flux capacitor would fit nicely.
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
      08-09-2013, 12:12 PM   #15
ZStig
279
actually valid question. we could put something useful there...
      08-09-2013, 12:25 PM   #16
Urluz3n
Lackey
Actually the mount is welded in place. I already have an idea as to what I want to put in that area. I will see if I can come up with a mount for an oil catch can, with a pleasing appearance.
      08-09-2013, 01:33 PM   #17
Beedub
423
it would be a nice pleace to mount a catch can actually.... especially if not re-circing.
      08-09-2013, 01:48 PM   #18
ZStig
279
actually yeah, I saw that its where that vt1-445kit seller has in the pics. definitely a great spot
      08-09-2013, 06:56 PM   #19
rkstar9
75
Drives: '10 X5 3.5D
interesting the 2.5i has the SAP mount next to the windshield wiper fluid.
535D Xdrive DUDMD Stage 1
x5d e70 DUDMD stage 2 tune
      08-09-2013, 10:34 PM   #20
StickMon
My other car is on Mars
StickMon's Avatar
636
Drives: 2006 MR
Yesterday I thought this was a frivolous mod.
Today I put on my VT motor mounts, and the SAI was TOTALLY in my way.
I didn't have a new gasket, so I couldn't remove the valve, so I couldn't get the heat shields out, so I had to use a U-joint to get the top right motor mount nut off.
And when it broke loose I lost the skin off 2 knuckles on the sharp friggin' cheese grater on top of the pump.
THE SAI MUST DIE!
Warning: May contain traces of nuts.
      08-09-2013, 10:55 PM   #21
seank
enthusiast
seank's Avatar
48
THE SAI MUST DIE!
That's nuts.
      08-18-2013, 01:11 PM   #22
pal
pal's Avatar
433
Drives: Z4 M Coupe
Removed the SAI on my Z4MC today and scanned the car for Readiness and Codes before removal and then after a short drive post removal.
There is a Readiness check for this pump so I suspect that once the ECU tries to turn it on (cold day possibly), this check will fail.
Sunday,18,August,2013,12:46:17:10376
VCDS Release 11.11.6: Generic OBD2
Mode 01 - PID 01 : Readiness -- Address 12
Number of DTCs stored: 0 -- MIL Status: MIL OFF
Misfire monitoring: Passed
Fuel System: Passed
Comprehensive Components: Passed
Catalyst monitoring: Passed
Heated catalyst monitoring: Not installed.
Evaporative system monitoring: Passed
Secondary air system monitoring: Passed
A/C system refrigerant monitoring: Not installed.
Oxygen sensor monitoring: Passed
Oxygen sensor heater monitoring: Passed
Exhaust Gas Recirculation: Not installed.
Post drive there was one Pending DTC below -
Sunday,18,August,2013,14:02:35:10376
Mode 07: Pending emission related fault codes
Address 12 (Engine): 1 Fault Found:
P0411 - Secondary Air Injection System: Incorrect Flow Detected
zpost
