05-15-2013, 11:03 PM | #1 |
19
Rep 196
Brass guide bushings and antiseize don't mix
Hey all.
I've learned from my mistake, hope you can to. I installed the brass guide pin bushings most of us know about. I read somewhere about how they require more maintenance than the standard rubber. I also read on some post to use Anti Seize compound on them. Well, did a track weekend on them and can't tell if they helped, but I had uneven pad wear. Turns out that while Anti Seize compound stop two metals from chemically binding together, it also gets really gummy and sticky after a number of heat cycles. My pads were worn unevenly. Like the piston was sticking against the rotor. I didn't realize it was the antiseize until my last track day on the original rubbers bushings. The pins still have antiseize on them, and terrible uneven pad wear again! I discovered that AntiSieze should not be used for the guide pins. Instead, look for a siliconized Brake Lube/silencer. I think they are called both or either. It works to silence vibration, but also to lube the guide pins, and the siliconized stuff is good for high temps. This is going in my track day tool bag now. Much cheaper than pads! Hopefully my mistake saves you from making it too
05-15-2013, 11:19 PM | #2 |
enthusiast
48
Rep 1,695
I made the same mistake back in the day on the track car. They don't need any lube. That is why it is made of brass. They call it "self lubricating." Just clean them every 3-6 months.
05-16-2013, 03:52 AM | #3 |
Rep 222
I have the brass bushings and use a thin smear of copper grease with no problems. I think that's the recommended way for these. With the OEM plastic bushings, no lubrication required.
05-16-2013, 05:23 AM | #4 |
2432
Rep 11,667
Look it up.
Ron Stygar posted it up several years ago according to BMW, even the OE pins are not to be lubed.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
05-16-2013, 02:33 PM | #5 |
Rep 102
I haven't checked with Bimmerworld, but I'll be installing these soon on my track car, and a number of racers use and recommended Permatex 24125 to lubricate the pins.
