06-16-2013, 06:13 AM | #2 |
5266
Rep 10,650
Not as far as I know. They probably consider the coolant to be lifetime. Everything is lifetime these days. They don't tell you how long one of these lifetimes is, though. It is safe to assume a shorter life than if you changed the fluids more often.
I have done all fluids but coolant on my 08M3 with 52k miles. Coolant is on the list for later this year. |
06-20-2013, 09:10 AM | #3 |
Rep 20
To my knowledge coolant is not a required service item for BMW as a maintenance item (Does not come up on the cbs data). They will not change it if you ask them too, only if the vehicle calls for it.
06-20-2013, 06:56 PM | #4 |
///M
161
Rep 1,867
BMW stated the coolant is lifetime so they won't change it, but i'm going to change mine out soon.
there a good DIY on the forum which I'm planning on doing soon hopefully, have a couple gallon of bmw coolant sitting at my house for months now.
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI |
06-21-2013, 06:54 AM | #5 |
145
Rep 409
I change mine every 2 years, when I do brake fluid. It is an easy DIY. The problem with the S65 is there is no coolant drain on the block, so you don't get close to getting all the coolant out. Normally I would change every 4 years, but on this engine with the lack of block drain, I have been going every 2.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
06-21-2013, 11:47 AM | #6 | |
2760
Rep 5,483
