05-10-2013, 11:55 AM | #3 |
38
Rep 529
What tires? Thanks.
2014 Porsche 911 Turbo S - FOR SALE
2010 BMW M3 (e90) - SOLD 2005 Corvette C6 - SOLD |
05-10-2013, 12:37 PM | #4 |
2740
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
275/30/19 will work but it's a little wide for a 9" wheel. I would recommend 255/35/19's for the front and 275/35/19 for the rear which will be a better match for the 9" and 10" wheels.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
05-10-2013, 02:27 PM | #6 |
30
Rep 361
The widest you should be able to run comfortably is 265 front and 285 rear.
Any larger may be too big and decrease performance.
05-11-2013, 12:19 AM | #8 |
38
Rep 529
Ha! I see 3 threads posted in the past week with this same question. Kinda funny. I answered the first two...not so much the 3rd.
BUT if it helps, in installing 275/30 and 295/30 PSS on AG 359's tomorrow in prep for my ESS install in a week. Very excited...
05-11-2013, 08:19 PM | #9 |
38
Rep 529
Ok, so I switched out my Vred 245/35 and 275/35 for PSS 275/30 and 295/30 today. All I can say is WOW what a difference. My first thoughts after driving around today...
THE GOOD: Incredible grip. Even right off the lot, they stuck to the road like glue. It is difficult to put into words how sticky these things are...especially with this width. Corners, straight lines, whatever. You are not going to slide unless you REALLY want to...or if you are SCed (...soon). THE BAD: A minor loss in steering feel, and a perceived sense of lessened sharpness when not pushing the car. As speed goes up, the natural M3 sharpness returns, however. Also, the car feels artificially heavy around town, despite the tires weighing approximately the same. Be it good or bad, I think it has to do with a combination of extra grip and extra width (i.e. more road friction). RUBBING: Fronts - no problem, no rub from lock to lock. Rears - no rubbing under normal driving, hard corners, and launches. Yes, they do rub on the fender liner under full compression, but diligent driving habits will prevent this. THE VERDICT: Fantastic switch. I cannot wait to see how they handle the extra power of an ESS! Hope this helps!
05-12-2013, 12:42 AM | #10 | |
Rep 85
05-12-2013, 12:55 AM | #11 |
38
Rep 529
I have an e90 on non-ZCP EDC suspension. Not really rubbing as I said, just on harsh road bumps. No big deal IMHO. Edit: Also may be wheel size? If you have a wider wheel, the tire may be more stretched and slightly shorter or may have less of a shoulder to catch the fender. Just a thought.
05-12-2013, 08:59 AM | #12 |
103
Rep 893
Semi- off topic, but this is good to hear. I'm looking at Swift springs and was wondering if I could run 295s with them. Since the H&R's lower the rear 0.6 and the Swifts lower the rear 0.7, i'd say i'll be ok.
05-12-2013, 06:50 PM | #13 |
Rep 85
How is that off topic? I have 359m wheels too. I doubt the .01 of an inch will matter although if they are really soft you may have problems. go 305s
