M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Mechanical Maintenance - Break-in, Oil, Fluids, Servicing, Etc.
      06-24-2013, 08:29 AM   #1
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Coolant leak
This is what I found this past weekend when I popped open the hood. I have already spoken to my Service Advisor (actually, Service Mgr) and he confirmed it's coolant leak. You guys may want to check yours.
      11-09-2013, 06:08 PM   #2
ImpetuousRacer
ImpetuousRacer's Avatar
67
Drives: 2017 Tesla Model X P100D
2013 BMW M5  [0.00]
Had same problem and had no idea until I took engine cover off and saw leak. Never smelled it or saw it on ground, or smoking etc.
Dealer fixed under warranty.
Parts Used:
1 x Feed Pipe 11 53 7 844 268
1 x Return Pipe 11 53 7 844 269
4 x Hose Clamp 32 41 1 131 346
      11-09-2013, 06:15 PM   #3
koxal
koxal's Avatar
121
Drives: 2015 LBB F85 X5M
2015 BMW X5M  [0.00]
2010 BMW M3  [0.00]
2013 BMW M5  [0.00]
mine was leaking too.
i had low coolant fluid warning.
dealer fixed under warranty.
      11-09-2013, 06:24 PM   #4
bobblehead
bobblehead's Avatar
256
Drives: warp speed
Mine was originally repaired with the same factory clamp. They then test pressured it and it failed to hold and leaked again. They had to use clamp with tightening type of screws (double) to fix it, now it has been about 5 months and all are good. No more leak.
Parts Used:
      11-12-2013, 06:12 PM   #5
ImpetuousRacer
67
2013 BMW M5  [0.00]
Hmm, I would assume my dealer didnt pressure test? or is that standard procedure? Ill take the cover off tonight to check things out.
      11-12-2013, 07:53 PM   #6
bobblehead
bobblehead's Avatar
256
Drives: warp speed
The service advisor said it was standard procedure as per requirement.
Either my dealer were simply following proper protocol or they went beyond the scope of warranty work.
      01-01-2020, 07:09 PM   #7
olis1
60
Drives: 2014 M5 Comp Package
I have the same problem. My mechanic said get screw tightening hose clamps. Does anyone know what size, where to buy? Amazon?
      01-02-2020, 05:18 AM   #8
M5Rick
General
M5Rick's Avatar
60017
Drives: M5 F10 DCT Gunmetal
Easiest job on the planet, measure one of old flex pipes and order I metre high temp synthetic pipe from e-b together with screw clamps.
      01-02-2020, 12:31 PM   #9
olis1
60
Yup, yup. Did some research and ended up doing the same thing. Even found it on Amazon prime, will be here tomorrow.
m5post
