07-28-2013, 01:10 AM | #1 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
For those with Linear Springs...
What heights are you running front and rear and does that include the use of a helper spring?
07-28-2013, 04:58 AM | #3 |
423
Rep 5,329
ride heights ???
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
07-28-2013, 10:07 AM | #4 |
2286
Rep 12,565
Spring lengths, ie 7", 6", 5.5" with helper, etc. Btw reason I ask is because I'm considering upping my spring rates. I currently have 450# 6" front, 550# 5.5" rear but it seems the rear is a custom length only offered by AST. So am I the odd one out using a 5.5" rear and if so, do I need to order through AST or can I just go with a 6" that is more readily available from other brands (Swift, GC, Hyperco, etc.)? Last edited by 3002 tii; 07-28-2013 at 10:16 AM.. |
07-28-2013, 10:18 AM | #6 |
2286
Rep 12,565
4" rear?? What shock are you using? Why so short? And when am I seeing you at the next track event???
07-28-2013, 10:28 AM | #8 | |
2286
Rep 12,565
How do you like the weight jacks? I'm going to get the car rebalanced and am thinking of picking those up. But I've also read (and don't understand why) that those only should be used with high spring rates. Other things I've read is that the spring can get unseated with the weight jacks... 'tis true? I'm wait listed for the glen in Sept with CCA but ill be doing a 3 day PCA event in Oct at NJMP. Hopefully see you there bud. |
07-28-2013, 02:39 PM | #11 |
2286
Rep 12,565
Pics with 5" springs? Car must be slammed... unfortunately NJ roads aren't as forgiving so I still need enough clearance just to make sure I can get to/from the track without bottoming out lol. I think I have about 2 finger gap.
07-28-2013, 03:46 PM | #15 |
enthusiast
48
Rep 1,695
08-06-2013, 09:17 PM | #17 |
35
Rep 441
I believe mine are both 5 inch swifts, I need to double check, when I adjust my ride height
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
08-29-2021, 08:52 PM | #18 |
180
Rep 700
I am thinking about getting the Rogue Articulating Spring Perches.
What length spring would be best? Currently, have Eibach lowering springs and the sitting spring height is 5.5", so I am thinking maybe a 4" spring would be correct to use with these?
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
08-30-2021, 04:01 AM | #19 | |
777
Rep 1,923
Those running 4" springs are making a mistake specially if you track.
